First post, by Kahenraz
- l33t
I have a Sankyo disc drive for my Compaq laptop that doesn't work. After disassembling and inspecting it closely, I found that one of the gears had cracked. I can't be certain that this is the actual problem, but it can't be good. When the broken part hits the other gear, it "jumps" a tooth.
I also noticed that the yellow, translucent gear in the middle is weirdly soft. It still spins the adjacent gears, but I'm not sure if it's supposed to be like that.
Anyways, is it possible to source a replacement gear for this drive? It might be possible to 3D print a new one, but I don't own a SLA printer.
It's also reasonable to guess that the laser might be bad, but I can only tackle one thing at a time. The laser is a KSS-610A.
