First post, by gmaverick2k
Anyone know where I can purchase a mount for the front panel where I can remove SD card from generic mounted sintech SD to IDE adapter. Having to open the side panel is getting a bit annoying when transferring files from main pc to SD card.
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: QDI Advance 10T/Pentium iii-S 1.4 GHz/Quadro2 Pro/Vortex 2/ESS 1868f/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 1 of 6, by douglar
search google for “floppy drive bay SD to IDE hard drive carrierº
Reply 2 of 6, by gmaverick2k
douglar wrote on 2025-06-21, 19:55:
Apologies, should've prefaced UK based or something relatively cheap
Reply 4 of 6, by StriderTR
douglar wrote on 2025-06-21, 22:15:
gmaverick2k wrote on 2025-06-21, 20:44:
Do you have access to a 3d printer?
If so, Thingiverse has several you can print. This is what I do. 😀
https://www.thingiverse.com/search?q=sd+ide&p … 2&sort=relevant
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 5 of 6, by Linoleum
... or you could use a HDD mobile rack drawer and keep the vintage-ish look.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 6 of 6, by gmaverick2k
Thanks for the suggestions guys
