First post, by twvd
I'd like to introduce 'Snow', a new classic Macintosh emulator I have been developing, which emulates 68k-based Macs.
My goal is to develop an accurate but user-friendly emulator. As such, it is able to run copy-protected games from bitstream and flux floppy images. It also has debugging features.
Currently it emulates the Macintosh 128K/512K, Plus, SE, Classic and the Macintosh II. I plan on adding more models in the future.
The emulator is open source, licensed under the MIT license.
Downloads are available at: https://snowemu.com/
Documentation can be found at: https://docs.snowemu.com/
And finally, the source code is available at: https://github.com/twvd/snow
Feedback, bug reports and ideas are most welcome!
Reply 2 of 15, by BaronSFel001
Interesting. It seems every Mac emulator exhibits one issue or another with certain games, none being ideal for the task. Will have to see if this can be made to work on Steam Deck and if its hardware accuracy provides just the non-MAME alternative many of us are looking for with games from the time before PowerPC (another realm that emulation still has a long way to go) but color Macs already offered enhancement over DOS PCs.
System 20: PIII 600, LAPC-I, MK1869 Xtreme, Voodoo3, SQ2500, R200, 3.0-Me
System 21: G2030 3.0, X-fi Fatal1ty, GTX 560, XP-Vista
Retro gaming (among other subjects): https://baronsfel001.wixsite.com/my-site
Reply 3 of 15, by DaveDDS
Looks interesting ... always been a "big fan" of emulators ... Any chance you could do a Win7 compatible build?
There are those of us who maintain (and use for offline "stuff") working systems not on the internet (which kinda
makes Win10 not really suitable)
I use a lot of Win64 stuff which works equally well on Win10 and Win7 - seems you kinda have to make effort to
eliminate Win7 (unless of course your devtools have made that effort for you)
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 4 of 15, by Dan9550
I'll have to try this out, its been a while since I've played Shufflepuck Cafe.
Reply 5 of 15, by Jo22
BaronSFel001 wrote on 2025-06-24, 20:26:
[..] but color Macs already offered enhancement over DOS PCs.
It's not widely known, but the original Quick Draw supported 8 colour mode.
The early Macs thus had same colour capabilities as Windows 1.x and 2.x PCs.
(EGA and VGA drivers did default to 8 colour palette, like Tandy 2000 graphics did.)
More information here:
https://lowendmac.com/2013/scuzzygraph-and-scuzzygraph-ii/
https://archive.org/details/TNM_ScuzzyGraph_d … t_20170827_0271
Reply 6 of 15, by twvd
DaveDDS wrote on 2025-06-25, 02:39:
I'd like to stick with the official stable and maintained tooling and the Rust toolchain supports Windows 10 as the earliest Windows release. Also GitHub doesn't provide any < Windows 10 runners so automating builds would be difficult.
Of course you can always try and see if the Windows 10+ build works on Windows 7, I don't think I use any (very) bleeding edge OS APIs and every dependency should be statically linked.
Reply 7 of 15, by BaronSFel001
Jo22 wrote on 2025-06-25, 07:48:
It's not widely known, but the original Quick Draw supported 8 colour mode. The early Macs thus had same colour capabilities as […]
Nice, I never knew that. That it required special hardware to exploit meant it was a very niche capability, thus I would be surprised if any games took advantage. Have the ScuzzyGraph devices ever been emulated, or are they too unknown/inaccessible for it?
Reply 8 of 15, by Jo22
BaronSFel001 wrote on 2025-06-25, 14:48:
Hi, I don't know. There's little information on the internet..
It's probably just an TMS34010 graphics processor with framebuffer on an SCSI bus.
The TMS34010 and 20 were programmable graphics chips, used in arcade games and the TIGA graphics standard on IBM PC.
- The driver software for System 6/7 would be interesting to have for further analysis.
Maybe it would also be possible to emulate a dumb 8 colour framebuffer and write some bit of code for it?
Software from late 80s can use it, according to the ScuzzyGraph ads.
Btw, there also had been commercial upgrades for Mac SE
that went much further than this, such as Micron Xceed Color Card.
https://www.youtube.com/watch?v=-2RJO51Uw-s
https://www.youtube.com/watch?v=ZsUVtx3pP8Y
Reply 9 of 15, by DaveDDS
twvd wrote on 2025-06-25, 14:14:
That was the first thing I tried (like I said, many things work)
(X) The application was unable to start correctly (0x0000005)
Click OK to close the application.
Not a big deal - I get it that everyone (else) wants every aspect of their
lives connected to the internet these days - I like to keep malware risk to
a minimum on the machines I actually use for personal/productive stuff...
(and yeah, I still do productive things on DOS and WinXP too!)
Reply 10 of 15, by emu34b
Gotta say, I'm all for this, since Mini vMac hasn't been updated in ages and is incredibly difficult to build from source.
For the Mac II specifically, one thing I might try is see if those applications which requisition memory from unused NuBus slots work. I can't think of the name off the top of my head and there's likely more than one program that does this.
Reply 11 of 15, by Jo22
emu34b wrote on 2025-06-29, 22:52:
Hey! I'm still using the original vMac here! The DOS port is neat to have! 😁
However, what I personally don’t like so much is that
Mini vMac emulates the serial ports with nothing attached.
It would be interesting to have an working serial connection, the actual baud rate is secondary.
For example, to get my PK-232 TNC running with the original 80s era Mac software.
The software has trouble with later Macs which don’t have internal serial ports available at the known hardware location.
(Well they sort of have one port, but it's occupied by on-board modem. Adapters are hard to find.)
So you can't use an USB-serial adapter here, even if Mac OS 8/9 itself can use it via available Mac drivers.
Reply 12 of 15, by emu34b
Jo22 wrote on 2025-07-01, 13:44:
Hey! I'm still using the original vMac here! The DOS port is neat to have! :D […]
vMac (and mini) are great. It's certainly the easiest to use vintage Mac emulator, in my opinion.
Still, I there's a github where it's just a big refactor of Mini vMac. It too hasn't been updated in a bit though. https://github.com/InvisibleUp/uvmac
Reply 13 of 15, by CRTARTBooks
I wrote about Snow in my latest newsletter.
I think it's amazing, mainly due to the fact that it allowed me to finally run a classic Mac on my PC without any fuss (and it even launched from a custom .vhd HDD image I had). When I tried to use Basilisk some years ago it was a rather painful experience and I gave up eventually.
Beyond Nostalgia - retro news & views presented in CRT-vision
CRT ART Books - retro gaming books with authentic CRT photos
Reply 14 of 15, by dhadner
Kudos on creating a truly high-fidelity Mac emulator that works well. The Rust source code is clean, clear, and without extraneous logic. Keep up the good work!
Reply 15 of 15, by Jo22
I'm looking forward to sound input in Mac emulators, eventually.
8-Bit mono for mic input would already be great for a start! ^^
So you could play with these old sound recorders again or try running old voice recognition software etc.
