How to Install Windows 98 on an IBM Aptiva 2168
First post, by yrz2001
Hello, at the beginning of this year, I bought an IBM Aptiva 2168 S65 in Japan. To install my new Voodoo graphics card, I need to reinstall the operating system, but I know nothing about old computer hardware and have no idea how to install Windows 98 on a CF card.When installing from a CD, do I need a floppy disk as a boot disk, or is there another method?
Reply 1 of 33, by yrz2001
This is the CF-to-IDE adapter card I'm using to replace the original 1700MB mechanical hard drive.
Reply 2 of 33, by yrz2001
To be honest, this IBM's BIOS is terrible – it can't even be set to boot from CD-ROM!
Reply 3 of 33, by chrismeyer6
Booting from a CD wasn't really a thing in the original pentium days. You'll need a simple boot floppy and then you can install 98 from its CD.
Reply 4 of 33, by yrz2001
chrismeyer6 wrote on 2025-06-25, 03:37:
Thanks! May I ask how to create a Windowsinstallation CD and a bootable floppy disk?
Reply 5 of 33, by myne
If you can get the drive in another machine, there are ways to make it dos bootable.
There's likely some modern tool to write a 98 boot sector even if it's just some random all-but-empty fat32 disk backup to be restored onto it.
Then you just copy the Win98 directory on, and after boot run setup.
If you can find one, it's easy enough to backup a vm and restore it to a real drive.
I built:
Reply 6 of 33, by theelf
yrz2001 wrote on 2025-06-25, 01:39:
Floppy are relics from the past! jeje
update and use some new technology, read the CF card in your PC using a USB reader, and format with HPUSBDisk.exe
The attachment HPUSBDisk.zip is no longer available
Download a win98 bootdisk, just decompress in a folder, and in HPUSBDisk select the option to create a booteable disk, and select the folder with the bootdisk, voila, you have a booteable CF disk
The copy win98 install folder, and install using setup, thats all
Reply 7 of 33, by dionb
Note that "2168" is the series indicator, basically telling you which case your Aptival has. That doesn't determine which hardware is inside it. Sometimes IBM used some pretty exotic stuff in there that might need specific drivers in Win98. My mother's 2168 (I don't recall which model exactly) had an OPTi Viper chipset, for example. I recommend checking what you have exactly and sorting out drivers before trying to install the OS, so that you're ready to feed it whatever drivers it asks for during the installation.
Reply 8 of 33, by yrz2001
dionb wrote on 2025-06-25, 08:25:
This is a photo of my motherboard.
Reply 9 of 33, by dionb
yrz2001 wrote on 2025-06-25, 08:46:
That image is missing most of the relevant parts of the motherboard, but it appears to be this one:
https://theretroweb.com/motherboards/s/univer … -scient-pro-57a
If so, you have a Trident TGUI9680 display adapter. You'll need drivers for that. I don't think specific Win98 drivers were ever made, but you can try the Win95 .VXD drivers: https://vogonsdrivers.com/getfile.php?fileid= … &menustate=22,1
The OPTi Viper-M chipset needs IDE HDC drivers if you want to enable DMA, but I've not been able to find any. Possbily they might be included in Win98, but more likely the IDE will show up as "standard IDE controller" and just work - slowly.
You don't show your sound card, but these systems would have originally been shipped with an IBM mWave sound/modem combo. Those are infamously tricky to get to work under Win95, but actually are fairly easy to get running under Win98 if you follow these instructions:
https://aptivasupport.com/win98/win98_and_mwave.html
Reply 10 of 33, by yrz2001
dionb wrote on 2025-06-25, 09:05:
That image is missing most of the relevant parts of the motherboard, but it appears to be this one: https://theretroweb.com/moth […]
Yes, actually I have an mWave sound card.
Reply 11 of 33, by yrz2001
theelf wrote on 2025-06-25, 05:59:
Floppy are relics from the past! jeje […]
According to your method, I just need to boot from the hard drive, right?
Reply 12 of 33, by theelf
yrz2001 wrote on 2025-06-25, 10:02:
Yes, no floopy, just boot and install from setup. Remember to do a config.sys with himem.sys
Reply 13 of 33, by yrz2001
theelf wrote on 2025-06-25, 12:15:
I'm sorry, I don't quite understand what "config.sys with himem.sys" means.
Reply 14 of 33, by yrz2001
I followed your method to create a bootable CF card, but now the computer looks like this when starting from the hard drive.
It first displays the characters 'I990301', then shows a floppy disk insertion animation, just like this.
Reply 15 of 33, by yrz2001
An interesting issue – the 8GB CF card is only recognized as 3.26GB. I'm not sure why this is happening
Reply 16 of 33, by yrz2001
Currently, there's nothing on this hard drive except the bootable disk. I modified the BIOS settings, and now it powers on but only displays the letter 'j' with a blinking cursor. Weird issue.
Reply 17 of 33, by Repo Man11
yrz2001 wrote on 2025-06-26, 03:28:
That's likely the hard drive size limit for the BIOS. To be sure, have you done a search to see if there is a BIOS update available for this board?
Reply 18 of 33, by yrz2001
Repo Man11 wrote on 2025-06-26, 04:17:
There probably are (updates), but I don't know how to download and update them
Reply 19 of 33, by myne
2gb fat partition.
Work around.
I built:
