First post, by DaveDDS
- Oldbie
Just in case anyone else in interested:
In recently helping a couple people figure out problems with floppy drives on
older systems, I took the time to do something I've been wanting to do for a
while, and make some boot disks to help diagnostics...
I've just put DBGBOOT.ZIP on my site, it contains DOS 5.0 boot disk images
in all common PC formats: 5.25" 360k, 5.25" 1.2m, 3.5" 720k and 3.5" 1.44m
These contain DOS itself, and:
XMSDSK[.EXE] "on the fly" RamDisk (make working space)UNP[.EXE] Self select/UNPacks common DOS utilitiesUNP DDS[.DDS] select/unpack some of my more useful toolsUNP IMD[.DDS] select/unpack ImageDisk (good to eval/test floppy)UNP PKT[.DDS] select/unpack dozens of network drivers
For 1.2 & 1.44 - all of the above in on the boot disk
720 - separate disk with PKT.DDS
360 - separate disks with DDS.DDS+IMD.DDS and PKT.DDS
Tools in my DBDOS package (also on my site) can be used to write the .IMG
images to real disks, and to write/read files to/from the images.
I'm interested in feedback, especially if there are other tools that might be
useful on the disks (keep in mind: These are small - I include capability to
move things on/off the booted DOS via serial, parallel or network to make
other "stuff" accessible)
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
