Slot1 mobo fsb help
First post, by PlaneVuki
Hi!
I have Siemens Nixdorf D1107 mobo
https://theretroweb.com/motherboards/s/siemen … tem-board-d1107
I want to run covington cpu at 100mhz fsb, but mobo seems to autodetect it and give 66mhz.
Am I missing a jumper/switch setting to set 100mhz fsb?
How can I set 100mhz fsb for covington?
Thnaks!
Reply 1 of 14, by PD2JK
Gotta work the DIP switches. Hope it works, FSB can't be selected through these. 🙁
See page 12:
https://theretroweb.com/motherboard/manual/ft … dc271854843.pdf
If you need more speed, you could find a CPU with L2 cache. Mendocino, Klamath, Deschutes, Katmai....
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 14, by PlaneVuki
I just want to run my Covington at 100mhz fsb.
Either using mobo settings or some pin hack.
Reply 3 of 14, by Horun
Appears there is no cpu clock jumper/switch, only multiplier switches. Does the BIOS have a bus speed setting ?
Reply 4 of 14, by sfryers
I've had success using a utility called SetFSB (https://www.majorgeeks.com/files/details/setfsb.html) on a 440BX motherboard without jumper or BIOS settings.
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 5 of 14, by Major Jackyl
Most of those CPUs that I've seen are only 66FSB, if I recall. I have two Celeron Slot1 CPUs and they both are 66Mhz. What is the CPU model (ex. SL27Z). Do you have 100Mhz memory installed? You may be trying to overclock, which might require some wizardry (and 100Mhz memory) to work.
This quip from the manual seems to know:
The attachment Screenshot 2025-06-27 182708.png is no longer available
Assuming this is the correct manual. It's always nice to see your actual board and setup, to make sure we're all looking at the correct board.
It'll be way easier to acquire a Pentium 2 or 3 100FSB than to try and force 100FSB. Kinda high-level overclocking. Like trying to overclock a coppermine. Not really do-able.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 7 of 14, by PlaneVuki
Solved!
Just taped pin B21 and whola.
Thanks!
Reply 8 of 14, by PD2JK
Great! 400 or 450 MHz?
Reply 9 of 14, by PlaneVuki
Was 300mhz, now is 450mhz.
Quake benchmark literally sped up by %50
Reply 10 of 14, by AlexZ
If you get a slotket with voltage settings and 100Mhz jumper you could use Mendocino at 100Mhz FSB. It should be much faster as it has L2 cache. You would need a couple of Mendocino 366 to be able to select one that runs at 550Mhz stable. It is the fastest CPU you can have on that board.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 ML-37@2.2Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 11 of 14, by H3nrik V!
PlaneVuki wrote on 2025-06-28, 09:16:
Makes sense, both cpu and fsb speed is increasing by 50% 😀
Good thing you found the B21 trick, I was gonna search for which pin to tape up, since it seemed to be the only way for that board ..
Reply 12 of 14, by H3nrik V!
AlexZ wrote on 2025-06-29, 11:59:
Well, 366 Slot1 Mendocino does exist, but yes, the 370 are much more plentiful ...
Oh the days, running dual 366@550 on an Abit BP6
Reply 13 of 14, by Disruptor
Pro:
Yes, Covington Celeron easily could be overclocked because it had no external cache.
Same with Mendocino Celeron. Its FSB overclocked resulting from 300 to 450 MHz, capable of SMP (multiprocessor) was the fastest x86 processor. At same clock even faster than the contemporary Deschutes Pentium 2 450 MHz because of its faster L2 cache.
But:
A Covington still remains a lame duck.
Reply 14 of 14, by H3nrik V!
Disruptor wrote on 2025-07-02, 14:42:
Pro: Yes, Covington Celeron easily could be overclocked because it had no external cache. Same with Mendocino Celeron. Its FSB o […]
Pro:
But:
For most purposes, yes the Mendocino will outperform the Deschutes at the same clock. But for some applications, using large datasets, the P2's slower, but 4x as big cache, pulls ahead. But that's pretty much more of a theoretical advantage in terms of retro games 😎
