First post, by bertrammatrix
After sporadically buying a few AMD 5x86 here and there over the last 2 years everytime I could get a decent price in hopes of eventually finding one that can run on a 60/66mhz fsb... I finally found one!
The cpu, an ADW, known to me as "#12" (but actually the 20th-something one I've tested)
The attachment 20250703_184658.jpg is no longer available
Other System specs:
Pcchips M919 v3.4 motherboard
Pancakepuppy's 1mb L2 cache module @ 2-1-2
128mb 60ns edo ram (Samsung tsop) @ 1/0 ws
Matrox G200 pci 16mb
Promise Ultra TX2 pci IDE
Ymf 719 based sound card
The system is fully windows stable at 180mhz with the CPU voltage at 3.7 volts and a large heatsink with a fan lightly blowing over it. 200mhz is possible at the same voltage with increased airflow, and I was able to play Worms Armageddon for a few hours without any issues, HOWEVER - during shut down the system would hang, no matter what I did. Not wanting windows registry issues I'll stick to 180mhz for "regular use" for reliability's sake (as reliable as a m919 running at these speeds gets anyway)
The attachment 20250701_113550.jpg is no longer available
The attachment 20250627_081254.jpg is no longer available
The attachment 20250627_081337.jpg is no longer available
Reply 1 of 41, by bertrammatrix
Some more numbers:
The attachment 20250627_074224.jpg is no longer available
The attachment 20250627_080843.jpg is no longer available
The attachment 20250627_074734.jpg is no longer available
Performance at 180mhz. Note, the FPU speed here is actually slightly lower then what my Cyrix at 2x60mhz scores in the same motherboard with enhancements enabled, however I have yet to find a game in which the AMD at 180 wouldn't feel faster. Obviously this is a bit of an apples to oranges comparison though as the cyrix needs much relaxed cache timings compared to the AMD.
The attachment 20250628_083333.jpg is no longer available
Reply 2 of 41, by pshipkov
Well, your 200mhz configuration is impressive. Best quake 1 score with 486 cpu so far.
Tell us more about it - bios version, ram chips (looks like samsung), post few more scores like Doom test.
Did you run any other more challenging benchmarks to verify stability?
retro bits and bytes | DOS media library
Reply 3 of 41, by red-ray
Well done, I wonder if my SIV utility correctly reports the CPU speed, please will you try it?
Ideally use SIV V5.82 Beta-05, do Menu->File->Save Local and post the save file.
Below you can see it's OK on my system, but I have never tested it with a 60/66 MHz FSB speed.
file.php?id=222780
I wonder why CPUZ reports the L1 cache size + technology for your CPU, but not for my CPU when that are basically the same CPU.
At x4 it repots the technology, but still no L1 cache size.
file.php?id=222782
I wonder if your system would be more stable a 4 x 50 MHz, have you tried it?
Reply 4 of 41, by bertrammatrix
pshipkov wrote on 2025-07-04, 05:55:
Thanks. I've been wanting in the club for some time now and working hard at it 😁
Didn't someone score around 25 with a 1:1 fsb/pci ratio? I could probably milk out an extra fps if I used one of my cards that can do that speed, however not that motivated since the G200 outperforms those under windows regardless of the benchmark score.
Bios version is stock for this board 05/06/1996. Extensive testing confirmed findings of others that all the other bioses available have a gap in the cacheable range between 56-64 mb, leading to lower performance, while not giving any other observable benefit. I tried a few award bioses of similar boards as well, but these all had other issues. Note, this bios also works flawlessly on a v1.5 board (that has a version with the memory gap from factory).
The edo ram has 5v tsop Samsung ic's - km44c16104bs-6. I tracked this down after some recomendations from Feipoa regarding Samsung tsop ram. I also have a 64mb 40ns (!!!) module with soj Samsung chips that performs flawlessly, however since there seemed no difference stability wise I obviously stuck with the 128. I also had great results with a 64mb module of Samsung tsop FPM - benchmark results were 1-2 us/mbps better with this and no instability was noted (I think one of my benchmark result photos is with this module). However, the FPM "felt " a tad slower in windows - not sure if EDO is playing a role here, or, if the FPM is at the edge of it's capabilities and I am getting cache misses or something that affects the performance.
Yeah I can post some more results.
So far, close to a week in, all seems stable, even leaving demanding windows games paused with winamp in the background etc all day has not triggered anything. I've messed with a few of these less successfully and usually causing lockups or errors isn't a problem
Reply 5 of 41, by H3nrik V!
Wonder if you could get by that shutting down issue by clocking down on the fly, just before closing Windows. My 486SOM's clock generator can switch frequency live, clocking up or down as needed. By red-ray's inspiration, I added switches rather than jumpers, to be able to switch as I please ..
The multiplier, though is read at reset, so that's not a live switch ...
Reply 6 of 41, by bertrammatrix
Here is a few more benches
Doom
The attachment 20250704_153051.jpg is no longer available
Pcplayer 320 and 640
The attachment 20250704_153246.jpg is no longer available
The attachment 20250704_153405.jpg is no longer available
Reply 7 of 41, by Disruptor
Did you do your test with the G200 or the Virge?
Reply 8 of 41, by The Serpent Rider
S3 Virge can't work stable at 60 MHz. At least I haven't encounter one that could.
Reply 9 of 41, by maxtherabbit
Very impressive results
Reply 10 of 41, by bertrammatrix
Disruptor wrote on 2025-07-05, 14:59:
Sharp eye. That round in particular was done with an S3 virge (with a 75mhz clock) and I believe FPM memory. I was wanting the virge in there as the g450 I usually use for dos tests (as it scores identically to my g200 which usually lives in a system/doesn'tserve as a test card) does not have windows 98 drivers that work on a 486.
The virge consistently scores about o.2 quake fps LESS then g200, while using FPM consistently scores about 0.2 more then using edo. SO, virge + FPM or g200 + edo yields an identical quake score. The virge obviously lacks heavily under windows compared to the g200
Reply 11 of 41, by bertrammatrix
The Serpent Rider wrote on 2025-07-05, 15:30:
I agree. I tested several and always had problems eventually. The ones with a lower clock rate did a little better but never reliable.
HOWEVER, I'm NOT running this one at 1:1 fsb/pci, so the pci is comfortably running at 30mhz. Honestly, I can't be bothered to hot switch it every boot to achieve a 1:1 pci at this speed (which is the only way to force it on a 919). I've had mixed results with running 60mhz pci on SiS and Ali boards - sometimes there is an extra fps to be had, sometimes not. I remember the Ali board in particular scoring over 100 in 3d bench with a sis6326 and a 2x60mhz cyrix which was very impressive, however the improvement to any other benchmark (or to the feel of games under windows) was very minimal
Reply 12 of 41, by pshipkov
Yes, thats evident by your Doom framerate. It is around 60, which if far below the 80 if you run at 1:1.
Basically, runtimes that can saturate the pci/vlb busses will suffer significantly.
Thanks for the additional details.
Linked you from a big thread related to this stuff.
Reply 13 of 41, by bertrammatrix
pshipkov wrote on 2025-07-06, 05:36:
Yes, thats evident by your Doom framerate. It is around 60, which if far below the 80 if you run at 1:1. Basically, runtimes tha […]
Oh really? I didn't realize it'd affect doom so much. What VGA?
I think I found my sis6326 to handle that pci speed best (as it's an agp chip, what a shame that it's so mediocre otherwise), followed by one of my slower virge's (was ok in dos but would artifact in windows). I remember noting that the slower virges would suddenly end up faster then the fast ones memory bandwidth wise, which seemingly must have automatically added wait states to cope with the bus speed (but were still unstable).
If the 919 had an easy way of forcing 1:1 permanently so I wouldn't have to fiddle with it every boot (could anyone edit the bios? The boards with this chipset that use Award instead of Amibios have it selectable) I would perhaps explore this more one day
Reply 14 of 41, by pshipkov
Yes, running the PCI bus with some divider will have a significant impact on such runtimes.
Assuming that a decent to good graphics card is used, the tight spot will be the bus.
In general, for DOS it is better to use VLB cards - the good ones are slightly faster than the good PCI cards.
For Windows, PCI cards (the good ones) are better than the VLB ones.
PCI - Matroxes, Voodoo3, etc
VLB - Ark1000, S3 Trio64, or the 96* variants.
Reply 15 of 41, by feipoa
How are you adhereing that oversized socket 370 heatsink to the socket 3?
180 MHz at 4.0 V was my setting max on the M919 with 2-1-2, 1/0 ws, 1024K, 128 MB EDO. As I recall it, 3.45 V was mostly stable except for some demanding Windows 95 software titles.
Windows 9x shutdown issues weren't uncommon even with non-overclocked systems. If at 200 MHz, you shut down by the option to "restart in MS-DOS mode", does the system still hang? Once in DOS mode, hit the power button. I try to shutdown on most of my Windows 95 systems like this.
bertrammatrix wrote on 2025-07-04, 03:30:
That's very common and I think it is why the Cyrix doesn't shine so much with overclocking compared to the AMD. However, there have recently been some very interesting tests at 150 MHz using a QFP Cyrix 5x86-120. Seems someone got it stable on an M918: Re: Cyrix 5x86 Register Enhancements Revealed I have 4 of these latest S1R3 QFP chips I [eventually] plan to try my luck with at 150 MHz. 3 units I still need to solder to PGA boards. They have the latest datecodes for S1R3 chips, meaning branch prediction should work in Windows, not just in DOS.
Some comparative results from the other thread, on an M918 w/cx5x86-150, 3-1-1-1, 1024K, 32M:
L1 = 309 MB/s ------> compared to 207 MB/s (Am5x86-200)
L2 = 105 MB/s ------> compared to 112 MB/s (Am5x86-200)
RAM (read) = 69 MB/s ------> compared to 62 MB/s (Am5x86-200)
Quake = 21.5 fps ------> compared to 23.4 fps (Am5x86-200)
However, if he is able to find a stable EDO/SRAM configuration to allow for 2-1-1-1, Quake jumpers to 22.6 fps. Still slower than the AMD at 200 MHz, but the Cyrix FPU should clobber the AMD's.
bertrammatrix wrote on 2025-07-06, 19:45:
I'm sure one day someone on the forum will be motivated enough to use a relay or switching transistor to do the 1:1/2 to 1:1 PCI switch automatically, perhaps using an Arduino. It's an idea I pitched in around 2012, but no biters yet. From my experience with the M919 PCI switch, it is best to do just after boot at an idle DOS prompt.
pshipkov wrote on 2025-07-07, 16:09:
Yes, running the PCI bus with some divider will have a significant impact on such runtimes. Assuming that a decent to good graph […]
Switching to PCI at 60 MHz will also allow for a whole new round of tweaking, depending on the entirety of expansion cards you are wanting to use in the system. Seems that I ran into all sorts of issues with this on socket 3 boards.
Reply 16 of 41, by bertrammatrix
feipoa wrote on 2025-07-12, 11:00:
How are you adhereing that oversized socket 370 heatsink to the socket 3? […]
A tiny dab of JBweld epoxy on the corners and an appropriate amount of heatsink compound in the middle. Have it in a motherboard and give it a good squeeze/jiggle to make it seat as well as possible, then let it set.
I've never had one I've done like this come off, this is the biggest heatsink I've used but I think it will be ok.
Would it be a hassle to get off? Possibly, but probably no worse then a factory glued heatsink
Reply 17 of 41, by Chadti99
Completely missed this thread, congrats on the Quake score, wasn’t sure we’d see 23+ fps on a 486, nice work!
Do we have the bios and jumper settings documented for the 23.4 fps Quake score?
Fastest dram and cache settings and I’m assuming 1:1 pci at 66x3? Screenshots of bios settings would be awesome.
Reply 18 of 41, by analog_programmer
But, but... PCChips M919... "PCChips = cr*p" 🤣 Actually pretty nice system and impressive results 😀
Is the passive cooler simply placed on top of the CPU or there is some kind of retention?
the rules... what rules? m$-dos 6.22 "DISK 1" is now freeware, enjoy!
Reply 19 of 41, by Chadti99
🤣, the m919 board I have was a total pain to work with, kept losing its bios settings on top of other issues. Tempted to pull it back out or find another example. And I agree with OP on forcing the 1:1 after each boot being a pain.
I’m also worried to move my 200Mhz capable 5x86 around too much in fears of killing it from ESD or otherwise.
