First post, by theshinyknight
I want to put some games on my Libretto 50CT, but that laptop has just a pentium 75 and no way to use a CD, unless I use a parallel CD enclosure (which I have not seen around for like 20 years?).
I looked at running daemon tools in W95 but most games didn't work. The only way I found to make it work is using tools to mount virtual CD directly in DOS but beside the work needed to make a ISO image, you also don't get audio tracks most of the time. Is there any other easy method to get these games to play on old machines, beside use cracks? I wish there was just a way to dump the entire content of the CD and have it work with DOS, without have to mount/unmount virtual drives, which is already adding a toll on a machine that is weak as is
