First post, by stanwebber
i'm stymied. this is a fresh install of win2k (no service packs). i just got done installing win95 & nt4 on the same machine to separate, identical cf cards (ide > cf adapter) with absolutely no problems using pcmcia to both sd & cf card readers. win2k recognizes the pcmcia sd reader, initializes the pcmcia ata controller device, but no disk drive is detected. the pcmcia cf reader has no issues.
i've tried swapping sd cards & pcmcia slots, switching drivers from pcmcia to standard ata controllers and uninstalling every device connected to the pcmcia bus to let win2k re-detect & re-install the drivers. nothing works (except when i switch back to win95 or nt4).
the kicker is i have another laptop with win2k (no service packs) installed and the pcmcia sd reader works just fine! the significant difference is a 32bit cardbus instead of a 16bit pcmcia bus, but still.
this is a deal breaker for win2k. what else can i try to resolve this?
