First post, by hax0rwax0r
I have a Mediavision Pro AudioStudio 16 / XL sound card (650-0060-53-B) that I installed in a computer that is running Windows NT 4.0 Workstation SP6a and I am trying to get it to work. I found drivers for the card on this site, but it seems that they are only be for MS-DOS and Windows 3.x and don't contain Windows NT drivers as far as I can tell.
I was able to install Windows NT 4.0 Workstation via the external SCSI CD-ROM attached to the sound card's SCSI controller by creating a custom boot floppy containing the SCSI driver for MS-DOS 6.22 and running "winnt /b" to install it. That was my workaround as, well, I couldn't find supplemental drivers to load the sound card's SCSI controller to install from the CD-ROM while using Windows NT 4.0's boot disks.
I have found references online that this card SHOULD support Windows NT 4.0 Workstation but I've never found drivers for it.
For what it's worth, it seems Windows NT 4.0 has built-in driver support for "Media Vision ProAudio Spectrum 16" and "Media Vision Thunder Board" but neither are for the Studio version that I have. To that point, I tried to install the ProAudio Spectrum 16 that was in the list and it wanted my Windows NT CD to copy additional files from which, again, doesn't work as the SCSI controller on the sound card isn't initialized / configured in Windows yet. I can likely work around this by booting up with my custom MS-DOS boot floppy and copying the CD contents over to another FAT16 drive partition and loading it from there, but I am not even confident that it will work as it's a Spectrum vs. Studio or that it will include all the components necessary to make the SCSI controller work.
Does anyone know of drivers for this card on Windows NT 4.0 or how to make it work? And by work, I also mean the SCSI portion of the card so I can use my CD-ROM drive.
Thanks.
Reply 1 of 6, by Grem Five
So far all I have found is this: https://web.archive.org/web/19971007071432fw_ … t/NT4.0FAQ.html
Not super helpful, there is a FAQ for setting up under Win95 but not the same as NT I believe. https://web.archive.org/web/19971007071416/ht … rt/win95faq.htm
I have 2 Prostudio cards but never tried them under NT4.
Reply 2 of 6, by hax0rwax0r
Grem Five wrote on 2025-07-16, 18:28:
I use archive.org for all kinds of retro computer related things that are long since broken and offline and I have no idea why it never occurred to me to try and search the Media Vision website from the 90s to find this article. Regardless, thank you for the reference. This was information I needed to get the SCSI card working.
In case something happens to the archive.org link before anyone in the future needs that information, the steps I took to get the SCSI controller working are:
On a separate computer, format a floppy disk and copy the entire contents from "drvlib\storage\retired\x86\" folder on the Windows NT 4.0 Workstation CD to the root of the formatted floppy disk.
Back on the Windows NT 4.0 Workstation machine, open Control Panel -> SCSI Adapters -> Drivers tab -> Add button -> Have Disk button -> A:\
From there, select the "Trantor MediaVision" SCSI adapter. After it finishes installing the drivers, it asks to reboot the computer. Upon reboot and logging back in, my external SCSI CD-ROM immediately showed up and the SCSI controller was functional.
As for the sound card, now that I had a functional CD-ROM connected to my Windows NT 4.0 Workstation machine, I was able to go into Control Panel -> Multimedia -> Devices tab -> Add button
From there, select the "Media Vision ProAudio Spectrum 16" option and hit the OK button. It will ask you for where it can find the "mvaudio.dll" file to which I pointed it at my Windows NT 4.0 Workstation CD path "E:\i386\" (obviously your CD-ROM drive letter will vary). Same as with the SCSI controller, upon reboot and logging back in, I heard the Windows NT Logon Sound wave file play, something I hadn't probably heard in at least 20 years.
Again, thanks so much for saving my sanity and time on this one.
Reply 3 of 6, by Grem Five
hax0rwax0r wrote on 2025-07-16, 23:38:
No problem, out of curiosity what type of computer is this on?
Reply 4 of 6, by hax0rwax0r
Grem Five wrote on 2025-07-17, 01:19:
I am running it in a NEC Ready 425 that was upgraded with an Intel 486 DX2 66MHz OverDrive. I have a few industrial CF cards I'm swapping out as the storage drive so I can play around with various OSes. Windows NT 4.0 might be a bit ambitious for a 66 MHz 486 CPU, especially with only 20 MB RAM (64 MB on order from eBay), but it's just a time and money sink to spend my evenings tinkering.
The computer itself is an eBay find that was the same make and model as our first family computer from back in 1992 so it had some nostalgia tied to it, though, our original one only had the stock 486 SX 25 MHz, 4 MB RAM, no sound card and no CD-ROM back then. I remember I got a sound card and CD-ROM bundle kit from Creative for my birthday in 1994 and had to return it because the case's 5.25" floppy bay was only what they call a 1/3 height drive bay and wouldn't accept the CD-ROM.
Reply 5 of 6, by Grem Five
I had to google NEC Ready 425 info.. looks like a nice machine.
Reply 6 of 6, by maxtherabbit
I have a dx2-66 running nt4. It's not bad at all
