First post, by Maz Hoot
Hello, I had some scaling problems on AT2 on toshiba 430CDT. This is what I get with vexp M2 T (second image) and this is what I get without vexp (first image). On AT2.ini there is these options :
screen_mode=0         ; program screen mode:
; [0] classic view (90x40 @ 720x480) (recommended)
; [1] extended view (120x50 @ 800x600) [SVGA][*]
; [2] wide extended view (180x60 @ 1024x768) [SVGA][*]
; [3] compatibility text-mode (...)
; [4] fullscreen (90x38 @ 800x600) [SVGA]
; [5] extended fullscreen (120x47 @ 1024x768) [SVGA]
comp_text_mode=0 ; compatibility text-mode:
; [0] 80x30
; [1] 80x25
; [2] 90x30 (default) Ä¿
; [3] 90x47 Ã VESA text-mode emulation
; [4] 120x47 ÄÙ
fps_down_factor=0 ; CPU saving factor for realtime gfx presentation
; and VESA text-mode emulation:
; [0] none
; [1-10] slowdown factor (1=least, 10=most)
// peripherals
typematic_rate=0 ; typematic rate [0] 30 chars/sec ... [31] 2 chars/sec
typematic_delay=0 ; typematic delay [0] 250 ms ... [3] 1s
mouse_hspeed=50 ; horizontal speed in mickeys/pixel
mouse_vspeed=50 ; vertical speed in mickeys/pixel
mouse_threshold=0 ; speed-doubling threshold in mickeys/second
mouse_disabled=off ; disable screen scrolling by mouse
// ** Custom SVGA text-mode configuration **
custom_svga_mode=off ; custom SVGA text-mode (only use this mode
; if you know what you are doing)
svga_txt_columns=100 ; columns (80..180)
svga_txt_rows=37 ; rows (25..60)
// CRTC register values (hex) (00-FF)
crtc_misc_out=6b ; Miscellaneous output
crtc_h_total=70 ; Horizontal total
crtc_h_disp_en_end=63 ; Horizontal display enable end
crtc_h_blank_start=64 ; Horizontal blank start
crtc_h_blank_end=82 ; Horizontal blank end
crtc_h_ret_start=65 ; Horizontal retrace start
crtc_h_ret_end=82 ; Horizontal retrace end
crtc_v_total=70 ; Vertical total
crtc_overflow_reg=f0 ; Overflow register
crtc_preset_r_scan=00 ; Preset row scan
crtc_max_scan_h=4f ; Maximum scan line/char height
crtc_v_ret_start=5b ; Vertical retrace start
crtc_v_ret_end=8c ; Vertical retrace end
crtc_v_disp_en_end=4f ; Vertical display enable end
crtc_offs_width=3c ; Offset/logical width
crtc_underline_loc=00 ; Underline location
crtc_v_blank_start=58 ; Vertical blank start
crtc_v_blank_end=70 ; Vertical blank end
crtc_mode_ctrl=a3 ; Mode control
…Show last 11 lines
crtc_clock_m_reg=01   ; Clock mode register
crtc_char_gen_sel=00 ; Character generator select
crtc_memory_m_reg=00 ; Memory mode register
crtc_mode_reg=10 ; Mode register
crtc_misc_reg=0e ; Miscellaneous register
crtc_mode_control=02 ; Mode control
crtc_screen_b_clr=00 ; Screen border color
crtc_colr_plane_en=0f ; Color plane enable
crtc_h_panning=00 ; Horizontal panning
crtc_color_select=00 ; Color select
I tried several screen mode but only the first one and 3 works, other give me a black screen. In the 3rd mode (comp text mode) only 0 and 1 works but it’s really dirty… I tried custom SVGA mode with several configurations, but it’s like the screen mode=0 config, nothing change, I also tried to change crt register values, and text column and rows but nothing change…
My music (chiptune, post-punk, world, industrial) : https://mazhootmusic.bandcamp.com
