First post, by old school gamer man
Hay everyone, Need some help here. I have a x79 gaming pc running xp with a titian x GPU. When I try to run dx5 and older games in hardware 3d I get garbled output.
It looked just like the image in this post Re: Jedi Knight: Dark Forces II - 3D acceleration in XP? but far worse. I tired every fix under the sun but nothing worked.
I read in a few places that its a NVIDIA driver bug found in newer drivers but with a titian x I can't roll back that far. the problem is that I can't just pick up any card as I play a few newish games like skyrim and mount and blade. I was thinking of dropping down to a 3gb GTX 580 but IDK if that's old enough.
Would anyone have any advice here ? any work around I don't know of or what older cards would work ?
Reply 1 of 19, by myne
In theory you could inf mod whatever the oldest driver is for any of these cards.
https://www.techpowerup.com/gpu-specs/?archit … sort=generation
Presumably the 980 was released first, so in theory you could inf mod whatever drivers it had on release.
I built:
Reply 2 of 19, by old school gamer man
myne wrote on 2025-07-22, 13:31:
You have to use the 960 drivers for XP, the oldest version on NVIDIAs site is 353.62 from 2015 and it did not fix the bug. From what I did find some others said the anything newer than version 266 would not work on some dx5 and older games but I not found anything concrete on that. I'd hate to go buy a 580 or something older only to find out it did not fix the bug.
I also recall having the same bug on a 780 ti a few years ago.
Reply 3 of 19, by myne
Dx5 is old enough that it might be helped by dxwnd or dgvoodoo.
Worth a try.
I built:
Reply 4 of 19, by old school gamer man
myne wrote on 2025-07-22, 14:06:
Worth a try.
I tried both, dgvoodoo2 does not work in xp and dxwnd did not work ether. I also tried a bunch of different versions of ddraw.dll, some wine render thing and so many other things.
Reply 5 of 19, by old school gamer man
screw it, bought a pair 3gb of 580s with blocks and a 3rd one with a air cooler. I'll test the air card and see if it works and if not I'll send the cards back or sell them or something. Hopefully I don't have to go back further as I know the 2gb gtx 285 is not fast enough for me, the 4890 is borderline fast enough but I still need more vram and a 2gb one is hard as hell to find, the gtx 480 would be pushing it on vram for the newer gameas I play.
Reply 6 of 19, by BinaryDemon
Back in the day, everything after Nvidia’s 7000 series seemed to revert to software dithering for Jedi Knight Dark Forces 2. So even 8800GT’s would have an issue.
For a while 7950GT/7800GTX were the best JK2 cards. I can’t remember to the extent AMD cards experience this.
Reply 7 of 19, by old school gamer man
BinaryDemon wrote on 2025-07-22, 17:07:
say it isn't so. I could never go back that far for a GPU, TBH it would not be so bad if I could get these older DX games to run in 1600x1200. software mode is not that bad in high res, darkforces 2 crashes in 1600x1200 and most other games do not support that high. I'm going to give wined3d a try. I tried other wine/opengl wrappers but not that one.
Reply 8 of 19, by Joseph_Joestar
An easy way to deal with older DirectX titles when using a GPU from the mid 2010s is to dual boot WinXP with either Win7 or Win10.
That way, you can use dgVoodoo2 and similar wrappers for any problematic games.
Reply 9 of 19, by old school gamer man
Joseph_Joestar wrote on 2025-07-22, 17:54:
yeah no. that's annoying and I'm trying to move away from dual booting
Reply 10 of 19, by The Serpent Rider
I can't recommend playing any DX5 game or DX6 games without 32-bit color awareness on GeForce GTX 580 natively. Modern* Nvidia and AMD GPUs do not have dithering for 16-bit color and games have terrible banding. This includes Dark Forces II. But at least they can be mostly launched on GTX 580.
*GeForce 8800+/AMD Radeon HD 2900+
Reply 11 of 19, by old school gamer man
Found a dx5 to dx9 wrapper that works on xp that fixed the issue with DX5 games, now to find a fix for older dx games 🤣. granted most older dx3 games don't have hardware 3d sooo not a big deal
Reply 12 of 19, by DoZator
old school gamer man wrote on 2025-07-23, 17:26:
Enter its name (Or a link to the description) - this may help others (who are facing the same difficulties).
Reply 13 of 19, by old school gamer man
DoZator wrote on 2025-07-24, 03:28:
sorry but this site doesn't support abandon ware
Reply 14 of 19, by DoZator
old school gamer man wrote on 2025-07-24, 12:20:
It is not forbidden to specify the name of the program (without links). Users will find it themselves.
Could you please write about this in a private message? Thank you.
Reply 15 of 19, by old school gamer man
DoZator wrote on 2025-07-24, 14:06:
the software was commercial and isn't sold anymore. you'd have to pirate it so no i'm not bringing it up as the rules here forbid supporting abandoneware
Reply 16 of 19, by DoZator
old school gamer man wrote on 2025-07-24, 17:37:
You're mistaken. If a program is no longer sold, it can usually be legally purchased from a third-party provider, as long as you comply with the terms of the license agreement. This is how I acquired boxed (packaged) versions of Windows and other outdated software that is no longer sold. However, in this case, there was no mention of distribution. You were only asked to provide the product name, and nothing more (to ensure that we understand the context). If we follow your logic, we should not mention outdated versions of Windows that are no longer sold. Isn't it?
Reply 17 of 19, by old school gamer man
the software wasn't sold retail... this site doesn't support abandoneware. if you have a problem with that go bitch to the people that run this site and not me.
Reply 18 of 19, by DoZator
old school gamer man wrote on 2025-07-24, 17:54:
Once again, mentioning the name of a software solution is not a violation here! Period.
Reply 19 of 19, by the3dfxdude
Not mentioning the software you used to solve your problem prevents anyone from using the same solution when they could actually have a way to acquiring the commercial software legally or already have said software. Furthermore if you identify the program, someone could recognize what it does and also identify a free alternative or help review and implement a free alternative. None of that is supporting piracy.
