First post, by gaffa2002
Hi again everyone.
Lately I'm having a bit more time to get back playing with retro hardware and I'm planning on putting my classic PC back in action. Thing is, at the moment I only have an older ATX PSU which works, but I'm not sure if it's safe to continue using it or not. That's why I want to replace it by something (hopefully) new.
As far as I know, some older hardware have problems with new ATX PSUs due to lack of -5v rail, amongst other things. Does anyone know how can I check that in my specific setup?
Basically I'm searching for a PSU replacement to an EP-7KXA motherboard, it does have an Athlon 750mhz CPU (Slot A) and also a Sound Blaster AWE64 card connected into its only ISA slot, the AGP slot has an Nvidia Geforce 4 MX440 card. May I just purchase any modern ATX PSU and get adapters for the different connections or better not?
Thanks in advance.
LO-RES, HI-FUN
Reply 1 of 5, by dominusprog
Some older Sound Blaster cards need the -5V for amplifier circuit I believe. You can check for yourself to see if your AWE64 card have the pad for -5V contact.
The attachment ISA_Bus_pins.png is no longer available
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 5, by gaffa2002
dominusprog wrote on 2025-07-23, 19:02:
Thanks for the response, it seems my sound card does not have the pad for -5V. Does that mean I can use any modern ATX PSU? Or there are other things to consider?
LO-RES, HI-FUN
Reply 3 of 5, by dominusprog
gaffa2002 wrote on 2025-07-23, 19:35:
No, go ahead and install your PSU 🙂.
Reply 4 of 5, by randi
I run a 1980s IBM 5160 off a ATX, it works fine .
I think modern ATX PSUs dropped the −12 V negative supply, but thats only important for certain legacy RS-232 serial port applications.
Reply 5 of 5, by gaffa2002
dominusprog wrote on 2025-07-23, 19:45:
randi wrote on 2025-07-23, 19:49:
Nice! Thanks guys!
LO-RES, HI-FUN
