First post, by RetroPCCupboard
I have been running PhilsComputerLab 136 in 1 Benchmarks on my Psuedo 386 PC build to compare a Cirrus Logic ISA video card to a Trident one.
The Trident is definitely slower, but both of them can go slower than a 25MHz 386 and both can go faster than a 33Mhz 486. (Depending on what features are disabled).
Not sure which of them to pick right now. As neither is able to hit the 3DBench2 scores that correlate to the given 386 examples. Depending on CPU features enabled they are either faster or slower.
I guess I can try increasing CPU speed but my thinking for clocking as slow as possible is that the various CPU features we are disabling are causing it to slow down by making it slower to fetch instructions and data, and to write the results to RAM. But the execution of the instructions, when it has them, will be running at far faster speeds than a 386 can do. So I am thinking that may result in unexpected spurts of speed or stuttering.
Also I am not sure what the "perfect" benchmark is for WC1 as Phil just said somewhere between 25mhz and 33mhz 386 which would be between 10.8 and 13.9. But in the video he said the 9.8 score he got was perfect for wing commander and the 11.2 score is more for WC2.
My host system has Pentium MMX running at 100Mhz, 8mb EDO RAM. Sound card is Soundblaster Pro 2.0.
I want to play Wing Commander 1 + 2. Various Lucusarts and Sierra point amd click games. Platform games like Commander Keen, Jill of the Jungle, Prince of Persia 1+2. Original SimCity, Sid Meyer Pirates, Civ 1, Railway Tycoon 1.
I am sure many of you have built a similar machine. What kind or scores were you shooting for if playing WC1? Did you use a PCI or ISA video card? What model graphics card did you use?
Reply 1 of 9, by Joseph_Joestar
RetroPCCupboard wrote on 2025-07-24, 21:17:
I was able to reach 386 speeds with a PCI Matrox Millennium II. You can see some of my tests here, and my slowest result here.
From my experience, if your motherboard can downclock a Pentium MMX CPU to either 133 MHz (2x66) or just 100 MHz (2x50) with both L1 and L2 caches disabled, you should be able to reach slow 386 speeds without any trouble. If necessary, you can stack the SetMul BPD and VPD parameters on top of that for some extra slowdown. Additionally, loosening the memory timings in the BIOS might make the system even slower.
My retro stuff
Reply 2 of 9, by RetroPCCupboard
Joseph_Joestar wrote on 2025-07-24, 21:34:
Thanks for the reply. Your findings are interesting. I haven't tried any games yet. I do have a Matrox Mystique 220, which I guess will be similar to your millennium II. I haven't used it in any builds due to reported DOS incompatabilities. So interesting to see that those issues only happen at certain speeds.
Basically what I am trying to do is cover thr 386-486 ranges with two machines. I have the 100Mhz system I already described, and also a 300Mhz Pentium MMX system. My thinking is that I want to avoid the need to reboot to change speed. Which means I don't want to manipulate the L2 cache (which can only be done through BIOS).
So I have benchmarked my existing 300Mhz system with L2 cache enabled using the PhilsComputerlab 136in1 project sheet. And I am comparing that to various configurations of Pseudo 386 that I am experimenting with. L2 cache is disabled on this machine. For reference, these are scores expected for some reference systems:
386-25 = 10.8
386-33 = 13.9
386-40 = 16.0
486-25 = 20.9
486-33 = 28.0
486-66 = 46.2
486-100 = 70.1
486-133 = 79.9
This is my results:
The attachment Data.jpg is no longer available
And as a line chart:
The attachment Systems Graph.jpg is no longer available
Zoomed in to the 486-66 and below:
The attachment Systems Graph Zoomed (2).jpg is no longer available
So, based on these results, I can see that EDO vs SDRAM makes a slight difference, but not much. Negligable once down to 386 speeds.
Video card makes a larger difference. The Cirrus is about 25% faster than the Trident at full system speed (equivilent to about 486-33mhz) but when you get down to 386 speeds, its less.
With these bemchmark results I am thinking the psuedo 386 will use Trident CPU and 8mb EDO. This will lead to the following performance characteristics for the two machines:
The attachment psudo machines.jpg is no longer available
Neither system will cover the 486-100 and 486-133 range, and not sure it that is a problem. The pseudo 386 looks like it will be able to drop to the speed of a fast 286 with this configuration. It can get close to 25mhz and 33mhz 386, but not 40mhz.
Reply 3 of 9, by AlexZ
If you need this capability then it's probably best to just use 86Box. I found my PIII 900 to be too slow with caches disabled. Slowing down to 486-66 is probably best as 386-33 is too slow.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 4 of 9, by SScorpio
There's no getting around toggling the L2 cache on/off in the BIOS. If you need slow 386 boards just don't support changing that at runtime.
Depending on your motherboard and case. If you have a turbo button. It might be possible to have that change a single CPU multiplier jumper. But again you'll need to reboot. Slow 386 ran DOS, it's not trying to boot into a full Windows environment which will just take forever.
486-100 and 133 aren't a thing that games ever targeted, 486 33 and 66 are what you need for that era, then you jump to slow Pentiums. If you want to do benchmarking of games with different configurations and seeing how things actual run, then you need real hardware. Having a single system that hits the different performance levels is to allow you to run games that have a variety of speed requirements on a single system.
Reply 5 of 9, by RetroPCCupboard
SScorpio wrote on 2025-07-25, 15:26:
Yes, that is why I am building two systems. One with cache on, and one with cache off.
The one with L2 cache enabled will be used to target games from slow 486 up to fast Pentium MMX. The one with L2 cache disabled will target slow 386 to slow 486.
Yes, which is why I want two machines. One primarily a fast Pentium MMX running Win95, but can be slowed to 486 speeds whilst in DOS mode without needing reboot. The other will have DOS 6.22 and probably Windows 3.11, and is just for DOS or early pre-9x Windows games.
Reply 6 of 9, by RetroPCCupboard
AlexZ wrote on 2025-07-25, 15:07:
With Pentium II and III, that's correct. Pentium MMX is more flexible in terms of granularity of slowdown. 386-33 is too fast for Wing Commander 1
Reply 7 of 9, by b0by007
Slowing down a system depends a lot of the memory type, FPM or EDO, and 60 or 70 nanosecs, video card type: ISA, PCI, AGP
I tried slowing down few retropc for playing Test Drive 3: The Passion.
For a Pentium 100 with ISA Trident TVGA9000, I reached 6.6 score in 3d Bench:
https://youtu.be/JRvI4yQMh-U?feature=shared&t=713
And for a Pentium II 266 I reached 4.9 score. Very interesting about this one, an IBM PC 300GL, with AGP integrated video card. AGP is linked directed to the CPU, so it will slow down more then with an ISA or PCI card:
https://youtu.be/F4_zILdYxAA?feature=shared&t=3117
HP Vectra D2753A 486/25N i486 SX 25mhz
UNISYS SG3500 AMD486 DX2 66mhz
OLIVETTI M4 i486 SX2 50mhz
IBM PC 330 6577-79T, Pentium 166mhz
IBM PC 300GL 6561-350, Pentium II MMX 266mhz
My retro youtube channel!
Reply 8 of 9, by RetroPCCupboard
b0by007 wrote on 2025-07-25, 20:05:
Slowing down a system depends a lot of the memory type, FPM or EDO, and 60 or 70 nanosecs, video card type: ISA, PCI, AGP I trie […]
Yes, true, memory timings can make a difference. I am running mine at 70ns. ISA vs PCI seemed a huge difference at higher speeds but less so when you bog the CPU down by disabling caches etc. My Pentium MMX 300Mhz system is running an AGP card.
I find it interesting how different CPUs respond to disabling their cache. Results can be wildly different. I find it very surprising that a PII or PIII is slower than a Pentium MMX when caches are disabled. But the results don't lie.
Reply 9 of 9, by myne
Architectures always trade efficiencies.
The p2 has a longer pipeline, so a cache miss costs more clock cycles.
Since you're disabling the cache, every read is a cache miss.
Memory also often trades latency for bandwidth.
The p2 uses 64bit memory, and Iirc it sends more than requested - to fill the cache pre-emptively, which is disabled. So it's sending a lot of extra junk that has to be sorted though and that probably has a cost too. Imagine sending a full shipping container with only one parcel you want.
So you're requesting 8 bits, getting... I think 4x64, and dumping most of it.
I built:
