Socketing a soldered DS12887A chip
First post, by multiplebaboons
I have the infamous dead DS12887A chip soldered to the board and I'd like to get it desoldered, modded with a battery, and then socketed. I've read people complain about fitting these chips into sockets, so I'd like to minimize the amount of trial and error here. Here's my first question. I assume that something like this should work. The dimensions and pin pitch seem to be correct. Or will it also fit a flat-pin socket like this? I have not used a soldering iron in 20 years, so any and all comments/suggestions will be welcome. Thanks!
Reply 1 of 64, by zyga64
Flat-pin sockets are better because Dallas chips have flat pins. That's (not only) my opinion.
However, Dallas replacements such as the nwx287 from Scorp (Necroware) use round pins.
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 64, by multiplebaboons
Well, this begs another question. Let's say I get the flat pin socket and my battery mod fails. Will that round pin replacement fit in the socket?
Reply 3 of 64, by zyga64
Yes, and vice versa. But the best contact will be when they are matched.
Reply 4 of 64, by multiplebaboons
Thanks, I will order the flat pin one then.
Reply 5 of 64, by nickles rust
If you are out of practice with your soldering skills, I would suggest doing the battery mod with the chip in place. Then if that goes wrong somehow, you could try soldering.
Reply 6 of 64, by multiplebaboons
nickles rust wrote on 2025-07-25, 13:17:
Given its location, feels like a doomed mission...
Reply 7 of 64, by nickles rust
Going from memory, it looks like they left you room on the side with the battery pins. There are pictures and videos about doing this. A few minutes with a dremel and soldering iron, done. Also, if you warm up the lid a bit the plastic cover and potting compound come off pretty easy.
At least I think this would be easier than un-soldering the chip. Good luck!
Reply 8 of 64, by multiplebaboons
Well, here is an example, and the guy miraculously has a ton of room where I have the ISA slot: https://www.youtube.com/watch?v=QOoOZzg3M6A
This looks absolutely brutal to me. You think this is easier/safer than going in with a wick on the other side?
Reply 9 of 64, by multiplebaboons
Well, what I initially thought was going somewhat OK seems like a disaster... And the chip won't budge. I am done here and off to ebay for a new motherboard, right?
Reply 10 of 64, by Aui
Why is it a disaster? I think you are almost done. At this stage I usually cut a thin solderwick to a pointy tip and soak it in flux. Then put the wick into the hole beside the legs. This helps to clean up the job. Even if one or two legs are still soldered in the chip wont move. Patience is key here.
Another thing to try at this stage is to take some tweezers and gently wiggle the individual legs. You will probably see that some are already loose and some still fix.
Reply 11 of 64, by multiplebaboons
Aui wrote on 2025-07-30, 03:45:
Bottom row, 4th from the left, I think I broke a trace there despite being as careful as I could... Let me actually try your suggestions just to see how much damage I've done.
Reply 12 of 64, by mkarcher
And if you found fixed pins, there are two ways you can approach it, and you should be aware of both. First, you can re-heat the pin with the iron until it can be wiggled, and then you keep wiggling it while it cools down. This will effectively prevent the pin to get re-soldered while cooling down. Secondly, even if there is no solder at the solder side any more, some solder may be still be in the hole near the other side of the board. Re-solder the pin with fresh solder, than heat it for 5 to 10 seconds with the iron before removing the solder again. The idea is that fresh solder with flux flows better, and performing this procedure mixes the old residual solder with flux-rich new solder, and allows the wicking action to reach the remaining solder.
I recommend trying these two approaches in order. If wiggling during cooldown loosens the pin, it's fine. If not, reflowing and re-wicking is likely going to help, but it obviously is more difficult.
While it will look ugly, you can certainly fix the possibly broken trace with a bodge wire.
Reply 13 of 64, by multiplebaboons
I think the most problematic one is that 4th bottom pin from the left. I actually think all of them are loose except that one -- and it is not trapped due to being soldered. It doesn't seem to move when hot, feels seized in the bent pad.
Reply 14 of 64, by multiplebaboons
This is the current state of affairs, not much movement from the chip. I actually reflowed and rewicked that pin, followed by some solder pump, but I don't think it's any better.
Reply 15 of 64, by zyga64
Using a hot air station or even a heat gun could help here.
PCB is multi-layered and contains large areas of ground and power that act as heat sinks.
Reply 16 of 64, by konc
If it's only that specific pin and you have any patience left, don't focus on it any more. Make sure all others are free and can move, then as the last step heat the stubborn pin while pulling the chip out. You'll be left with a blocked hole, but it's much easier to clean without the chip in place.
Reply 17 of 64, by multiplebaboons
zyga64 wrote on 2025-07-30, 08:07:
I figured as much, but I don't own a heat gun and I think at this point I'd like to limit the investment into things I will be unlikely to use ever again...
Reply 18 of 64, by multiplebaboons
konc wrote on 2025-07-30, 08:26:
I tried exactly this, but sadly I think the top leftmost one is also stuck, just not as badly. Every other pin is able to move, I'm not really sure this is a great indicator of the pin ready to actually come out... I think it only is when you definitely know what you're doing, which may not be my case. 😀
Reply 19 of 64, by shevalier
Sorry for butting in. WHY don't you just break the chip with nippers/pliers and then desolder the pins one by one?
Dallas DS1287 DS12887 RTC Replacement nwX287 Real Time Clock Module Battery Kit
https://www.ebay.com/itm/276981098778
https://www.ebay.com/itm/134217827379
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
