First post, by Retronerd878
I got this Creative Voodoo 2 with 12 mb of ram. Popped it in my windows 95 machine and it wont post. Took it out to further investigate on my microscope. There were clearly some bent pins at two of three main chips and they were shorting. On one of the chips I straighten them no problem. However, when i got to the 2nd chip, and tried to align the pins, they were clearly loose. Like 25% of the total pins, in the corner of the chip, are not soldered to the pad no more. They "dangle" in the air i guess.
How can i fix this? While I do have a solder, desolder and hot air station, I'm a complete noob to fine work like this. I don't even know how the procedure goes.
Is it possible to bake a voodoo 2 in the oven and hope it will reflow the existing solder of the pins and stick them in place?
