First post, by gaffa2002
- Member
Hi,
I've always had this issue where in some games there is an horizontal portion of the screen which has some kind of moving grainy graphical issues. Not sure how to explain in words, but there is a video of it here: https://youtu.be/6J8Lu0E-8sw?si=4OrE_8fbcojnXbh8
The video was recorded while running Outlaws, but the issue also happen in other games (some more, some less, and some don't have the issue at all). My system is a V72MA motherboard with a Pentium 200 MMX and 64 megs of RAM. The video card is the onboard Ati Rage Pro Turbo. I also tried using a different card, a Diamond Stealth 2000 PCI and the grainy graphics became less intense, but still remained even on a different video card.
Any ideas of what could be causing this? I have that board for more than 12 years and this issue was always there, no idea what might be causing it 🙁
Things I already tried:
- Using another monitor (crt and lcd)
- Using another memory module
- Different VGA cables
- Different driver versions for both cards (note that the issue is much less noticeable on the Diamond stealth card)
-Tried disabling hardware acceleration in windows (that improves it, but I think this is due to the grainy movement becoming slower making it less noticeable, similar to using the Diamond Stealth card).
-Using another cmos battery
-Using a different sound card
-Using a different CPU (tried with an K6-2 and same issue)
- Different case (and no case at all)
-Different houses
-Different country
LO-RES, HI-FUN
EP-7KXA Motherboard
Athlon Thunderbird 750mhz
256Mb PC100 RAM
Geforce 4 MX440 64MB AGP (128 bit)
Sound Blaster AWE 64 CT4500 (ISA)
32GB HDD
