MaRCer wrote on 2025-07-29, 18:18:
R8500 is most likely LE, as the bios frequencies are 250/250. In 3D applications, polygons are stretched, and in Doom 1, there are vertical stripes of white dots. Windows works normally. The board itself is undamaged and does not have any leaking or leaking capacitors. Replacing the firmware, reducing/increasing the GPU and memory frequencies, and adjusting the GPU and memory pressure do not affect the artifacts. This is a common problem, but the RV200's crystal is covered in plastic and cannot be damaged, so I assume that the issue is related to the power supply on the board. Where should I start checking? I have found the datasheets for all the voltage generators, but I am unable to determine which pin provides the output voltage.
It has the small square RAMDAC by the GPU so it should be the Radeon 8500 rather than the LE version. Could you take a screenshot of the error that you're seeing in doom?
I don't have the Radeon 8500 myself yet but I've got an AIW 8500 DV I'm about to test and I'm shopping for a full 8500 😀
Weird that Doom shows artifacts but Windows is fine.
Try out a generic memory test tool, I'm not sure there is one for the R200 specifically: Radeon R200 and R100 memory test tool
old school gamer man wrote on 2025-07-29, 19:38:MaRCer wrote on 2025-07-29, 19:35:
The photo is of poor quality, but I've included it to show you what the graphics card looks like. I've inspected all the capacitors, and they appear to be in excellent condition.
just because the caps look good does not mean they are good...
Kind of, if it's a reference board built to a good spec then the capacitors are usually good high quality ones and it's best to go with clues of faults rather than immediately suspecting caps. The silver-can, black marking ones look like good quality capacitors like panasonic polymer low-esr capacitors rather than dodgy brands. The silver markings on the green capacitors imply they're Sanyo capacitors and those are excellent from all the ones I've salvaged and tested so far.
But if they're dodgy brands like Choyo then that's worth being suspicious of even if the caps look okay from the top.
The damaged fan blade is a bigger concern 😒
