First post, by starcraft
I was thinking about making a decent machine that could run games like crusader, system shock, tomb raider with 3dfx patch, super ef2000, f-18 korea, and other 1990-1997 games, etc. I guessed i would need a proccesor along the line of a 166 pentium and a 3dfx voodoo 2 card, around 64 mb ram, sb16 card, but i am not sure what motherboard i should use or what else i need and what is compatible with what. any comments, suggestions or tips anyone? i was also wodering if anyone knows the difference between the win95 versions and which one is optimal for gaming. thanks.
Reply 1 of 9, by DosFreak
Well.....if you buy a fast machine you can run
System Shock
Crusader
on DosBox just fine....
As for Tomb Raider there's always Dgvoodoo or GliDos (If you want Hires textures).
Can't really help you with the other games.
Of course if you just want to build an old machine then that's fine but for alot of games it's not really necessary.
Make your games work offline
Reply 2 of 9, by vasyl
I ended up getting used Asus P2B motherboard. It has PCI, AGP, and ISA, supports a lot of different CPU frequencies and types, known to be very stable and compatible. It's not really old skool but with ISA video (Tseng ET4000), SBPro2, and LAPC-I it is pretty good approximation.
Reply 3 of 9, by starcraft
Thx for the input guys. I tried using dgvoodoo on tombraider, i set it up and tried to run, but after the intro it shows a frame of the main menu and crashes 😒 . I tried fiddling with all the options but still doesnt work. I also tried it on f-18 Korea, it did the 3d part somewhat right but the picture of the cockpit is invisible except for traces of the hud and other indicators. It requires 3dfx to run, unless you want software rendering, which let me tell you, looks graphically inferior to Falcon 3.0 (no textures w/o 3dfx) so LoL. If you got it to work with Tomb Raider can you tell me what version you have and what switches you have on ? thx in advance.
Reply 4 of 9, by HunterZ
🤣 an ISA video card in a system with AGP slots... That's like ripping the whole fuel injection system out of a modern car and putting in a carburetor instead 😉
Or, like hooking up a 1950s black-and-white TV to a DVD player!
Reply 5 of 9, by vasyl
You don't know the whole story: that ISA video card is connected to Dell widescreen 24" LCD monitor! 🤣
Reply 6 of 9, by 5u3
Here is the system I would build for the games you mentioned:
CPU: AMD K6 or Intel Pentium MMX (somewhere between 166 and 233 MHz)
I'd prefer the K6, because it has no locked multipliers and can be clocked down to 100 MHz if needed. Note that some games reaching back to 1990 may have problems with Pentium class CPUs, not only because of the higher clock speed, but also because they sometimes used non-standard 386/486 tricks which will crash a Pentium.
Board: A brand name Socket 7 ATX board with the Intel 430TX chipset.
The TX is one of the least problematic and most versatile chipsets I've ever used. The FSB range is 50 to 66 MHz (some boards go as high as 83 MHz). Supports SDRAM, UDMA on the IDE controller, and the ATX versions often come with USB and PS/2 connectors.
Memory: 64MB SDRAM
More than that wouldn't be cached anyway. Plenty for DOS and about right for Windows, if all you do with it is playing games.
Graphics: 3dfx Voodoo Banshee
Super-fast framebuffer and Glide support, very compatible with older games. Works well with UniVBE.
Sound: ISA SoundBlaster 16 or AWE32/64. Wavetable card recommended.
Storage: 30 GB harddisk, CD-ROM drive (16x minimum)
OS: Windows 95 OSR2, using the integrated DOS7 for DOS games
Reply 7 of 9, by 5u3
AAAHRGH! 😵
Let me guess: 100 thin film transistors to display one pixel? 🙄
Reply 8 of 9, by vasyl
Close... actually, even little more in 320x200 mode. The interesting part is that the display has 16x10 ratio so pixels are actually square in 320x200!
Reply 9 of 9, by gulikoza
Banshee does not work with the first voodoo games that have statically compiled glide in the executable.
