First post, by theelf
Hi, grettings
I know how difficult will be but I ask here for any help
I buy this board assembled and designed in spain, a very nice 486slc chips mb
The problem is even keyboard for a moment look like is detected is not working. I checked all pins and is not a hardware problem
i think is something detect not connected and block the keyboard
any ideas? im stuck here
The attachment CP135C.jpg is no longer available
Reply 1 of 3, by Anonymous Coward
You can do a quick check of the keyboard fuse. I see the marking 'F1' on your board near the keyboard controller, which is a fuse. Looks like it's removable without soldering.
Reply 2 of 3, by Nunoalex
Maybe the keyboard is not working properly ? or it is not compatible ?
When the computer is turned on can you activate the "caps lock" or "num lock" do they light toggle on and off ?
good luck
Reply 3 of 3, by MikeSG
Could try reseating the Fujitsu keyboard controller.
Do the keyboard lights flash, or nothing at all?
