VSBHDA
First post, by Baron von Riedesel
Hello,
VSBHDA - virtual SoundBlaster for DOS (a fork of SBEMU) - got a new release, v1.7:
- fixed: clear CF in case int 31h hook proc handles the function (ax=0x20x).
- added soundfont support from VSBHDASF; new cmdline options /SF, /MV, /PS.
- fixed: array bounds check in vopl3.cpp added (& 0xff).
- fixed: handling of DSP cmd E2 (DMA identification).
- DSP cmd 14h with size < 32 will trigger an IRQ at once; this should make more detection routines to work.
- qpiemu.dll: bit 1 of register CH now holds IF.
- XMSRes.exe: option -H added.
- SB16: 8-bit signed PCM mode (C6h 10h) supported.
- HDA: reset controller if no codecs are attached.
- cmdline option /CF added.
- fixed: ES1371 audio driver.
- /F cmdline option now accepts 11025 as argument.
- added support for SiS 7012.
- cmdline option /O1 for SBLive enables speaker jack.
- fixed: SB Live/SB Audigy FX8010 initialization.
Special thanks to cacodemon345 ( soundfonts ), mkarcher ( ES1371 fix for 5880 variants ) and Thomas Perl ( SiS 7012 support ).
https://github.com/Baron-von-Riedesel/VSBHDA/ … leases/tag/v1.7
