First post, by Retronerd878
I'm trying to bring back to life a Creative voodoo 2 with 12 mb. soldered back some missing caps. And reflowed some loose pins. Got the card to work at some point, and managed to do a Quake 2 benchmark. Now the card doesn't post. Did a full reflow of the TMU's. The card posts and mojo detects the FBI and both TMU chips, however, one TMU chip with zero memory. When I tried to do a full reflow of the FBI chip, some pins got stuck to one-another and when i tried to align them, they were stuck to the pad as well. The pad get dislodged. This happened to maybe 4-5 pins. I managed to align all the pins and solder them to the pads, even though some pads are loose. One pad was shorting a neighboring pad and i used a needle to squeeze between the pins and align the pad in place. Now it's not shorting, even though it's technically loose, and just anchored to the pin. The card doesn't post though.
What am I suppose to do? I'm thinking of removing the chip all together to get a good look at the pads. Even though it's not clear to me how to stick the pads back to the board.
