First post, by superfury
At https://xem.github.io/minix86/manual/intel-x8 … 80e0ce-194.html a table is displayed mentioning various fault levels which much occur before other faults.
When is the VIP+VIF being set handled in this? In my implementation it can happen after the Code Breakpoint Fault, so after step 7 (practically a step 7.5 essentially). When does said check happen in real processors (Supporting interrupt virtualization)?
Or does it execute after the instruction is fetched, when starting execution of the new instruction that's read from memory? Basically falling under "Virtualization exception"?
UniPCemu Git repository
