First post, by audiocrush
Hello Forum People!
Today I cleaned an old IBM 5170 that has some interesting hardware in it.
After fixing a failed diode in the PSU I checked the AT power connector for shorts to ground (case) with all the cards installed.
Sure enough two of the cards made the multimeter beep, so I was trying to figure out what is going on by removing all the caps, powering it up using the lab power supply and trying to see if anything got warm...
One of the cards, the meter "detects continuety", but when I measure the resistance between 5V and GND it is like about 48+50 ohms.
I decided to power it up limited current of course, slowly cranked it up and it was drawing about 320mA at 5V.
I measured the temperature of the chips and they barely got above 33 C or 91 F...
It is a controller card for a maynard tape drive just large enough to fit an 8-Bit ISA slot with some 74 series logic on it...
Is that kind of power consumption normal? Is it maybe also just normal that my meter registers these values as "continuety"?
The other card in question might be more familiar to people:
It is the IBM Fixed Disk-Floppy Diskette ISA Card.
This one reads about 84 ohm on the 5V rail.
Whats special is in this case, in continuety mode I can hear a periodic "tick" noise while the meter is beeping along. I thought well maybe some circuitry trying to start up from the voltage I'm injecting... but the polarity of my continuety test does not matter for the "ticking".
Does anyone have an explanation for that?
If someone could enlighten me that would be really great and give me peace of mind so I can enjoy the weekend.
Greetings
Audiocrush
https://www.nerdsh.org/ - my blog, a bit neglected though
https://www.youtube.com/channel/UChsU6woi3lhLhtT_ILbSCCw - Some videos of mine
