First post, by assenort
Hi guys,
A few days ago the video card in my primary desktop home computer went bad on me. As I turned the computer on as I normally do, the text on the POST screen looked garbled and unreadable. As soon as the Windows booting screen showed up, I noticed distinctive artifacts - evenly-spaced color bands from top to bottom. The color of these bands would change with every consequent restarting of the computer. Furthermore, every now and then the computer would completely freeze requiring reset or hard reboot.
I have used this card for about 9 years now, always kept it clean and dust-free, never overclocked it, and used MSI Afterburner to keep the fan speed at 80%. Normal operational temperature of the card was about 50 degrees C, going up to 60-65 when playing games. Computer case is well-ventilated. PSU is healthy and works fine.
I removed the card from the computer and closely examined it visually to see if there is any color change of the PCB or other sign of burn-out - there was none. Capacitors seem to be in good shape.
My gut feeling tells me the life of the card is up, yet I decided to post here asking for advise - could it be that the card BIOS bugged out and eventual re-flashing would fix the problem? Please let me know, I'd be very grateful for any help on the issue.
Specification:
Manifacturer: Jaton
Model: nVidia GeForce 8800 GTS
Codename: G80
Memory: 640MB
Interface: PCIe 1.0
Regards!
Reply 1 of 6, by myne
Find version of mats mods for that era.
Run.
Most likely memory is faulty somehow.
I built:
Reply 2 of 6, by agent_x007
It's either a VRAM chip gone bad (one of chips has "stuck" bit), a BGA connection issue between VRAM and GPU (can be under either GPU itself or VRAM chip) OR NVIO chip giving up the ghost (with again bad connection of failed transisotors inside).
Note : NVIO chip is located to the left of GPU core on G80/GT200 cards (top view, with PCIe at the bottom), and it's in short responsible for displaying things on monitor.
Reply 3 of 6, by assenort
myne and agent_x007 - thank you very much for responding, really appreciate it.
I am having trouble locating nVidia MODS/MATS that would work with this particular video card model, but I will keep searching.
From what I understand (this whole situation is well above my pay grade, so to speak) the only chance for repairing this card is to replace eventual bad VRAM chips, right? Meaning I have to find GDDR3 512Mb chips and also a technician who can do the replacement? Not gonna be ease, honestly...
Also, is it correct to assume that the NVIO chip that agent_x007 mentioned is not repairable?
Thanks again for the responses 😀
Reply 4 of 6, by The Serpent Rider
If you're REALLY lucky, that's a VRAM problem and you can replace it relatively easy. But usually G80 chip itself have some sort of bumpgate failure (you can read about it here on Vogons if you search) and there's nothing you can do about it as a long term fix, unless you can find a new old stock of G80 chips.
At the same time, it's usually just not economically reasonable to fix any of these cards when you can just buy a G92 card really cheap.
Reply 5 of 6, by myne
It could be many things.
Mats mods usually covers a few generations backwards.
You might have more luck looking for 2/300 series versions.
I built:
Reply 6 of 6, by assenort
Thanks again for all the responses, it's been an eye opener 😀
