First post, by Jackal1983
I'm having an issue with enabling DMA on my 440BX rig.
It's this mobo: https://theretroweb.com/motherboards/s/ecs-p6bx-ms
Basically I've been unable to get DMA mode working on it. I'll switch on DMA in the device manager, I'll get the "unsupported hardware" error but the box stays checked. However when I reboot it's not selected anymore. I've tried different ide SSDs, SATA to ide bridged SATA drives, 40 wire and 80 wire cables with no luck. Is there a specific version of the chipset driver I need to use? It's an mATX board, so I'd like to avoid using a PCI slot.
Reply 1 of 14, by Chkcpu
Hi Jackal1983,
What you are facing here is the infamous UDMA mode bug. This Award BIOS bug was fixed in March 1999 and later BIOS versions.
Unfortunately, the latest ECS P6BX-MS BIOS is Ver 1.1d from 02/08/1999. I assume you are running this BIOS?
This UDMA bug causes the BIOS to report a higher UDMA mode than the chipset can handle, when using an ATA66 or faster drive. Windows then rejects any UMDA mode and reverts to PIO mode 4 to protect your data on the HDD/SSD.
I have a fix for this UDMA mode bug. Give me a few days to patch the 02/08/1999 BIOS with this fix. While I’m at it, I will fix the 32GB HDD limit bug in this BIOS as well. 😀
Cheers, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 2 of 14, by Jackal1983
Chkcpu wrote on 2025-08-21, 11:40:
Hi Jackal1983, […]
Hi Jackal1983,
Cheers, Jan
Yep, I'm on v 1.1d. And YES, please send it!!!
Reply 3 of 14, by Jackal1983
By the by, could you add in Coppermine and Tualatin microcode? I'd like to get this board working with C3 Ezra and Nehemiah CPUs and I figure those microcodes might help. Do you have any ideas along those lines?
Reply 4 of 14, by Chkcpu
Jackal1983 wrote on 2025-08-22, 04:28:
Hi Jackal1983, […]
Hi Jackal1983,
Cheers, Jan
Here is the patched P6BX-MS Rev 1.1d BIOS.
Both the UMDA Mode bug and 32GB IDE HDD limit bug are fixed.
In the zip, I’ve included a PATCH.TXT file that lists the changes I’ve made.
The attachment BXMS_J1.zip is no longer available
When ATA/66/100/133 drives are fitted, the BIOS will now limit the reported UDMA Mode to UDMA 2, the maximum supported UDMA Mode on this 440BX chipset. This change is also visible on the BIOS summary screen.
The 32GB limit bugfix consists of one 32GB and two 64GB limit fixes. This patch J.1 BIOS now supports IDE drives up to 128GiB/137GB.
More info about these fixes can be found on my website at http://www.steunebrink.info/k6plus.htm#32GB_bugfix
The “new community fix” described there is the fix I used for your BIOS.
Jackal1983 wrote on 2025-08-22, 08:00:
I’ve looked at the CPU support in the Rev 1.1d BIOS, but I see only Intel CPUs are supported. VIA C3 detection and support code is nowhere to be found. Not surprising for an early 1999 Slot 1 BIOS. 😉
I’m unable to add VIA C3 support. I do mainly Socket 3/5/7 BIOS patches, and my modding repertoire for Slot 1/Socket 370 is very limited.
Do let us know how this P6BX-MS patch J.1 BIOS works.
Cheers, Jan
Reply 5 of 14, by Jackal1983
Chkcpu wrote on 2025-08-22, 13:46:
Here is the patched P6BX-MS Rev 1.1d BIOS. Both the UMDA Mode bug and 32GB IDE HDD limit bug are fixed. In the zip, I’ve include […]
Hi Jackal1983, […]
Hi Jackal1983,
Cheers, Jan
Cheers, Jan
Looks like it works. DMA was already selected when I rebooted after flashing. What's the best way of testing read write speeds? I just did Roadkil's disk speed test and speeds maxed out at 25 mb/s which is faster than PIO-4, but is more along the lines of UDMA-1
Reply 6 of 14, by Jackal1983
Also, it doesn't seem like windows will allow DMA to be enabled for the SD card reader I have on the secondary channel. I'm using a 40 wire cable for it but that should be ok for UDMA 33, correct?
Reply 7 of 14, by Chkcpu
Great to hear the patched BIOS works and Windows allows UDMA now. 😀
My drive read and write speed benchmark of choice is the ATTO Disk Benchmark v2.41 (2007 version). Works fine under Win98.
A 40-wire IDE cable is indeed fine for UDMA 33. Only higher UDMA modes need the 80-wire cable.
DMA on SD card readers can be hit or miss. There are a lot of reports here on Vogons about that, and on SATA2IDE adapters too. Seems to depend a lot on the controller chip used.
Cheers, Jan
Reply 8 of 14, by Jackal1983
Chkcpu wrote on 2025-08-22, 19:53:
Great to hear the patched BIOS works and Windows allows UDMA now. :) […]
Cheers, Jan
So after running ATTO on my HDD with and without DMA enabled there is one helluva difference
DMA Disabled:
Read Max is 5.1 mb/s at 8192 kb
Write Max is 4 mb/s at 256 Kb, with writes at 64 kb and 128 kb being 3.9 mb/s
Write at 8192 kb was 3.8 mb/s
DMA Enabled:
Read Max is 26.2 mb/s at 8192 kb
Write Max is 13.6 mb/s at 64 kb, with writes at 128 kb and 256 kb being 9.89 mb/s and 10.5 mb/s
Writes at 8192 kb was 9 mb/s
Reply 9 of 14, by Jackal1983
Hi Jackal1983, […]
Hi Jackal1983,
Cheers, Jan
Cheers, Jan
Also, would you mind if I shared this modded bios with theretroweb.com?
Reply 10 of 14, by Chkcpu
These DMA Enabled figures look nice!! 😀
Jackal1983 wrote on 2025-08-23, 00:31:
No, I don't mind at all. So yes, please send this patched P6BX-MS BIOS to TRW.
Jan
Reply 11 of 14, by Jackal1983
Chkcpu wrote on 2025-08-23, 10:09:
These DMA Enabled figures look nice!! :) […]
Jan
Oh and it looks like it was in fact an issue with my SD card reader. DMA does work with an IDE CF card reader.
Reply 12 of 14, by megatog615
Hi Jackal1983, […]
Hi Jackal1983,
Cheers, Jan
Could this affect an AMI bios as well? I have another SBC(Portwell ROBO-668) that has a problem booting Windows without compatibility mode disk access. The SBC isn't on TRW yet otherwise I'd link it. Oddly enough Linux seems to boot fine and see the entire drive, no doubt with some sort of workaround for this problem. Windows 2000 will BSOD in the installer when it tries to find the drive it's copied files to, and XP seems to detect the drive but only as an 8GB drive if it's larger than that. I'm guessing XP is employing some workaround as well but not as robust as Linux.
Reply 13 of 14, by Chkcpu
megatog615 wrote on 2026-04-01, 01:15:
Hi Jackal1983, […]
Hi Jackal1983,
Cheers, Jan
No, I never experienced or heard of a similar UDMA issue in AMI BIOSes.
Your ROBO-668 BIOS is dated March 3, 2002 and should have no problems with IDE drives up to 128Gib/137GB. Only LBA48 was not yet a thing, hence the 128GiB limit.
Did you try a conventional 120GB or smaller HDD? I ask because using modern SD cards or SSD drives on a BIOS from that era can cause the symptoms you describe.
Jan
Reply 14 of 14, by megatog615
Chkcpu wrote on 2026-04-01, 20:53:
No, I never experienced or heard of a similar UDMA issue in AMI BIOSes. Your ROBO-668 BIOS is dated March 3, 2002 and should hav […]
Hi Jackal1983, […]
Hi Jackal1983,
Cheers, Jan
Jan
Yes, a 6GB Toshiba laptop drive. Shows up as UDMA 2. Others have told me that they suspect the southbridge is dying.
