First post, by aurasdoom
I have bought an old Pentium III Sony VAIO PC which came with a 120V PSU.
I replaced the PSU with a more modern one which doesn't have the -5V rail anymore. The computer complains about that at boot time. More specifically it thinks there's -12v on the -5v pin, but I checked and that pin is not present.
Did no computer ever use it and that's why it was removed?
Should I ignore it?
Reply 1 of 10, by Matth79
-12 being detected on the -5 is alarming, but that is presumably the voltage sense somehow floating - and if it's floating, then there is no load.
Some soundcards need -5 for the audio stages, and if you can spare an ISA slot, there is the "voltage blaster" https://www.philscomputerlab.com/voltage-blaster--5v.html.
In the AT era, it was needed a lot more
Reply 2 of 10, by aurasdoom
Thanks for the reply. There is no ISA slot in this pc. Was it only used for those slots?
Reply 3 of 10, by mkarcher
aurasdoom wrote on 2025-08-22, 16:04:
Since the 4116 memory chips (which required -5V if I remember correctly) were obsolete in 1983, Mainboards No longer required -5V, and the only remaining use was to forward that voltage to the slots.
Reply 4 of 10, by aurasdoom
The computer works fine. I really hate that it stops the boot process every time and I have to press F1.
Reply 5 of 10, by DaveDDS
The current requirement on the -5v rail is/was very low.
IIRC many PSUs implementer it with a simple analog regulator on the -12v rail.
You can do the same, with something as simple as a 7905.
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 7 of 10, by aurasdoom
@red-ray do you have a clearer picture? Or the do you still know the values of the resistors?
Reply 8 of 10, by red-ray
aurasdoom wrote on 2025-09-08, 13:23:
It may depend on the board, I used -12 ... 1K ... -5 ... 680R ... earth, measure the actual -5 voltage and adjust the 680R as needed.
Doing the sums -12 x 680 / ( 1000 + 680 ) = -4.86 volts
Reply 9 of 10, by jh80
aurasdoom wrote on 2025-09-08, 07:36:
Sometimes there is a way to turn off the -5V alarm in the BIOS. I'd check there first.
Reply 10 of 10, by aurasdoom
jh80 wrote on 2025-09-08, 22:40:
I've set the BIOS to ignore the voltage on the -5V rail but it still gives the warning at boot and requires me to press F1
