Hello dionb,
thank you for such a complex answer. I will have to think about it many times. Until then I am going to make some reactions to each of your section:
1st - my mistake, yes, it is Amptron :-]. If you mean by VP1 Apollo VP VT82C585VP, then probably yes, haven't checked it yet.
2nd - this was little bit Spanish village for me, as we here in Slovakia use to say to things which are hard to understand, but I gave it a thought: that module has 8 chips, so according your info when each has 128Mb, then it is 128Mb x 8chips=1024Mb/8Mbit=128MB. When the chipset can address only 16Mb per chip, then it is 16MB. Understood. But when I inserted only that one module, it showed 32MB. After I put back those two simms with the dimm still in place, now the dimm added 16MB.
3rd - "This is a hard limit and indeed means you can't get more than 32MB per DIMM on boards using this chipset" - strange, because manual contains different info, but I am not arguing and you explained it already.
- no, I don't wanna solder anything :-]
4th - "Note that you can install up to 128MB on the board using four 32MB SIMMs" - clear. - the cache according manual should be 512kB.
Bottom line: thanks again for these usefull information. I will stick to those two simm modules plus one 16MB instead of the 128MB.
