First post, by Avenger
I have setup the base game with TombATI 1.8 including the HQ FMV's and Texture Pack without issue found here:
https://www.glidos.net/tombati.html?lang=en
However, I'm getting a crash to desktop after the "EIDOS" logo screen when trying to run the Unfinished Business Expansion.
I copied the levels to the "Data" folder within the base directory from here:
https://www.tombraiderforums.com/showthread.php?t=213223
Any ideas on what the problem may be?
Thanks in advance.
Reply 1 of 24, by Glidos
Difficult to say. If you are copying the data files by hand then it can be difficult to get everything right. What works best is to use the installer from here: https://www.glidos.net/tombati.html?lang=en and let it copy the files for you although, for that to work, you need to have the orginal TR1 CDs, or the gog version install, or the steam version installed (in fact, I think possibly for the steam version, you need TR2 installed - weird I know).
Hmmm, I may have misremembered that. Actually, it looks like the installer I referred to above, installs several things, including TombATIConfigure.exe and TombRaiderImporter.exe. It is the second of these that can copy the data for you.
I don't know if this will help, but here is a list of all the files I have in my TOMBATI directory:
-rwxr-xr-x 1 paul 197121 205824 Apr 18 2017 ./ati3dcif.dll
-rw-r--r-- 1 paul 197121 46 Aug 31 12:36 ./atiset.dat
-rw-r--r-- 1 paul 197121 3270738 Jul 27 2016 ./DATA/CAT.PHD
-rw-r--r-- 1 paul 197121 231538 Jul 16 2013 ./DATA/CRED0.PCX
-rw-r--r-- 1 paul 197121 106587 Feb 27 2022 ./DATA/CRED1.PCX
-rw-r--r-- 1 paul 197121 196985 Feb 27 2022 ./DATA/CRED2.PCX
-rw-r--r-- 1 paul 197121 174908 Feb 27 2022 ./DATA/CRED3.PCX
-rw-r--r-- 1 paul 197121 599840 Feb 27 2022 ./DATA/CUT1.PHD
-rw-r--r-- 1 paul 197121 354320 Feb 27 2022 ./DATA/CUT2.PHD
-rw-r--r-- 1 paul 197121 512104 Feb 27 2022 ./DATA/CUT3.PHD
-rw-r--r-- 1 paul 197121 879582 Feb 27 2022 ./DATA/CUT4.PHD
-rw-r--r-- 1 paul 197121 3279056 Mar 6 2016 ./DATA/EGYPT.PHD
-rw-r--r-- 1 paul 197121 22700 Feb 27 2022 ./DATA/EIDOSPC.PCX
-rw-r--r-- 1 paul 197121 102512 Feb 27 2022 ./DATA/END.PCX
-rw-r--r-- 1 paul 197121 3208420 Mar 6 2016 ./DATA/END.PHD
-rw-r--r-- 1 paul 197121 3153688 Mar 6 2016 ./DATA/END2.PHD
-rw-r--r-- 1 paul 197121 3237128 Feb 27 2022 ./DATA/GYM.PHD
-rw-r--r-- 1 paul 197121 168100 Feb 27 2022 ./DATA/INSTALL.PCX
-rw-r--r-- 1 paul 197121 2533634 Feb 27 2022 ./DATA/LEVEL1.PHD
-rw-r--r-- 1 paul 197121 3224138 Feb 27 2022 ./DATA/LEVEL10A.PHD
-rw-r--r-- 1 paul 197121 3094342 Feb 27 2022 ./DATA/LEVEL10B.PHD
-rw-r--r-- 1 paul 197121 3532024 Feb 27 2022 ./DATA/LEVEL10C.PHD
-rw-r--r-- 1 paul 197121 2873450 Feb 27 2022 ./DATA/LEVEL2.PHD
-rw-r--r-- 1 paul 197121 2934730 Feb 27 2022 ./DATA/LEVEL3A.PHD
-rw-r--r-- 1 paul 197121 2738258 Feb 27 2022 ./DATA/LEVEL3B.PHD
-rw-r--r-- 1 paul 197121 3030872 Feb 27 2022 ./DATA/LEVEL4.PHD
-rw-r--r-- 1 paul 197121 2718540 Feb 27 2022 ./DATA/LEVEL5.PHD
-rw-r--r-- 1 paul 197121 3074376 Feb 27 2022 ./DATA/LEVEL6.PHD
-rw-r--r-- 1 paul 197121 2817612 Feb 27 2022 ./DATA/LEVEL7A.PHD
-rw-r--r-- 1 paul 197121 3389096 Feb 27 2022 ./DATA/LEVEL7B.PHD
-rw-r--r-- 1 paul 197121 2880564 Feb 27 2022 ./DATA/LEVEL8A.PHD
-rw-r--r-- 1 paul 197121 2886756 Feb 27 2022 ./DATA/LEVEL8B.PHD
-rw-r--r-- 1 paul 197121 3105450 Feb 27 2022 ./DATA/LEVEL8C.PHD
-rw-r--r-- 1 paul 197121 316460 Feb 27 2022 ./DATA/TITLE.PHD
-rw-r--r-- 1 paul 197121 115980 Feb 27 2022 ./DATA/TITLEH.PCX
-rwxr-xr-x 1 paul 197121 151040 Apr 18 2017 ./ddraw.dll
-rwxr-xr-x 1 paul 197121 98816 Apr 6 1999 ./Dec130.dll
-rwxr-xr-x 1 paul 197121 265396 Feb 15 2006 ./DOS4GW.EXE
-rwxr-xr-x 1 paul 197121 117248 Apr 6 1999 ./Edec.dll
-rw-r--r-- 1 paul 197121 101 Apr 6 1999 ./filedesc.des
-rw-r--r-- 1 paul 197121 7402139 May 2 2011 ./FMV/CAFE.AVI
-rw-r--r-- 1 paul 197121 15995851 Feb 27 2022 ./FMV/CAFE.RPL
-rw-r--r-- 1 paul 197121 16560515 May 2 2011 ./FMV/CANYON.AVI
-rw-r--r-- 1 paul 197121 32413718 Feb 27 2022 ./FMV/CANYON.RPL
-rw-r--r-- 1 paul 197121 1123548 May 2 2011 ./FMV/CORE.AVI
-rw-r--r-- 1 paul 197121 1877283 Feb 27 2022 ./FMV/CORE.RPL
-rw-r--r-- 1 paul 197121 5457021 May 2 2011 ./FMV/END.AVI
-rw-r--r-- 1 paul 197121 10158823 Feb 27 2022 ./FMV/END.RPL
-rw-r--r-- 1 paul 197121 1062180 Feb 27 2022 ./FMV/ESCAPE.RPL
-rw-r--r-- 1 paul 197121 8110033 May 2 2011 ./FMV/LIFT.AVI
-rw-r--r-- 1 paul 197121 17919663 Feb 27 2022 ./FMV/LIFT.RPL
-rw-r--r-- 1 paul 197121 1837150 May 2 2011 ./FMV/MANSION.AVI
-rw-r--r-- 1 paul 197121 2895565 Feb 27 2022 ./FMV/MANSION.RPL
-rw-r--r-- 1 paul 197121 7169748 May 2 2011 ./FMV/PRISON.AVI
-rw-r--r-- 1 paul 197121 13764300 Feb 27 2022 ./FMV/PRISON.RPL
-rw-r--r-- 1 paul 197121 628558 May 2 2011 ./FMV/PYRAMID.AVI
-rw-r--r-- 1 paul 197121 1330206 Feb 27 2022 ./FMV/PYRAMID.RPL
-rw-r--r-- 1 paul 197121 7882825 May 2 2011 ./FMV/SNOW.AVI
-rw-r--r-- 1 paul 197121 16352839 Feb 27 2022 ./FMV/SNOW.RPL
-rw-r--r-- 1 paul 197121 5854064 May 2 2011 ./FMV/VISION.AVI
-rw-r--r-- 1 paul 197121 10979902 Feb 27 2022 ./FMV/VISION.RPL
-rwxr-xr-x 1 paul 197121 214016 Apr 18 2017 ./glrage.dll
-rw-r--r-- 1 paul 197121 1166 Mar 18 2017 ./glrage.ini
-rw-r--r-- 1 paul 197121 83774 Feb 15 2006 ./HMIDET.386
-rw-r--r-- 1 paul 197121 317317 Feb 15 2006 ./HMIDRV.386
-rw-r--r-- 1 paul 197121 220 Feb 15 2006 ./HMISET.CFG
-rw-r--r-- 1 paul 197121 552 May 14 2017 ./INSTALL.BAT
-rw-r--r-- 1 paul 197121 1914216 Apr 22 2017 ./JC/CAT_0.png
-rw-r--r-- 1 paul 197121 1497662 Apr 22 2017 ./JC/CAT_1.png
-rw-r--r-- 1 paul 197121 1133267 Apr 22 2017 ./JC/CAT_11.png
-rw-r--r-- 1 paul 197121 509349 Apr 22 2017 ./JC/CAT_12.png
-rw-r--r-- 1 paul 197121 1518732 Apr 22 2017 ./JC/CAT_2.png
-rw-r--r-- 1 paul 197121 1556511 Apr 22 2017 ./JC/CAT_4.png
-rw-r--r-- 1 paul 197121 1396777 Apr 22 2017 ./JC/CAT_5.png
-rw-r--r-- 1 paul 197121 1665819 Mar 30 2017 ./JC/CUT1_0.png
-rw-r--r-- 1 paul 197121 1280956 Mar 30 2017 ./JC/CUT1_1.png
-rw-r--r-- 1 paul 197121 1063321 Mar 30 2017 ./JC/CUT1_2.png
-rw-r--r-- 1 paul 197121 315270 Mar 30 2017 ./JC/CUT1_3.png
-rw-r--r-- 1 paul 197121 1583028 Mar 30 2017 ./JC/CUT2_0.png
-rw-r--r-- 1 paul 197121 1370224 Mar 30 2017 ./JC/CUT2_1.png
-rw-r--r-- 1 paul 197121 313291 Mar 30 2017 ./JC/CUT2_2.png
-rw-r--r-- 1 paul 197121 2022074 Mar 30 2017 ./JC/CUT3_0.png
-rw-r--r-- 1 paul 197121 1659098 Mar 30 2017 ./JC/CUT3_1.png
-rw-r--r-- 1 paul 197121 1856092 Mar 30 2017 ./JC/CUT3_2.png
-rw-r--r-- 1 paul 197121 803522 Mar 30 2017 ./JC/CUT3_3.png
-rw-r--r-- 1 paul 197121 2064193 Mar 30 2017 ./JC/CUT4_0.png
-rw-r--r-- 1 paul 197121 1429152 Mar 30 2017 ./JC/CUT4_1.png
-rw-r--r-- 1 paul 197121 1479226 Mar 30 2017 ./JC/CUT4_2.png
-rw-r--r-- 1 paul 197121 1296436 Mar 30 2017 ./JC/CUT4_3.png
-rw-r--r-- 1 paul 197121 508777 Mar 30 2017 ./JC/CUT4_4.png
-rw-r--r-- 1 paul 197121 2277805 Apr 22 2017 ./JC/EGYPT_0.png
-rw-r--r-- 1 paul 197121 1903446 Apr 22 2017 ./JC/EGYPT_1.png
-rw-r--r-- 1 paul 197121 1109122 Apr 22 2017 ./JC/EGYPT_11.png
-rw-r--r-- 1 paul 197121 254131 Apr 22 2017 ./JC/EGYPT_12.png
-rw-r--r-- 1 paul 197121 1491478 Apr 22 2017 ./JC/EGYPT_2.png
-rw-r--r-- 1 paul 197121 1112665 Apr 22 2017 ./JC/EGYPT_3.png
-rw-r--r-- 1 paul 197121 1941537 Apr 22 2017 ./JC/EGYPT_4.png
-rw-r--r-- 1 paul 197121 984181 Apr 22 2017 ./JC/EGYPT_5.png
-rw-r--r-- 1 paul 197121 2149433 Apr 22 2017 ./JC/END_0.png
-rw-r--r-- 1 paul 197121 2397393 Apr 22 2017 ./JC/END_1.png
-rw-r--r-- 1 paul 197121 1478807 Apr 22 2017 ./JC/END_10.png
-rw-r--r-- 1 paul 197121 976151 Apr 22 2017 ./JC/END_11.png
-rw-r--r-- 1 paul 197121 286068 Apr 22 2017 ./JC/END_12.png
-rw-r--r-- 1 paul 197121 1611127 Apr 22 2017 ./JC/END_2.png
-rw-r--r-- 1 paul 197121 2299043 Apr 22 2017 ./JC/END_3.png
-rw-r--r-- 1 paul 197121 1671632 Apr 22 2017 ./JC/END_4.png
-rw-r--r-- 1 paul 197121 1371455 Apr 22 2017 ./JC/END_8.png
-rw-r--r-- 1 paul 197121 1638521 Apr 22 2017 ./JC/END_9.png
-rw-r--r-- 1 paul 197121 2142773 Apr 22 2017 ./JC/END2_0.png
-rw-r--r-- 1 paul 197121 2048938 Apr 22 2017 ./JC/END2_1.png
-rw-r--r-- 1 paul 197121 1493233 Apr 22 2017 ./JC/END2_10.png
-rw-r--r-- 1 paul 197121 880992 Apr 22 2017 ./JC/END2_11.png
-rw-r--r-- 1 paul 197121 229935 Apr 22 2017 ./JC/END2_12.png
-rw-r--r-- 1 paul 197121 1754725 Apr 22 2017 ./JC/END2_2.png
-rw-r--r-- 1 paul 197121 970238 Mar 30 2017 ./JC/GYM_0.png
-rw-r--r-- 1 paul 197121 1122584 Mar 30 2017 ./JC/GYM_2.png
-rw-r--r-- 1 paul 197121 1242701 Mar 30 2017 ./JC/GYM_3.png
-rw-r--r-- 1 paul 197121 1300743 Mar 30 2017 ./JC/GYM_4.png
-rw-r--r-- 1 paul 197121 957802 Mar 30 2017 ./JC/GYM_5.png
-rw-r--r-- 1 paul 197121 972558 Mar 30 2017 ./JC/GYM_6.png
-rw-r--r-- 1 paul 197121 980115 Mar 30 2017 ./JC/GYM_7.png
-rw-r--r-- 1 paul 197121 732439 Mar 30 2017 ./JC/GYM_8.png
-rw-r--r-- 1 paul 197121 12163 Mar 30 2017 ./JC/keys.txt
-rw-r--r-- 1 paul 197121 2373249 Mar 30 2017 ./JC/LEVEL1_0.png
-rw-r--r-- 1 paul 197121 2454373 Mar 30 2017 ./JC/LEVEL1_1.png
-rw-r--r-- 1 paul 197121 309998 Mar 30 2017 ./JC/LEVEL1_10.png
-rw-r--r-- 1 paul 197121 2244198 Mar 30 2017 ./JC/LEVEL1_2.png
-rw-r--r-- 1 paul 197121 2192276 Mar 30 2017 ./JC/LEVEL1_3.png
-rw-r--r-- 1 paul 197121 1640917 Mar 30 2017 ./JC/LEVEL1_4.png
-rw-r--r-- 1 paul 197121 1680933 Mar 30 2017 ./JC/LEVEL1_5.png
-rw-r--r-- 1 paul 197121 1104567 Mar 30 2017 ./JC/LEVEL1_6.png
-rw-r--r-- 1 paul 197121 1043797 Mar 30 2017 ./JC/LEVEL1_7.png
-rw-r--r-- 1 paul 197121 1268797 Mar 30 2017 ./JC/LEVEL1_8.png
-rw-r--r-- 1 paul 197121 972823 Mar 30 2017 ./JC/LEVEL1_9.png
-rw-r--r-- 1 paul 197121 2514322 Mar 30 2017 ./JC/LEVEL10A_0.png
-rw-r--r-- 1 paul 197121 1732524 Mar 30 2017 ./JC/LEVEL10A_1.png
-rw-r--r-- 1 paul 197121 1209908 Mar 30 2017 ./JC/LEVEL10A_10.png
-rw-r--r-- 1 paul 197121 822353 Mar 30 2017 ./JC/LEVEL10A_11.png
-rw-r--r-- 1 paul 197121 136674 Mar 30 2017 ./JC/LEVEL10A_12.png
-rw-r--r-- 1 paul 197121 1725589 Mar 30 2017 ./JC/LEVEL10A_2.png
-rw-r--r-- 1 paul 197121 1984924 Mar 30 2017 ./JC/LEVEL10A_3.png
-rw-r--r-- 1 paul 197121 1287382 Mar 30 2017 ./JC/LEVEL10A_4.png
-rw-r--r-- 1 paul 197121 1874300 Mar 30 2017 ./JC/LEVEL10A_5.png
-rw-r--r-- 1 paul 197121 1985923 Mar 30 2017 ./JC/LEVEL10A_6.png
-rw-r--r-- 1 paul 197121 1706371 Mar 30 2017 ./JC/LEVEL10A_7.png
-rw-r--r-- 1 paul 197121 1623685 Mar 30 2017 ./JC/LEVEL10A_8.png
-rw-r--r-- 1 paul 197121 1531727 Mar 30 2017 ./JC/LEVEL10A_9.png
-rw-r--r-- 1 paul 197121 1929759 Mar 30 2017 ./JC/LEVEL10B_1.png
-rw-r--r-- 1 paul 197121 1550153 Mar 30 2017 ./JC/LEVEL10B_10.png
-rw-r--r-- 1 paul 197121 849566 Mar 30 2017 ./JC/LEVEL10B_11.png
-rw-r--r-- 1 paul 197121 182595 Mar 30 2017 ./JC/LEVEL10B_12.png
-rw-r--r-- 1 paul 197121 1685082 Mar 30 2017 ./JC/LEVEL10B_2.png
-rw-r--r-- 1 paul 197121 2202300 Mar 30 2017 ./JC/LEVEL10B_3.png
-rw-r--r-- 1 paul 197121 1514161 Mar 30 2017 ./JC/LEVEL10B_4.png
-rw-r--r-- 1 paul 197121 1707456 Mar 30 2017 ./JC/LEVEL10B_5.png
-rw-r--r-- 1 paul 197121 2090903 Mar 30 2017 ./JC/LEVEL10B_6.png
-rw-r--r-- 1 paul 197121 1634286 Mar 30 2017 ./JC/LEVEL10B_7.png
-rw-r--r-- 1 paul 197121 1362296 Mar 30 2017 ./JC/LEVEL10B_8.png
-rw-r--r-- 1 paul 197121 1660100 Mar 30 2017 ./JC/LEVEL10B_9.png
-rw-r--r-- 1 paul 197121 2189399 Mar 30 2017 ./JC/LEVEL10C_0.png
-rw-r--r-- 1 paul 197121 2031724 Mar 30 2017 ./JC/LEVEL10C_1.png
-rw-r--r-- 1 paul 197121 1312990 Mar 30 2017 ./JC/LEVEL10C_10.png
-rw-r--r-- 1 paul 197121 1182603 Mar 30 2017 ./JC/LEVEL10C_11.png
-rw-r--r-- 1 paul 197121 446697 Mar 30 2017 ./JC/LEVEL10C_12.png
-rw-r--r-- 1 paul 197121 1720653 Mar 30 2017 ./JC/LEVEL10C_2.png
-rw-r--r-- 1 paul 197121 2281365 Mar 30 2017 ./JC/LEVEL10C_3.png
-rw-r--r-- 1 paul 197121 1579644 Mar 30 2017 ./JC/LEVEL10C_4.png
-rw-r--r-- 1 paul 197121 1675055 Mar 30 2017 ./JC/LEVEL10C_5.png
-rw-r--r-- 1 paul 197121 1996224 Mar 30 2017 ./JC/LEVEL10C_6.png
-rw-r--r-- 1 paul 197121 1475751 Mar 30 2017 ./JC/LEVEL10C_7.png
-rw-r--r-- 1 paul 197121 1388840 Mar 30 2017 ./JC/LEVEL10C_8.png
-rw-r--r-- 1 paul 197121 1389691 Mar 30 2017 ./JC/LEVEL10C_9.png
-rw-r--r-- 1 paul 197121 2402951 Mar 30 2017 ./JC/LEVEL2_0.png
-rw-r--r-- 1 paul 197121 2309778 Mar 30 2017 ./JC/LEVEL2_1.png
-rw-r--r-- 1 paul 197121 1056624 Mar 30 2017 ./JC/LEVEL2_10.png
-rw-r--r-- 1 paul 197121 999079 Mar 30 2017 ./JC/LEVEL2_11.png
-rw-r--r-- 1 paul 197121 122618 Mar 30 2017 ./JC/LEVEL2_12.png
-rw-r--r-- 1 paul 197121 1781709 Mar 30 2017 ./JC/LEVEL2_2.png
-rw-r--r-- 1 paul 197121 2033997 Mar 30 2017 ./JC/LEVEL2_3.png
-rw-r--r-- 1 paul 197121 1391797 Mar 30 2017 ./JC/LEVEL2_4.png
-rw-r--r-- 1 paul 197121 1618024 Mar 30 2017 ./JC/LEVEL2_5.png
-rw-r--r-- 1 paul 197121 1751958 Mar 30 2017 ./JC/LEVEL2_6.png
-rw-r--r-- 1 paul 197121 1359337 Mar 30 2017 ./JC/LEVEL2_7.png
-rw-r--r-- 1 paul 197121 1348132 Mar 30 2017 ./JC/LEVEL2_8.png
-rw-r--r-- 1 paul 197121 1220473 Mar 30 2017 ./JC/LEVEL2_9.png
-rw-r--r-- 1 paul 197121 1805397 Mar 30 2017 ./JC/LEVEL3A_0.png
-rw-r--r-- 1 paul 197121 1594089 Mar 30 2017 ./JC/LEVEL3A_1.png
-rw-r--r-- 1 paul 197121 927367 Mar 30 2017 ./JC/LEVEL3A_10.png
-rw-r--r-- 1 paul 197121 398519 Mar 30 2017 ./JC/LEVEL3A_11.png
-rw-r--r-- 1 paul 197121 2257573 Mar 30 2017 ./JC/LEVEL3A_2.png
-rw-r--r-- 1 paul 197121 2081922 Mar 30 2017 ./JC/LEVEL3A_3.png
-rw-r--r-- 1 paul 197121 1738875 Mar 30 2017 ./JC/LEVEL3A_4.png
-rw-r--r-- 1 paul 197121 1360770 Mar 30 2017 ./JC/LEVEL3A_5.png
-rw-r--r-- 1 paul 197121 1291418 Mar 30 2017 ./JC/LEVEL3A_6.png
-rw-r--r-- 1 paul 197121 1188054 Mar 30 2017 ./JC/LEVEL3A_7.png
-rw-r--r-- 1 paul 197121 1749924 Mar 30 2017 ./JC/LEVEL3A_8.png
-rw-r--r-- 1 paul 197121 1623439 Mar 30 2017 ./JC/LEVEL3A_9.png
-rw-r--r-- 1 paul 197121 1890549 Mar 30 2017 ./JC/LEVEL3B_0.png
-rw-r--r-- 1 paul 197121 1746553 Mar 30 2017 ./JC/LEVEL3B_1.png
-rw-r--r-- 1 paul 197121 424488 Mar 30 2017 ./JC/LEVEL3B_10.png
-rw-r--r-- 1 paul 197121 1953283 Mar 30 2017 ./JC/LEVEL3B_2.png
-rw-r--r-- 1 paul 197121 1830307 Mar 30 2017 ./JC/LEVEL3B_3.png
-rw-r--r-- 1 paul 197121 1350978 Mar 30 2017 ./JC/LEVEL3B_4.png
-rw-r--r-- 1 paul 197121 1359810 Mar 30 2017 ./JC/LEVEL3B_5.png
-rw-r--r-- 1 paul 197121 1177852 Mar 30 2017 ./JC/LEVEL3B_6.png
-rw-r--r-- 1 paul 197121 1557381 Mar 30 2017 ./JC/LEVEL3B_7.png
-rw-r--r-- 1 paul 197121 1668350 Mar 30 2017 ./JC/LEVEL3B_8.png
-rw-r--r-- 1 paul 197121 1007716 Mar 30 2017 ./JC/LEVEL3B_9.png
-rw-r--r-- 1 paul 197121 2021160 Mar 30 2017 ./JC/LEVEL4_0.png
-rw-r--r-- 1 paul 197121 2003693 Mar 30 2017 ./JC/LEVEL4_1.png
-rw-r--r-- 1 paul 197121 1239436 Mar 30 2017 ./JC/LEVEL4_10.png
-rw-r--r-- 1 paul 197121 483590 Apr 3 2017 ./JC/LEVEL4_11.png
-rw-r--r-- 1 paul 197121 1856535 Mar 30 2017 ./JC/LEVEL4_2.png
-rw-r--r-- 1 paul 197121 1977361 Mar 30 2017 ./JC/LEVEL4_3.png
-rw-r--r-- 1 paul 197121 1018792 Mar 30 2017 ./JC/LEVEL4_4.png
-rw-r--r-- 1 paul 197121 1127114 Mar 30 2017 ./JC/LEVEL4_5.png
-rw-r--r-- 1 paul 197121 1568837 Mar 30 2017 ./JC/LEVEL4_6.png
-rw-r--r-- 1 paul 197121 1319792 Mar 30 2017 ./JC/LEVEL4_7.png
-rw-r--r-- 1 paul 197121 1234929 Mar 30 2017 ./JC/LEVEL4_8.png
-rw-r--r-- 1 paul 197121 1447977 Mar 30 2017 ./JC/LEVEL4_9.png
-rw-r--r-- 1 paul 197121 2079939 Mar 30 2017 ./JC/LEVEL5_0.png
-rw-r--r-- 1 paul 197121 1728230 Mar 30 2017 ./JC/LEVEL5_1.png
-rw-r--r-- 1 paul 197121 1463880 Mar 30 2017 ./JC/LEVEL5_2.png
-rw-r--r-- 1 paul 197121 1003744 Mar 30 2017 ./JC/LEVEL5_3.png
-rw-r--r-- 1 paul 197121 1479672 Mar 30 2017 ./JC/LEVEL5_4.png
-rw-r--r-- 1 paul 197121 1336754 Mar 30 2017 ./JC/LEVEL5_5.png
-rw-r--r-- 1 paul 197121 1223673 Mar 30 2017 ./JC/LEVEL5_6.png
-rw-r--r-- 1 paul 197121 1195449 Mar 30 2017 ./JC/LEVEL5_7.png
-rw-r--r-- 1 paul 197121 1366585 Mar 30 2017 ./JC/LEVEL5_8.png
-rw-r--r-- 1 paul 197121 558557 Mar 30 2017 ./JC/LEVEL5_9.png
-rw-r--r-- 1 paul 197121 1992768 Mar 30 2017 ./JC/LEVEL6_0.png
-rw-r--r-- 1 paul 197121 2035776 Mar 30 2017 ./JC/LEVEL6_1.png
-rw-r--r-- 1 paul 197121 1191577 Mar 30 2017 ./JC/LEVEL6_10.png
-rw-r--r-- 1 paul 197121 659783 Mar 30 2017 ./JC/LEVEL6_11.png
-rw-r--r-- 1 paul 197121 1264788 Mar 30 2017 ./JC/LEVEL6_2.png
-rw-r--r-- 1 paul 197121 1891870 Mar 30 2017 ./JC/LEVEL6_3.png
-rw-r--r-- 1 paul 197121 1399832 Mar 30 2017 ./JC/LEVEL6_4.png
-rw-r--r-- 1 paul 197121 1389291 Mar 30 2017 ./JC/LEVEL6_5.png
-rw-r--r-- 1 paul 197121 1714488 Mar 30 2017 ./JC/LEVEL6_6.png
-rw-r--r-- 1 paul 197121 1793682 Mar 30 2017 ./JC/LEVEL6_7.png
-rw-r--r-- 1 paul 197121 1458737 Mar 30 2017 ./JC/LEVEL6_8.png
-rw-r--r-- 1 paul 197121 1399594 Mar 30 2017 ./JC/LEVEL6_9.png
-rw-r--r-- 1 paul 197121 2315022 Apr 2 2017 ./JC/LEVEL7A_0.png
-rw-r--r-- 1 paul 197121 2528134 Mar 30 2017 ./JC/LEVEL7A_1.png
-rw-r--r-- 1 paul 197121 1460209 Mar 30 2017 ./JC/LEVEL7A_2.png
-rw-r--r-- 1 paul 197121 1122272 Mar 30 2017 ./JC/LEVEL7A_3.png
-rw-r--r-- 1 paul 197121 1469928 Mar 30 2017 ./JC/LEVEL7A_4.png
-rw-r--r-- 1 paul 197121 1521292 Mar 30 2017 ./JC/LEVEL7A_5.png
-rw-r--r-- 1 paul 197121 1098869 Mar 30 2017 ./JC/LEVEL7A_6.png
-rw-r--r-- 1 paul 197121 1340332 Mar 30 2017 ./JC/LEVEL7A_7.png
-rw-r--r-- 1 paul 197121 1308195 Mar 30 2017 ./JC/LEVEL7A_8.png
-rw-r--r-- 1 paul 197121 447414 Mar 30 2017 ./JC/LEVEL7A_9.png
-rw-r--r-- 1 paul 197121 2431094 Mar 30 2017 ./JC/LEVEL7B_0.png
-rw-r--r-- 1 paul 197121 2197856 Mar 30 2017 ./JC/LEVEL7B_1.png
-rw-r--r-- 1 paul 197121 1374597 Mar 30 2017 ./JC/LEVEL7B_10.png
-rw-r--r-- 1 paul 197121 1214360 Mar 30 2017 ./JC/LEVEL7B_11.png
-rw-r--r-- 1 paul 197121 492796 Mar 30 2017 ./JC/LEVEL7B_12.png
-rw-r--r-- 1 paul 197121 1697996 Mar 30 2017 ./JC/LEVEL7B_2.png
-rw-r--r-- 1 paul 197121 2127150 Mar 30 2017 ./JC/LEVEL7B_3.png
-rw-r--r-- 1 paul 197121 1666585 Mar 30 2017 ./JC/LEVEL7B_4.png
-rw-r--r-- 1 paul 197121 1594854 Mar 30 2017 ./JC/LEVEL7B_5.png
-rw-r--r-- 1 paul 197121 1677048 Mar 30 2017 ./JC/LEVEL7B_6.png
-rw-r--r-- 1 paul 197121 1306801 Mar 30 2017 ./JC/LEVEL7B_7.png
-rw-r--r-- 1 paul 197121 1235094 Mar 30 2017 ./JC/LEVEL7B_8.png
-rw-r--r-- 1 paul 197121 1482880 Mar 30 2017 ./JC/LEVEL7B_9.png
-rw-r--r-- 1 paul 197121 2340923 Mar 30 2017 ./JC/LEVEL8A_0.png
-rw-r--r-- 1 paul 197121 2203950 Mar 30 2017 ./JC/LEVEL8A_1.png
-rw-r--r-- 1 paul 197121 1100538 Mar 30 2017 ./JC/LEVEL8A_10.png
-rw-r--r-- 1 paul 197121 576229 Mar 30 2017 ./JC/LEVEL8A_11.png
-rw-r--r-- 1 paul 197121 1867626 Mar 30 2017 ./JC/LEVEL8A_2.png
-rw-r--r-- 1 paul 197121 2141027 Mar 30 2017 ./JC/LEVEL8A_3.png
-rw-r--r-- 1 paul 197121 1731233 Mar 30 2017 ./JC/LEVEL8A_4.png
-rw-r--r-- 1 paul 197121 1478150 Mar 30 2017 ./JC/LEVEL8A_5.png
-rw-r--r-- 1 paul 197121 1691326 Mar 30 2017 ./JC/LEVEL8A_6.png
-rw-r--r-- 1 paul 197121 1591868 Mar 30 2017 ./JC/LEVEL8A_7.png
-rw-r--r-- 1 paul 197121 1319557 Mar 30 2017 ./JC/LEVEL8A_8.png
-rw-r--r-- 1 paul 197121 1415582 Mar 30 2017 ./JC/LEVEL8A_9.png
-rw-r--r-- 1 paul 197121 2280505 Mar 30 2017 ./JC/LEVEL8B_0.png
-rw-r--r-- 1 paul 197121 2149893 Mar 30 2017 ./JC/LEVEL8B_1.png
-rw-r--r-- 1 paul 197121 1446768 Mar 30 2017 ./JC/LEVEL8B_10.png
-rw-r--r-- 1 paul 197121 1497237 Mar 30 2017 ./JC/LEVEL8B_11.png
-rw-r--r-- 1 paul 197121 677844 Mar 30 2017 ./JC/LEVEL8B_12.png
-rw-r--r-- 1 paul 197121 1691467 Mar 30 2017 ./JC/LEVEL8B_2.png
-rw-r--r-- 1 paul 197121 2198606 Mar 30 2017 ./JC/LEVEL8B_3.png
-rw-r--r-- 1 paul 197121 1787071 Mar 30 2017 ./JC/LEVEL8B_4.png
-rw-r--r-- 1 paul 197121 1478763 Mar 30 2017 ./JC/LEVEL8B_5.png
-rw-r--r-- 1 paul 197121 1613169 Mar 30 2017 ./JC/LEVEL8B_6.png
-rw-r--r-- 1 paul 197121 1521000 Mar 30 2017 ./JC/LEVEL8B_7.png
-rw-r--r-- 1 paul 197121 1490009 Mar 30 2017 ./JC/LEVEL8B_8.png
-rw-r--r-- 1 paul 197121 1492371 Mar 30 2017 ./JC/LEVEL8B_9.png
-rw-r--r-- 1 paul 197121 2480145 Mar 30 2017 ./JC/LEVEL8C_0.png
-rw-r--r-- 1 paul 197121 2302029 Mar 30 2017 ./JC/LEVEL8C_1.png
-rw-r--r-- 1 paul 197121 1375306 Mar 30 2017 ./JC/LEVEL8C_10.png
-rw-r--r-- 1 paul 197121 461220 Mar 30 2017 ./JC/LEVEL8C_11.png
-rw-r--r-- 1 paul 197121 1653963 Mar 30 2017 ./JC/LEVEL8C_2.png
-rw-r--r-- 1 paul 197121 2300422 Mar 30 2017 ./JC/LEVEL8C_3.png
-rw-r--r-- 1 paul 197121 1472486 Mar 30 2017 ./JC/LEVEL8C_4.png
-rw-r--r-- 1 paul 197121 1563745 Mar 30 2017 ./JC/LEVEL8C_5.png
-rw-r--r-- 1 paul 197121 1482329 Mar 30 2017 ./JC/LEVEL8C_6.png
-rw-r--r-- 1 paul 197121 1255002 Mar 30 2017 ./JC/LEVEL8C_7.png
-rw-r--r-- 1 paul 197121 1465323 Mar 30 2017 ./JC/LEVEL8C_8.png
-rw-r--r-- 1 paul 197121 1475317 Mar 30 2017 ./JC/LEVEL8C_9.png
-rw-r--r-- 1 paul 197121 198824 Mar 30 2017 ./JC/TITLE_0.png
-rw-r--r-- 1 paul 197121 999584 Mar 30 2017 ./JC/TITLE_1.png
-rw-r--r-- 1 paul 197121 359266 Mar 30 2017 ./JC/TITLE_2.png
-rw-r--r-- 1 paul 197121 408157 Mar 30 2017 ./JC/TITLEH.png
-rwxr-xr-x 1 paul 197121 1708032 Mar 4 2017 ./libzplay.dll
-rw-r--r-- 1 paul 197121 17107991 Feb 25 2017 ./music/Track02.flac
-rw-r--r-- 1 paul 197121 5080052 Feb 25 2017 ./music/Track03.flac
-rw-r--r-- 1 paul 197121 10284724 Feb 25 2017 ./music/Track04.flac
-rw-r--r-- 1 paul 197121 6308021 Feb 25 2017 ./music/Track05.flac
-rw-r--r-- 1 paul 197121 7357896 Feb 25 2017 ./music/Track06.flac
-rw-r--r-- 1 paul 197121 4530517 Feb 25 2017 ./music/Track07.flac
-rw-r--r-- 1 paul 197121 7186334 Feb 25 2017 ./music/Track08.flac
-rw-r--r-- 1 paul 197121 2946341 Feb 25 2017 ./music/Track09.flac
-rw-r--r-- 1 paul 197121 6457395 Feb 25 2017 ./music/Track10.flac
-rw-r--r-- 1 paul 197121 536568 Feb 25 2017 ./music/Track11.flac
-rw-r--r-- 1 paul 197121 872102 Feb 25 2017 ./music/Track12.flac
-rw-r--r-- 1 paul 197121 324834 Feb 25 2017 ./music/Track13.flac
-rw-r--r-- 1 paul 197121 488710 Feb 25 2017 ./music/Track14.flac
-rw-r--r-- 1 paul 197121 746525 Feb 25 2017 ./music/Track15.flac
-rw-r--r-- 1 paul 197121 3938186 Feb 25 2017 ./music/Track16.flac
-rw-r--r-- 1 paul 197121 3178106 Feb 25 2017 ./music/Track17.flac
-rw-r--r-- 1 paul 197121 1892140 Feb 25 2017 ./music/Track18.flac
-rw-r--r-- 1 paul 197121 7131055 Feb 25 2017 ./music/Track19.flac
-rw-r--r-- 1 paul 197121 5126872 Feb 25 2017 ./music/Track20.flac
-rw-r--r-- 1 paul 197121 3384664 Feb 25 2017 ./music/Track21.flac
-rw-r--r-- 1 paul 197121 6183961 Feb 25 2017 ./music/Track22.flac
-rw-r--r-- 1 paul 197121 6303706 Feb 25 2017 ./music/Track23.flac
-rw-r--r-- 1 paul 197121 1424583 Feb 25 2017 ./music/Track24.flac
-rw-r--r-- 1 paul 197121 3632194 Feb 25 2017 ./music/Track25.flac
-rw-r--r-- 1 paul 197121 228075 Feb 25 2017 ./music/Track26.flac
-rw-r--r-- 1 paul 197121 193022 Feb 25 2017 ./music/Track27.flac
-rw-r--r-- 1 paul 197121 265645 Feb 25 2017 ./music/Track28.flac
-rw-r--r-- 1 paul 197121 344135 Feb 25 2017 ./music/Track29.flac
-rw-r--r-- 1 paul 197121 497262 Feb 25 2017 ./music/Track30.flac
-rw-r--r-- 1 paul 197121 388520 Feb 25 2017 ./music/Track31.flac
-rw-r--r-- 1 paul 197121 603566 Feb 25 2017 ./music/Track32.flac
-rw-r--r-- 1 paul 197121 569007 Feb 25 2017 ./music/Track33.flac
-rw-r--r-- 1 paul 197121 403009 Feb 25 2017 ./music/Track34.flac
-rw-r--r-- 1 paul 197121 418649 Feb 25 2017 ./music/Track35.flac
-rw-r--r-- 1 paul 197121 1096201 Feb 25 2017 ./music/Track36.flac
-rw-r--r-- 1 paul 197121 149878 Feb 25 2017 ./music/Track37.flac
-rw-r--r-- 1 paul 197121 259172 Feb 25 2017 ./music/Track38.flac
-rw-r--r-- 1 paul 197121 1027596 Feb 25 2017 ./music/Track39.flac
-rw-r--r-- 1 paul 197121 695420 Feb 25 2017 ./music/Track40.flac
-rw-r--r-- 1 paul 197121 50858 Feb 25 2017 ./music/Track41.flac
-rw-r--r-- 1 paul 197121 331411 Feb 25 2017 ./music/Track42.flac
-rw-r--r-- 1 paul 197121 588241 Feb 25 2017 ./music/Track43.flac
-rw-r--r-- 1 paul 197121 518480 Feb 25 2017 ./music/Track44.flac
-rw-r--r-- 1 paul 197121 593401 Feb 25 2017 ./music/Track45.flac
-rw-r--r-- 1 paul 197121 73306 Feb 25 2017 ./music/Track46.flac
-rw-r--r-- 1 paul 197121 108578 Feb 25 2017 ./music/Track47.flac
-rw-r--r-- 1 paul 197121 274209 Feb 25 2017 ./music/Track48.flac
-rw-r--r-- 1 paul 197121 1084390 Feb 25 2017 ./music/Track49.flac
-rw-r--r-- 1 paul 197121 205937 Feb 25 2017 ./music/Track50.flac
-rw-r--r-- 1 paul 197121 96529 Feb 25 2017 ./music/Track51.flac
-rw-r--r-- 1 paul 197121 130657 Feb 25 2017 ./music/Track52.flac
-rw-r--r-- 1 paul 197121 573050 Feb 25 2017 ./music/Track53.flac
-rw-r--r-- 1 paul 197121 261813 Feb 25 2017 ./music/Track54.flac
-rw-r--r-- 1 paul 197121 558967 Feb 25 2017 ./music/Track55.flac
-rw-r--r-- 1 paul 197121 353882 Feb 25 2017 ./music/Track56.flac
-rw-r--r-- 1 paul 197121 7053934 Feb 25 2017 ./music/Track57.flac
-rw-r--r-- 1 paul 197121 16038190 Feb 25 2017 ./music/Track58.flac
-rw-r--r-- 1 paul 197121 11268084 Feb 25 2017 ./music/Track59.flac
-rw-r--r-- 1 paul 197121 11979816 Feb 25 2017 ./music/Track60.flac
-rw-r--r-- 1 paul 197121 520 Feb 25 2017 ./patches/arigs.ini
-rw-r--r-- 1 paul 197121 3994 Aug 8 2023 ./patches/tombati.ini
-rw-r--r-- 1 paul 197121 3794 Aug 8 2023 ./patches/tombub.ini
-rw-r--r-- 1 paul 197121 517 Feb 25 2017 ./patches/wipeout.ini
-rw-r--r-- 1 paul 197121 627 Apr 6 1999 ./readme.txt
-rw-r--r-- 1 paul 197121 10675 Aug 6 2023 ./saveati.0
-rw-r--r-- 1 paul 197121 10675 Aug 6 2023 ./saveati.1
-rw-r--r-- 1 paul 197121 10675 Aug 6 2023 ./saveati.2
-rw-r--r-- 1 paul 197121 10675 Aug 6 2023 ./saveati.3
-rw-r--r-- 1 paul 197121 10675 Aug 6 2023 ./saveati.4
-rw-r--r-- 1 paul 197121 10675 Aug 6 2023 ./saveati.5
-rw-r--r-- 1 paul 197121 10675 Aug 6 2023 ./saveati.6
-rw-r--r-- 1 paul 197121 10675 Aug 6 2023 ./saveati.7
-rw-r--r-- 1 paul 197121 10675 Aug 7 2023 ./saveati.8
-rw-r--r-- 1 paul 197121 11059218 Mar 3 2022 ./screenshot0000.tga
-rw-r--r-- 1 paul 197121 3129 Apr 17 2017 ./shaders/ati3dcif.fsh
-rw-r--r-- 1 paul 197121 512 Feb 25 2017 ./shaders/ati3dcif.vsh
-rw-r--r-- 1 paul 197121 185 Feb 25 2017 ./shaders/ddraw.fsh
-rw-r--r-- 1 paul 197121 233 Apr 9 2017 ./shaders/ddraw.vsh
-rw-r--r-- 1 paul 197121 6153 May 14 2017 ./shortcutJS.bat
-rw-r--r-- 1 paul 197121 2131433 Aug 8 2023 ./Silverlok/CAT_0.png
-rw-r--r-- 1 paul 197121 1511706 Aug 8 2023 ./Silverlok/CAT_1.png
-rw-r--r-- 1 paul 197121 1224759 Aug 8 2023 ./Silverlok/CAT_11.png
-rw-r--r-- 1 paul 197121 559027 Aug 8 2023 ./Silverlok/CAT_12.png
-rw-r--r-- 1 paul 197121 1562891 Aug 8 2023 ./Silverlok/CAT_2.png
-rw-r--r-- 1 paul 197121 1675191 Aug 8 2023 ./Silverlok/CAT_4.png
-rw-r--r-- 1 paul 197121 1368257 Aug 8 2023 ./Silverlok/CAT_5.png
-rw-r--r-- 1 paul 197121 1603611 Aug 8 2023 ./Silverlok/CUT1_0.png
-rw-r--r-- 1 paul 197121 1678922 Aug 8 2023 ./Silverlok/CUT1_1.png
-rw-r--r-- 1 paul 197121 1229073 Aug 8 2023 ./Silverlok/CUT1_2.png
-rw-r--r-- 1 paul 197121 180652 Aug 8 2023 ./Silverlok/CUT1_3.png
-rw-r--r-- 1 paul 197121 1248433 Aug 8 2023 ./Silverlok/CUT2_0.png
-rw-r--r-- 1 paul 197121 1427864 Aug 8 2023 ./Silverlok/CUT2_1.png
-rw-r--r-- 1 paul 197121 368455 Aug 8 2023 ./Silverlok/CUT2_2.png
-rw-r--r-- 1 paul 197121 1414460 Aug 8 2023 ./Silverlok/CUT3_0.png
-rw-r--r-- 1 paul 197121 1840647 Aug 8 2023 ./Silverlok/CUT3_1.png
-rw-r--r-- 1 paul 197121 1242298 Aug 8 2023 ./Silverlok/CUT3_2.png
-rw-r--r-- 1 paul 197121 732460 Aug 8 2023 ./Silverlok/CUT3_3.png
-rw-r--r-- 1 paul 197121 1375847 Aug 8 2023 ./Silverlok/CUT4_0.png
-rw-r--r-- 1 paul 197121 1952578 Aug 8 2023 ./Silverlok/CUT4_1.png
-rw-r--r-- 1 paul 197121 1055487 Aug 8 2023 ./Silverlok/CUT4_2.png
-rw-r--r-- 1 paul 197121 1390514 Aug 8 2023 ./Silverlok/CUT4_3.png
-rw-r--r-- 1 paul 197121 491354 Aug 8 2023 ./Silverlok/CUT4_4.png
-rw-r--r-- 1 paul 197121 1564759 Aug 8 2023 ./Silverlok/EGYPT_0.png
-rw-r--r-- 1 paul 197121 1562723 Aug 8 2023 ./Silverlok/EGYPT_1.png
-rw-r--r-- 1 paul 197121 1145428 Aug 8 2023 ./Silverlok/EGYPT_11.png
-rw-r--r-- 1 paul 197121 351870 Aug 8 2023 ./Silverlok/EGYPT_12.png
-rw-r--r-- 1 paul 197121 1309268 Aug 8 2023 ./Silverlok/EGYPT_2.png
-rw-r--r-- 1 paul 197121 1159206 Aug 8 2023 ./Silverlok/EGYPT_3.png
-rw-r--r-- 1 paul 197121 1659476 Aug 8 2023 ./Silverlok/EGYPT_4.png
-rw-r--r-- 1 paul 197121 1285269 Aug 8 2023 ./Silverlok/EGYPT_5.png
-rw-r--r-- 1 paul 197121 1456321 Aug 8 2023 ./Silverlok/END_0.png
-rw-r--r-- 1 paul 197121 1766781 Aug 8 2023 ./Silverlok/END_1.png
-rw-r--r-- 1 paul 197121 1102843 Aug 8 2023 ./Silverlok/END_10.png
-rw-r--r-- 1 paul 197121 938137 Aug 8 2023 ./Silverlok/END_11.png
-rw-r--r-- 1 paul 197121 507424 Aug 8 2023 ./Silverlok/END_12.png
-rw-r--r-- 1 paul 197121 2116595 Aug 8 2023 ./Silverlok/END_2.png
-rw-r--r-- 1 paul 197121 1228879 Aug 8 2023 ./Silverlok/END_3.png
-rw-r--r-- 1 paul 197121 1787547 Aug 8 2023 ./Silverlok/END_4.png
-rw-r--r-- 1 paul 197121 1592115 Aug 8 2023 ./Silverlok/END_8.png
-rw-r--r-- 1 paul 197121 1251236 Aug 8 2023 ./Silverlok/END_9.png
-rw-r--r-- 1 paul 197121 1442710 Aug 8 2023 ./Silverlok/END2_0.png
-rw-r--r-- 1 paul 197121 1750225 Aug 8 2023 ./Silverlok/END2_1.png
-rw-r--r-- 1 paul 197121 1111503 Aug 8 2023 ./Silverlok/END2_10.png
-rw-r--r-- 1 paul 197121 931792 Aug 8 2023 ./Silverlok/END2_11.png
-rw-r--r-- 1 paul 197121 362793 Aug 8 2023 ./Silverlok/END2_12.png
-rw-r--r-- 1 paul 197121 2132211 Aug 8 2023 ./Silverlok/END2_2.png
-rw-r--r-- 1 paul 197121 1353604 Aug 8 2023 ./Silverlok/GYM_0.png
-rw-r--r-- 1 paul 197121 1191639 Aug 8 2023 ./Silverlok/GYM_1.png
-rw-r--r-- 1 paul 197121 1357247 Aug 8 2023 ./Silverlok/GYM_2.png
-rw-r--r-- 1 paul 197121 1271710 Aug 8 2023 ./Silverlok/GYM_3.png
-rw-r--r-- 1 paul 197121 1971174 Aug 8 2023 ./Silverlok/GYM_4.png
-rw-r--r-- 1 paul 197121 1465018 Aug 8 2023 ./Silverlok/GYM_5.png
-rw-r--r-- 1 paul 197121 1227368 Aug 8 2023 ./Silverlok/GYM_6.png
-rw-r--r-- 1 paul 197121 1239374 Aug 8 2023 ./Silverlok/GYM_7.png
-rw-r--r-- 1 paul 197121 908214 Aug 8 2023 ./Silverlok/GYM_8.png
-rw-r--r-- 1 paul 197121 11341 Aug 8 2023 ./Silverlok/keys.txt
-rw-r--r-- 1 paul 197121 1341294 Aug 8 2023 ./Silverlok/LEVEL1_0.png
-rw-r--r-- 1 paul 197121 1496230 Aug 8 2023 ./Silverlok/LEVEL1_1.png
-rw-r--r-- 1 paul 197121 394220 Aug 8 2023 ./Silverlok/LEVEL1_10.png
-rw-r--r-- 1 paul 197121 1389435 Aug 8 2023 ./Silverlok/LEVEL1_2.png
-rw-r--r-- 1 paul 197121 1419429 Aug 8 2023 ./Silverlok/LEVEL1_3.png
-rw-r--r-- 1 paul 197121 2063861 Aug 8 2023 ./Silverlok/LEVEL1_4.png
-rw-r--r-- 1 paul 197121 2127932 Aug 8 2023 ./Silverlok/LEVEL1_5.png
-rw-r--r-- 1 paul 197121 1668683 Aug 8 2023 ./Silverlok/LEVEL1_6.png
-rw-r--r-- 1 paul 197121 1089763 Aug 8 2023 ./Silverlok/LEVEL1_7.png
-rw-r--r-- 1 paul 197121 1448949 Aug 8 2023 ./Silverlok/LEVEL1_8.png
-rw-r--r-- 1 paul 197121 1085167 Aug 8 2023 ./Silverlok/LEVEL1_9.png
-rw-r--r-- 1 paul 197121 1208763 Aug 8 2023 ./Silverlok/LEVEL10A_0.png
-rw-r--r-- 1 paul 197121 1242197 Aug 8 2023 ./Silverlok/LEVEL10A_1.png
-rw-r--r-- 1 paul 197121 1140354 Aug 8 2023 ./Silverlok/LEVEL10A_10.png
-rw-r--r-- 1 paul 197121 1046082 Aug 8 2023 ./Silverlok/LEVEL10A_11.png
-rw-r--r-- 1 paul 197121 171413 Aug 8 2023 ./Silverlok/LEVEL10A_12.png
-rw-r--r-- 1 paul 197121 2598077 Aug 8 2023 ./Silverlok/LEVEL10A_2.png
-rw-r--r-- 1 paul 197121 1256771 Aug 8 2023 ./Silverlok/LEVEL10A_3.png
-rw-r--r-- 1 paul 197121 1346635 Aug 8 2023 ./Silverlok/LEVEL10A_4.png
-rw-r--r-- 1 paul 197121 1994884 Aug 8 2023 ./Silverlok/LEVEL10A_5.png
-rw-r--r-- 1 paul 197121 2180319 Aug 8 2023 ./Silverlok/LEVEL10A_6.png
-rw-r--r-- 1 paul 197121 1771952 Aug 8 2023 ./Silverlok/LEVEL10A_7.png
-rw-r--r-- 1 paul 197121 1621853 Aug 8 2023 ./Silverlok/LEVEL10A_8.png
-rw-r--r-- 1 paul 197121 1615178 Aug 8 2023 ./Silverlok/LEVEL10A_9.png
-rw-r--r-- 1 paul 197121 1639006 Aug 8 2023 ./Silverlok/LEVEL10B_1.png
-rw-r--r-- 1 paul 197121 1154468 Aug 8 2023 ./Silverlok/LEVEL10B_10.png
-rw-r--r-- 1 paul 197121 974455 Aug 8 2023 ./Silverlok/LEVEL10B_11.png
-rw-r--r-- 1 paul 197121 281962 Aug 8 2023 ./Silverlok/LEVEL10B_12.png
-rw-r--r-- 1 paul 197121 1967613 Aug 8 2023 ./Silverlok/LEVEL10B_2.png
-rw-r--r-- 1 paul 197121 1097912 Aug 8 2023 ./Silverlok/LEVEL10B_3.png
-rw-r--r-- 1 paul 197121 1840224 Aug 8 2023 ./Silverlok/LEVEL10B_4.png
-rw-r--r-- 1 paul 197121 1735203 Aug 8 2023 ./Silverlok/LEVEL10B_5.png
-rw-r--r-- 1 paul 197121 2044904 Aug 8 2023 ./Silverlok/LEVEL10B_6.png
-rw-r--r-- 1 paul 197121 1623233 Aug 8 2023 ./Silverlok/LEVEL10B_7.png
-rw-r--r-- 1 paul 197121 1586069 Aug 8 2023 ./Silverlok/LEVEL10B_8.png
-rw-r--r-- 1 paul 197121 1240695 Aug 8 2023 ./Silverlok/LEVEL10B_9.png
-rw-r--r-- 1 paul 197121 1456533 Aug 8 2023 ./Silverlok/LEVEL10C_0.png
-rw-r--r-- 1 paul 197121 1361312 Aug 8 2023 ./Silverlok/LEVEL10C_1.png
-rw-r--r-- 1 paul 197121 1072918 Aug 8 2023 ./Silverlok/LEVEL10C_10.png
-rw-r--r-- 1 paul 197121 899791 Aug 8 2023 ./Silverlok/LEVEL10C_11.png
-rw-r--r-- 1 paul 197121 587637 Aug 8 2023 ./Silverlok/LEVEL10C_12.png
-rw-r--r-- 1 paul 197121 2047059 Aug 8 2023 ./Silverlok/LEVEL10C_2.png
-rw-r--r-- 1 paul 197121 1157230 Aug 8 2023 ./Silverlok/LEVEL10C_3.png
-rw-r--r-- 1 paul 197121 1938248 Aug 8 2023 ./Silverlok/LEVEL10C_4.png
-rw-r--r-- 1 paul 197121 1636441 Aug 8 2023 ./Silverlok/LEVEL10C_5.png
-rw-r--r-- 1 paul 197121 1999148 Aug 8 2023 ./Silverlok/LEVEL10C_6.png
-rw-r--r-- 1 paul 197121 1473577 Aug 8 2023 ./Silverlok/LEVEL10C_7.png
-rw-r--r-- 1 paul 197121 1584902 Aug 8 2023 ./Silverlok/LEVEL10C_8.png
-rw-r--r-- 1 paul 197121 1229098 Aug 8 2023 ./Silverlok/LEVEL10C_9.png
-rw-r--r-- 1 paul 197121 1464077 Aug 8 2023 ./Silverlok/LEVEL2_0.png
-rw-r--r-- 1 paul 197121 1515164 Aug 8 2023 ./Silverlok/LEVEL2_1.png
-rw-r--r-- 1 paul 197121 1249061 Aug 8 2023 ./Silverlok/LEVEL2_10.png
-rw-r--r-- 1 paul 197121 1057545 Aug 8 2023 ./Silverlok/LEVEL2_11.png
-rw-r--r-- 1 paul 197121 185484 Aug 8 2023 ./Silverlok/LEVEL2_12.png
-rw-r--r-- 1 paul 197121 1925254 Aug 8 2023 ./Silverlok/LEVEL2_2.png
-rw-r--r-- 1 paul 197121 1464155 Aug 8 2023 ./Silverlok/LEVEL2_3.png
-rw-r--r-- 1 paul 197121 1490170 Aug 8 2023 ./Silverlok/LEVEL2_4.png
-rw-r--r-- 1 paul 197121 1809301 Aug 8 2023 ./Silverlok/LEVEL2_5.png
-rw-r--r-- 1 paul 197121 1964804 Aug 8 2023 ./Silverlok/LEVEL2_6.png
-rw-r--r-- 1 paul 197121 1888123 Aug 8 2023 ./Silverlok/LEVEL2_7.png
-rw-r--r-- 1 paul 197121 1486630 Aug 8 2023 ./Silverlok/LEVEL2_8.png
-rw-r--r-- 1 paul 197121 1262494 Aug 8 2023 ./Silverlok/LEVEL2_9.png
-rw-r--r-- 1 paul 197121 1435197 Aug 8 2023 ./Silverlok/LEVEL3A_0.png
-rw-r--r-- 1 paul 197121 1946628 Aug 8 2023 ./Silverlok/LEVEL3A_1.png
-rw-r--r-- 1 paul 197121 1303545 Aug 8 2023 ./Silverlok/LEVEL3A_10.png
-rw-r--r-- 1 paul 197121 491115 Aug 8 2023 ./Silverlok/LEVEL3A_11.png
-rw-r--r-- 1 paul 197121 1379922 Aug 8 2023 ./Silverlok/LEVEL3A_2.png
-rw-r--r-- 1 paul 197121 1424862 Aug 8 2023 ./Silverlok/LEVEL3A_3.png
-rw-r--r-- 1 paul 197121 1963620 Aug 8 2023 ./Silverlok/LEVEL3A_4.png
-rw-r--r-- 1 paul 197121 2028375 Aug 8 2023 ./Silverlok/LEVEL3A_5.png
-rw-r--r-- 1 paul 197121 1438118 Aug 8 2023 ./Silverlok/LEVEL3A_6.png
-rw-r--r-- 1 paul 197121 1496237 Aug 8 2023 ./Silverlok/LEVEL3A_7.png
-rw-r--r-- 1 paul 197121 1433448 Aug 8 2023 ./Silverlok/LEVEL3A_8.png
-rw-r--r-- 1 paul 197121 1275264 Aug 8 2023 ./Silverlok/LEVEL3A_9.png
-rw-r--r-- 1 paul 197121 1431982 Aug 8 2023 ./Silverlok/LEVEL3B_0.png
-rw-r--r-- 1 paul 197121 1774197 Aug 8 2023 ./Silverlok/LEVEL3B_1.png
-rw-r--r-- 1 paul 197121 543741 Aug 8 2023 ./Silverlok/LEVEL3B_10.png
-rw-r--r-- 1 paul 197121 1319499 Aug 8 2023 ./Silverlok/LEVEL3B_2.png
-rw-r--r-- 1 paul 197121 2328006 Aug 8 2023 ./Silverlok/LEVEL3B_3.png
-rw-r--r-- 1 paul 197121 1957447 Aug 8 2023 ./Silverlok/LEVEL3B_4.png
-rw-r--r-- 1 paul 197121 1508978 Aug 8 2023 ./Silverlok/LEVEL3B_5.png
-rw-r--r-- 1 paul 197121 1352977 Aug 8 2023 ./Silverlok/LEVEL3B_6.png
-rw-r--r-- 1 paul 197121 1183268 Aug 8 2023 ./Silverlok/LEVEL3B_7.png
-rw-r--r-- 1 paul 197121 1165177 Aug 8 2023 ./Silverlok/LEVEL3B_8.png
-rw-r--r-- 1 paul 197121 1320003 Aug 8 2023 ./Silverlok/LEVEL3B_9.png
-rw-r--r-- 1 paul 197121 1395709 Aug 8 2023 ./Silverlok/LEVEL4_0.png
-rw-r--r-- 1 paul 197121 1424425 Aug 8 2023 ./Silverlok/LEVEL4_1.png
-rw-r--r-- 1 paul 197121 1119993 Aug 8 2023 ./Silverlok/LEVEL4_10.png
-rw-r--r-- 1 paul 197121 619733 Aug 8 2023 ./Silverlok/LEVEL4_11.png
-rw-r--r-- 1 paul 197121 1595062 Aug 8 2023 ./Silverlok/LEVEL4_2.png
-rw-r--r-- 1 paul 197121 1710261 Aug 8 2023 ./Silverlok/LEVEL4_3.png
-rw-r--r-- 1 paul 197121 1373953 Aug 8 2023 ./Silverlok/LEVEL4_4.png
-rw-r--r-- 1 paul 197121 2231234 Aug 8 2023 ./Silverlok/LEVEL4_5.png
-rw-r--r-- 1 paul 197121 2008010 Aug 8 2023 ./Silverlok/LEVEL4_6.png
-rw-r--r-- 1 paul 197121 1752998 Aug 8 2023 ./Silverlok/LEVEL4_7.png
-rw-r--r-- 1 paul 197121 1419421 Aug 8 2023 ./Silverlok/LEVEL4_8.png
-rw-r--r-- 1 paul 197121 1284214 Aug 8 2023 ./Silverlok/LEVEL4_9.png
-rw-r--r-- 1 paul 197121 1479657 Aug 8 2023 ./Silverlok/LEVEL5_0.png
-rw-r--r-- 1 paul 197121 1405107 Aug 8 2023 ./Silverlok/LEVEL5_1.png
-rw-r--r-- 1 paul 197121 1792551 Aug 8 2023 ./Silverlok/LEVEL5_2.png
-rw-r--r-- 1 paul 197121 1377278 Aug 8 2023 ./Silverlok/LEVEL5_3.png
-rw-r--r-- 1 paul 197121 2142244 Aug 8 2023 ./Silverlok/LEVEL5_4.png
-rw-r--r-- 1 paul 197121 1846429 Aug 8 2023 ./Silverlok/LEVEL5_5.png
-rw-r--r-- 1 paul 197121 1607202 Aug 8 2023 ./Silverlok/LEVEL5_6.png
-rw-r--r-- 1 paul 197121 1389665 Aug 8 2023 ./Silverlok/LEVEL5_7.png
-rw-r--r-- 1 paul 197121 993968 Aug 8 2023 ./Silverlok/LEVEL5_8.png
-rw-r--r-- 1 paul 197121 672393 Aug 8 2023 ./Silverlok/LEVEL5_9.png
-rw-r--r-- 1 paul 197121 1452608 Aug 8 2023 ./Silverlok/LEVEL6_0.png
-rw-r--r-- 1 paul 197121 1418333 Aug 8 2023 ./Silverlok/LEVEL6_1.png
-rw-r--r-- 1 paul 197121 1294980 Aug 8 2023 ./Silverlok/LEVEL6_10.png
-rw-r--r-- 1 paul 197121 891203 Aug 8 2023 ./Silverlok/LEVEL6_11.png
-rw-r--r-- 1 paul 197121 1829194 Aug 8 2023 ./Silverlok/LEVEL6_2.png
-rw-r--r-- 1 paul 197121 1427419 Aug 8 2023 ./Silverlok/LEVEL6_3.png
-rw-r--r-- 1 paul 197121 1388254 Aug 8 2023 ./Silverlok/LEVEL6_4.png
-rw-r--r-- 1 paul 197121 1459722 Aug 8 2023 ./Silverlok/LEVEL6_5.png
-rw-r--r-- 1 paul 197121 1849914 Aug 8 2023 ./Silverlok/LEVEL6_6.png
-rw-r--r-- 1 paul 197121 2095507 Aug 8 2023 ./Silverlok/LEVEL6_7.png
-rw-r--r-- 1 paul 197121 1660677 Aug 8 2023 ./Silverlok/LEVEL6_8.png
-rw-r--r-- 1 paul 197121 1330771 Aug 8 2023 ./Silverlok/LEVEL6_9.png
-rw-r--r-- 1 paul 197121 1373756 Aug 8 2023 ./Silverlok/LEVEL7A_0.png
-rw-r--r-- 1 paul 197121 1411566 Aug 8 2023 ./Silverlok/LEVEL7A_1.png
-rw-r--r-- 1 paul 197121 1731565 Aug 8 2023 ./Silverlok/LEVEL7A_2.png
-rw-r--r-- 1 paul 197121 1376314 Aug 8 2023 ./Silverlok/LEVEL7A_3.png
-rw-r--r-- 1 paul 197121 1495496 Aug 8 2023 ./Silverlok/LEVEL7A_4.png
-rw-r--r-- 1 paul 197121 1973872 Aug 8 2023 ./Silverlok/LEVEL7A_5.png
-rw-r--r-- 1 paul 197121 1406154 Aug 8 2023 ./Silverlok/LEVEL7A_6.png
-rw-r--r-- 1 paul 197121 1171898 Aug 8 2023 ./Silverlok/LEVEL7A_7.png
-rw-r--r-- 1 paul 197121 1079380 Aug 8 2023 ./Silverlok/LEVEL7A_8.png
-rw-r--r-- 1 paul 197121 517318 Aug 8 2023 ./Silverlok/LEVEL7A_9.png
-rw-r--r-- 1 paul 197121 1458115 Aug 8 2023 ./Silverlok/LEVEL7B_0.png
-rw-r--r-- 1 paul 197121 1394866 Aug 8 2023 ./Silverlok/LEVEL7B_1.png
-rw-r--r-- 1 paul 197121 1061325 Aug 8 2023 ./Silverlok/LEVEL7B_10.png
-rw-r--r-- 1 paul 197121 989980 Aug 8 2023 ./Silverlok/LEVEL7B_11.png
-rw-r--r-- 1 paul 197121 520570 Aug 8 2023 ./Silverlok/LEVEL7B_12.png
-rw-r--r-- 1 paul 197121 1797974 Aug 8 2023 ./Silverlok/LEVEL7B_2.png
-rw-r--r-- 1 paul 197121 1554928 Aug 8 2023 ./Silverlok/LEVEL7B_3.png
-rw-r--r-- 1 paul 197121 1905149 Aug 8 2023 ./Silverlok/LEVEL7B_4.png
-rw-r--r-- 1 paul 197121 1726281 Aug 8 2023 ./Silverlok/LEVEL7B_5.png
-rw-r--r-- 1 paul 197121 1880880 Aug 8 2023 ./Silverlok/LEVEL7B_6.png
-rw-r--r-- 1 paul 197121 1753890 Aug 8 2023 ./Silverlok/LEVEL7B_7.png
-rw-r--r-- 1 paul 197121 1471853 Aug 8 2023 ./Silverlok/LEVEL7B_8.png
-rw-r--r-- 1 paul 197121 1265830 Aug 8 2023 ./Silverlok/LEVEL7B_9.png
-rw-r--r-- 1 paul 197121 1543300 Aug 8 2023 ./Silverlok/LEVEL8A_0.png
-rw-r--r-- 1 paul 197121 1425344 Aug 8 2023 ./Silverlok/LEVEL8A_1.png
-rw-r--r-- 1 paul 197121 1228346 Aug 8 2023 ./Silverlok/LEVEL8A_10.png
-rw-r--r-- 1 paul 197121 654597 Aug 8 2023 ./Silverlok/LEVEL8A_11.png
-rw-r--r-- 1 paul 197121 1725660 Aug 8 2023 ./Silverlok/LEVEL8A_2.png
-rw-r--r-- 1 paul 197121 1220258 Aug 8 2023 ./Silverlok/LEVEL8A_3.png
-rw-r--r-- 1 paul 197121 1360996 Aug 8 2023 ./Silverlok/LEVEL8A_4.png
-rw-r--r-- 1 paul 197121 1654549 Aug 8 2023 ./Silverlok/LEVEL8A_5.png
-rw-r--r-- 1 paul 197121 1582203 Aug 8 2023 ./Silverlok/LEVEL8A_6.png
-rw-r--r-- 1 paul 197121 1571355 Aug 8 2023 ./Silverlok/LEVEL8A_7.png
-rw-r--r-- 1 paul 197121 1581231 Aug 8 2023 ./Silverlok/LEVEL8A_8.png
-rw-r--r-- 1 paul 197121 1323496 Aug 8 2023 ./Silverlok/LEVEL8A_9.png
-rw-r--r-- 1 paul 197121 1550114 Aug 8 2023 ./Silverlok/LEVEL8B_0.png
-rw-r--r-- 1 paul 197121 1428814 Aug 8 2023 ./Silverlok/LEVEL8B_1.png
-rw-r--r-- 1 paul 197121 1352982 Aug 8 2023 ./Silverlok/LEVEL8B_10.png
-rw-r--r-- 1 paul 197121 1425467 Aug 8 2023 ./Silverlok/LEVEL8B_11.png
-rw-r--r-- 1 paul 197121 798249 Aug 8 2023 ./Silverlok/LEVEL8B_12.png
-rw-r--r-- 1 paul 197121 1687777 Aug 8 2023 ./Silverlok/LEVEL8B_2.png
-rw-r--r-- 1 paul 197121 1263826 Aug 8 2023 ./Silverlok/LEVEL8B_3.png
-rw-r--r-- 1 paul 197121 1430185 Aug 8 2023 ./Silverlok/LEVEL8B_4.png
-rw-r--r-- 1 paul 197121 1654292 Aug 8 2023 ./Silverlok/LEVEL8B_5.png
-rw-r--r-- 1 paul 197121 1529041 Aug 8 2023 ./Silverlok/LEVEL8B_6.png
-rw-r--r-- 1 paul 197121 1806910 Aug 8 2023 ./Silverlok/LEVEL8B_7.png
-rw-r--r-- 1 paul 197121 1566380 Aug 8 2023 ./Silverlok/LEVEL8B_8.png
-rw-r--r-- 1 paul 197121 1245355 Aug 8 2023 ./Silverlok/LEVEL8B_9.png
-rw-r--r-- 1 paul 197121 1479268 Aug 8 2023 ./Silverlok/LEVEL8C_0.png
-rw-r--r-- 1 paul 197121 1474569 Aug 8 2023 ./Silverlok/LEVEL8C_1.png
-rw-r--r-- 1 paul 197121 1358706 Aug 8 2023 ./Silverlok/LEVEL8C_10.png
-rw-r--r-- 1 paul 197121 567497 Aug 8 2023 ./Silverlok/LEVEL8C_11.png
-rw-r--r-- 1 paul 197121 1678548 Aug 8 2023 ./Silverlok/LEVEL8C_2.png
-rw-r--r-- 1 paul 197121 1332696 Aug 8 2023 ./Silverlok/LEVEL8C_3.png
-rw-r--r-- 1 paul 197121 1498507 Aug 8 2023 ./Silverlok/LEVEL8C_4.png
-rw-r--r-- 1 paul 197121 1932335 Aug 8 2023 ./Silverlok/LEVEL8C_5.png
-rw-r--r-- 1 paul 197121 1566534 Aug 8 2023 ./Silverlok/LEVEL8C_6.png
-rw-r--r-- 1 paul 197121 1359484 Aug 8 2023 ./Silverlok/LEVEL8C_7.png
-rw-r--r-- 1 paul 197121 1108137 Aug 8 2023 ./Silverlok/LEVEL8C_8.png
-rw-r--r-- 1 paul 197121 1638112 Aug 8 2023 ./Silverlok/LEVEL8C_9.png
-rw-r--r-- 1 paul 197121 330041 Aug 8 2023 ./Silverlok/TITLE_0.png
-rw-r--r-- 1 paul 197121 1377973 Aug 8 2023 ./Silverlok/TITLE_1.png
-rw-r--r-- 1 paul 197121 452607 Aug 8 2023 ./Silverlok/TITLE_2.png
-rw-r--r-- 1 paul 197121 371206 Aug 8 2023 ./Silverlok/TITLEH.png
-rw-r--r-- 1 paul 197121 26759 Aug 21 2023 ./Silverlok/unins000.dat
-rwxr-xr-x 1 paul 197121 3247677 Aug 21 2023 ./Silverlok/unins000.exe
-rw-r--r-- 1 paul 197121 11888 Feb 15 2006 ./TOMB.SP
-rwxr-xr-x 1 paul 197121 396800 Apr 6 1999 ./tombati.exe
-rw-r--r-- 1 paul 197121 4286 Mar 4 2017 ./TombATI.ico
-rwxr-xr-x 1 paul 197121 3580416 May 22 2017 ./TombATIConfigure.exe
-rw-r--r-- 1 paul 197121 136 Apr 6 1999 ./Tombraider.txt
-rwxr-xr-x 1 paul 197121 3470336 Feb 27 2022 ./TombRaiderImporter.exe
-r-xr-xr-x 1 paul 197121 392704 Feb 13 1998 ./Tombub.exe
-rw-r--r-- 1 paul 197121 1107093 Feb 7 2017 ./TR1HD/CAT_7.png
-rw-r--r-- 1 paul 197121 369718 Feb 7 2017 ./TR1HD/CAT_8.png
-rw-r--r-- 1 paul 197121 1699938 Feb 7 2017 ./TR1HD/CUT1_0.png
-rw-r--r-- 1 paul 197121 779697 Feb 7 2017 ./TR1HD/CUT1_1.png
-rw-r--r-- 1 paul 197121 1310043 Feb 7 2017 ./TR1HD/CUT2_0.png
-rw-r--r-- 1 paul 197121 2177398 Feb 7 2017 ./TR1HD/CUT3_0.png
-rw-r--r-- 1 paul 197121 1583157 Feb 7 2017 ./TR1HD/CUT3_1.png
-rw-r--r-- 1 paul 197121 559036 Feb 7 2017 ./TR1HD/CUT3_2.png
-rw-r--r-- 1 paul 197121 2138066 Feb 7 2017 ./TR1HD/CUT4_0.png
-rw-r--r-- 1 paul 197121 94273 Feb 7 2017 ./TR1HD/EGYPT_0.png
-rw-r--r-- 1 paul 197121 230196 Feb 7 2017 ./TR1HD/EGYPT_1.png
-rw-r--r-- 1 paul 197121 222350 Feb 7 2017 ./TR1HD/EGYPT_2.png
-rw-r--r-- 1 paul 197121 184063 Feb 7 2017 ./TR1HD/EGYPT_3.png
-rw-r--r-- 1 paul 197121 211267 Feb 7 2017 ./TR1HD/EGYPT_4.png
-rw-r--r-- 1 paul 197121 1107093 Feb 7 2017 ./TR1HD/EGYPT_7.png
-rw-r--r-- 1 paul 197121 371640 Feb 7 2017 ./TR1HD/EGYPT_8.png
-rw-r--r-- 1 paul 197121 776427 Feb 7 2017 ./TR1HD/END_5.png
-rw-r--r-- 1 paul 197121 560927 Feb 7 2017 ./TR1HD/END_6.png
-rw-r--r-- 1 paul 197121 776427 Feb 7 2017 ./TR1HD/END2_5.png
-rw-r--r-- 1 paul 197121 560231 Feb 7 2017 ./TR1HD/END2_6.png
-rw-r--r-- 1 paul 197121 821024 Feb 7 2017 ./TR1HD/GYM_0.png
-rw-r--r-- 1 paul 197121 700825 Feb 7 2017 ./TR1HD/GYM_1.png
-rw-r--r-- 1 paul 197121 707888 Feb 7 2017 ./TR1HD/GYM_2.png
-rw-r--r-- 1 paul 197121 1193490 Feb 7 2017 ./TR1HD/GYM_3.png
-rw-r--r-- 1 paul 197121 917573 Feb 7 2017 ./TR1HD/GYM_4.png
-rw-r--r-- 1 paul 197121 310697 Feb 7 2017 ./TR1HD/GYM_5.png
-rw-r--r-- 1 paul 197121 316445 Feb 7 2017 ./TR1HD/GYM_6.png
-rw-r--r-- 1 paul 197121 200865 Feb 7 2017 ./TR1HD/GYM_7.png
-rw-r--r-- 1 paul 197121 10025 Feb 26 2017 ./TR1HD/keys.txt
-rw-r--r-- 1 paul 197121 9247 Feb 11 2017 ./TR1HD/keys.txt~
-rw-r--r-- 1 paul 197121 1409519 Feb 7 2017 ./TR1HD/LEVEL1_0.png
-rw-r--r-- 1 paul 197121 1527220 Feb 7 2017 ./TR1HD/LEVEL1_1.png
-rw-r--r-- 1 paul 197121 56215 Feb 7 2017 ./TR1HD/LEVEL1_10.png
-rw-r--r-- 1 paul 197121 1571437 Feb 7 2017 ./TR1HD/LEVEL1_2.png
-rw-r--r-- 1 paul 197121 4284789 Feb 7 2017 ./TR1HD/LEVEL1_3.png
-rw-r--r-- 1 paul 197121 858618 Feb 7 2017 ./TR1HD/LEVEL1_4.png
-rw-r--r-- 1 paul 197121 1200846 Feb 7 2017 ./TR1HD/LEVEL1_5.png
-rw-r--r-- 1 paul 197121 185110 Feb 7 2017 ./TR1HD/LEVEL1_6.png
-rw-r--r-- 1 paul 197121 484207 Feb 7 2017 ./TR1HD/LEVEL1_7.png
-rw-r--r-- 1 paul 197121 269792 Feb 7 2017 ./TR1HD/LEVEL1_8.png
-rw-r--r-- 1 paul 197121 258210 Feb 7 2017 ./TR1HD/LEVEL1_9.png
-rw-r--r-- 1 paul 197121 2018243 Feb 7 2017 ./TR1HD/LEVEL10A_0.png
-rw-r--r-- 1 paul 197121 1768718 Feb 7 2017 ./TR1HD/LEVEL10A_1.png
-rw-r--r-- 1 paul 197121 1067546 Feb 7 2017 ./TR1HD/LEVEL10A_2.png
-rw-r--r-- 1 paul 197121 2022885 Feb 7 2017 ./TR1HD/LEVEL10A_3.png
-rw-r--r-- 1 paul 197121 1080918 Feb 7 2017 ./TR1HD/LEVEL10A_4.png
-rw-r--r-- 1 paul 197121 1294088 Feb 7 2017 ./TR1HD/LEVEL10A_5.png
-rw-r--r-- 1 paul 197121 1631956 Feb 7 2017 ./TR1HD/LEVEL10A_6.png
-rw-r--r-- 1 paul 197121 2200694 Feb 7 2017 ./TR1HD/LEVEL10B_0.png
-rw-r--r-- 1 paul 197121 1928719 Feb 7 2017 ./TR1HD/LEVEL10B_1.png
-rw-r--r-- 1 paul 197121 1490761 Feb 7 2017 ./TR1HD/LEVEL10B_2.png
-rw-r--r-- 1 paul 197121 1867513 Feb 7 2017 ./TR1HD/LEVEL10B_3.png
-rw-r--r-- 1 paul 197121 1285526 Feb 7 2017 ./TR1HD/LEVEL10B_5.png
-rw-r--r-- 1 paul 197121 1638051 Feb 7 2017 ./TR1HD/LEVEL10B_6.png
-rw-r--r-- 1 paul 197121 2200694 Feb 7 2017 ./TR1HD/LEVEL10C_0.png
-rw-r--r-- 1 paul 197121 2044820 Feb 7 2017 ./TR1HD/LEVEL10C_1.png
-rw-r--r-- 1 paul 197121 1441861 Feb 7 2017 ./TR1HD/LEVEL10C_2.png
-rw-r--r-- 1 paul 197121 1860127 Feb 7 2017 ./TR1HD/LEVEL10C_3.png
-rw-r--r-- 1 paul 197121 1010613 Feb 7 2017 ./TR1HD/LEVEL10C_5.png
-rw-r--r-- 1 paul 197121 1648712 Feb 7 2017 ./TR1HD/LEVEL10C_6.png
-rw-r--r-- 1 paul 197121 1791915 Feb 7 2017 ./TR1HD/LEVEL2_0.png
-rw-r--r-- 1 paul 197121 1572050 Feb 7 2017 ./TR1HD/LEVEL2_1.png
-rw-r--r-- 1 paul 197121 68013 Feb 7 2017 ./TR1HD/LEVEL2_10.png
-rw-r--r-- 1 paul 197121 1225353 Feb 7 2017 ./TR1HD/LEVEL2_2.png
-rw-r--r-- 1 paul 197121 1607374 Feb 7 2017 ./TR1HD/LEVEL2_3.png
-rw-r--r-- 1 paul 197121 839460 Feb 7 2017 ./TR1HD/LEVEL2_4.png
-rw-r--r-- 1 paul 197121 1062838 Feb 7 2017 ./TR1HD/LEVEL2_5.png
-rw-r--r-- 1 paul 197121 1211103 Feb 7 2017 ./TR1HD/LEVEL2_6.png
-rw-r--r-- 1 paul 197121 708012 Feb 7 2017 ./TR1HD/LEVEL2_7.png
-rw-r--r-- 1 paul 197121 472722 Feb 7 2017 ./TR1HD/LEVEL2_8.png
-rw-r--r-- 1 paul 197121 196138 Feb 7 2017 ./TR1HD/LEVEL2_9.png
-rw-r--r-- 1 paul 197121 1853249 Feb 7 2017 ./TR1HD/LEVEL3A_0.png
-rw-r--r-- 1 paul 197121 1241568 Feb 7 2017 ./TR1HD/LEVEL3A_1.png
-rw-r--r-- 1 paul 197121 199477 Feb 7 2017 ./TR1HD/LEVEL3A_10.png
-rw-r--r-- 1 paul 197121 1599911 Feb 7 2017 ./TR1HD/LEVEL3A_2.png
-rw-r--r-- 1 paul 197121 1266510 Feb 7 2017 ./TR1HD/LEVEL3A_3.png
-rw-r--r-- 1 paul 197121 857219 Feb 7 2017 ./TR1HD/LEVEL3A_4.png
-rw-r--r-- 1 paul 197121 1102003 Feb 7 2017 ./TR1HD/LEVEL3A_5.png
-rw-r--r-- 1 paul 197121 339464 Feb 7 2017 ./TR1HD/LEVEL3A_6.png
-rw-r--r-- 1 paul 197121 1776906 Feb 7 2017 ./TR1HD/LEVEL3B_0.png
-rw-r--r-- 1 paul 197121 1158100 Feb 7 2017 ./TR1HD/LEVEL3B_1.png
-rw-r--r-- 1 paul 197121 1282364 Feb 7 2017 ./TR1HD/LEVEL3B_2.png
-rw-r--r-- 1 paul 197121 1306672 Feb 7 2017 ./TR1HD/LEVEL3B_3.png
-rw-r--r-- 1 paul 197121 1054678 Feb 7 2017 ./TR1HD/LEVEL3B_4.png
-rw-r--r-- 1 paul 197121 1506001 Feb 7 2017 ./TR1HD/LEVEL4_0.png
-rw-r--r-- 1 paul 197121 1564778 Feb 7 2017 ./TR1HD/LEVEL4_1.png
-rw-r--r-- 1 paul 197121 1297445 Feb 7 2017 ./TR1HD/LEVEL4_2.png
-rw-r--r-- 1 paul 197121 1195912 Feb 7 2017 ./TR1HD/LEVEL4_3.png
-rw-r--r-- 1 paul 197121 309902 Feb 7 2017 ./TR1HD/LEVEL4_4.png
-rw-r--r-- 1 paul 197121 560068 Feb 7 2017 ./TR1HD/LEVEL4_5.png
-rw-r--r-- 1 paul 197121 1302676 Feb 7 2017 ./TR1HD/LEVEL4_6.png
-rw-r--r-- 1 paul 197121 609085 Feb 7 2017 ./TR1HD/LEVEL4_7.png
-rw-r--r-- 1 paul 197121 434613 Feb 7 2017 ./TR1HD/LEVEL4_8.png
-rw-r--r-- 1 paul 197121 1601272 Feb 7 2017 ./TR1HD/LEVEL5_0.png
-rw-r--r-- 1 paul 197121 1398673 Feb 7 2017 ./TR1HD/LEVEL5_1.png
-rw-r--r-- 1 paul 197121 1151861 Feb 7 2017 ./TR1HD/LEVEL5_2.png
-rw-r--r-- 1 paul 197121 197367 Feb 7 2017 ./TR1HD/LEVEL5_3.png
-rw-r--r-- 1 paul 197121 896824 Feb 7 2017 ./TR1HD/LEVEL5_4.png
-rw-r--r-- 1 paul 197121 1006225 Feb 7 2017 ./TR1HD/LEVEL5_5.png
-rw-r--r-- 1 paul 197121 752153 Feb 7 2017 ./TR1HD/LEVEL5_6.png
-rw-r--r-- 1 paul 197121 272976 Feb 7 2017 ./TR1HD/LEVEL5_7.png
-rw-r--r-- 1 paul 197121 1391775 Feb 7 2017 ./TR1HD/LEVEL6_0.png
-rw-r--r-- 1 paul 197121 1691457 Feb 7 2017 ./TR1HD/LEVEL6_1.png
-rw-r--r-- 1 paul 197121 48422 Feb 7 2017 ./TR1HD/LEVEL6_10.png
-rw-r--r-- 1 paul 197121 41046 Feb 7 2017 ./TR1HD/LEVEL6_11.png
-rw-r--r-- 1 paul 197121 990369 Feb 7 2017 ./TR1HD/LEVEL6_2.png
-rw-r--r-- 1 paul 197121 1507116 Feb 7 2017 ./TR1HD/LEVEL6_3.png
-rw-r--r-- 1 paul 197121 1141570 Feb 7 2017 ./TR1HD/LEVEL6_4.png
-rw-r--r-- 1 paul 197121 922811 Feb 7 2017 ./TR1HD/LEVEL6_5.png
-rw-r--r-- 1 paul 197121 1145829 Feb 7 2017 ./TR1HD/LEVEL6_6.png
-rw-r--r-- 1 paul 197121 1205812 Feb 7 2017 ./TR1HD/LEVEL6_7.png
-rw-r--r-- 1 paul 197121 469653 Feb 7 2017 ./TR1HD/LEVEL6_8.png
-rw-r--r-- 1 paul 197121 57923 Feb 7 2017 ./TR1HD/LEVEL6_9.png
-rw-r--r-- 1 paul 197121 1831865 Feb 7 2017 ./TR1HD/LEVEL7A_0.png
-rw-r--r-- 1 paul 197121 1503587 Feb 7 2017 ./TR1HD/LEVEL7A_1.png
-rw-r--r-- 1 paul 197121 817008 Feb 7 2017 ./TR1HD/LEVEL7A_2.png
-rw-r--r-- 1 paul 197121 1120660 Feb 7 2017 ./TR1HD/LEVEL7A_4.png
-rw-r--r-- 1 paul 197121 532951 Feb 7 2017 ./TR1HD/LEVEL7A_5.png
-rw-r--r-- 1 paul 197121 58208 Feb 7 2017 ./TR1HD/LEVEL7A_6.png
-rw-r--r-- 1 paul 197121 60957 Feb 7 2017 ./TR1HD/LEVEL7A_7.png
-rw-r--r-- 1 paul 197121 60796 Feb 7 2017 ./TR1HD/LEVEL7A_8.png
-rw-r--r-- 1 paul 197121 1777099 Feb 7 2017 ./TR1HD/LEVEL7B_0.png
-rw-r--r-- 1 paul 197121 1484447 Feb 7 2017 ./TR1HD/LEVEL7B_1.png
-rw-r--r-- 1 paul 197121 1036836 Feb 7 2017 ./TR1HD/LEVEL7B_2.png
-rw-r--r-- 1 paul 197121 129979 Feb 7 2017 ./TR1HD/LEVEL7B_3.png
-rw-r--r-- 1 paul 197121 1100334 Feb 7 2017 ./TR1HD/LEVEL7B_5.png
-rw-r--r-- 1 paul 197121 1106609 Feb 7 2017 ./TR1HD/LEVEL7B_6.png
-rw-r--r-- 1 paul 197121 1257739 Feb 7 2017 ./TR1HD/LEVEL8A_0.png
-rw-r--r-- 1 paul 197121 1880001 Feb 7 2017 ./TR1HD/LEVEL8A_1.png
-rw-r--r-- 1 paul 197121 1100176 Feb 7 2017 ./TR1HD/LEVEL8A_2.png
-rw-r--r-- 1 paul 197121 1637022 Feb 7 2017 ./TR1HD/LEVEL8A_3.png
-rw-r--r-- 1 paul 197121 998189 Feb 7 2017 ./TR1HD/LEVEL8A_4.png
-rw-r--r-- 1 paul 197121 1175998 Feb 7 2017 ./TR1HD/LEVEL8A_5.png
-rw-r--r-- 1 paul 197121 1254610 Feb 7 2017 ./TR1HD/LEVEL8A_6.png
-rw-r--r-- 1 paul 197121 750785 Feb 7 2017 ./TR1HD/LEVEL8A_7.png
-rw-r--r-- 1 paul 197121 577260 Feb 7 2017 ./TR1HD/LEVEL8A_8.png
-rw-r--r-- 1 paul 197121 1626334 Feb 7 2017 ./TR1HD/LEVEL8B_0.png
-rw-r--r-- 1 paul 197121 1897307 Feb 7 2017 ./TR1HD/LEVEL8B_1.png
-rw-r--r-- 1 paul 197121 1210110 Feb 7 2017 ./TR1HD/LEVEL8B_2.png
-rw-r--r-- 1 paul 197121 1781150 Feb 7 2017 ./TR1HD/LEVEL8B_3.png
-rw-r--r-- 1 paul 197121 1107136 Feb 7 2017 ./TR1HD/LEVEL8B_4.png
-rw-r--r-- 1 paul 197121 1175998 Feb 7 2017 ./TR1HD/LEVEL8B_5.png
-rw-r--r-- 1 paul 197121 993009 Feb 7 2017 ./TR1HD/LEVEL8B_6.png
-rw-r--r-- 1 paul 197121 707119 Feb 7 2017 ./TR1HD/LEVEL8B_7.png
-rw-r--r-- 1 paul 197121 854233 Feb 7 2017 ./TR1HD/LEVEL8B_8.png
-rw-r--r-- 1 paul 197121 1758386 Feb 7 2017 ./TR1HD/LEVEL8C_0.png
-rw-r--r-- 1 paul 197121 1808247 Feb 7 2017 ./TR1HD/LEVEL8C_1.png
-rw-r--r-- 1 paul 197121 1313929 Feb 7 2017 ./TR1HD/LEVEL8C_2.png
-rw-r--r-- 1 paul 197121 1500203 Feb 7 2017 ./TR1HD/LEVEL8C_3.png
-rw-r--r-- 1 paul 197121 922232 Feb 7 2017 ./TR1HD/LEVEL8C_4.png
-rw-r--r-- 1 paul 197121 1202958 Feb 7 2017 ./TR1HD/LEVEL8C_5.png
-rw-r--r-- 1 paul 197121 65432 Feb 7 2017 ./TR1HD/TITLE_0.png
-rw-r--r-- 1 paul 197121 862499 Feb 7 2017 ./TR1HD/TITLE_1.png
-rw-r--r-- 1 paul 197121 325284 Feb 7 2017 ./TR1HD/TITLE_2.png
-rwxr-xr-x 1 paul 197121 14458272 Mar 18 2017 ./vc_redist.x86.exe
-rwxr-xr-x 1 paul 197121 58368 Mar 4 2017 ./winmm.dll
-rwxr-xr-x 1 paul 197121 60416 Apr 6 1999 ./Winplay.dll
-rwxr-xr-x 1 paul 197121 89600 Apr 6 1999 ./Winsdec.dll
-rwxr-xr-x 1 paul 197121 80896 Apr 6 1999 ./Winstr.dll
Reply 2 of 24, by Avenger
Glidos wrote on 2025-08-31, 11:41:
Difficult to say. If you are copying the data files by hand then it can be difficult to get everything right. What works best is […]
This is the gog version of the game which is just repackaged DOS files to run on DOSBox and it doesn't come with the Unfinished Business Expansion. Since that was released as a free download initially it still remains that way today. It's super simple to get running on DOSBox since you can define the directories yourself via commands. I have no idea what the hardcoded directories are for TombATI though and since there is no readme or guide anywhere that I can find and not even an error code when the "tombub.exe" crashes to desktop it's difficult to figure out what the problem is. The level files also have to be in .PHD format so I'm very limited on where I can source the files. All the converters that I have found lead to dead links unfortunately.
Can you please post screenshots of both your "tombati" and "data" folder in "details" view so I can see the entire file names, please?
This is assuming that the level files for Unfinished Business are supposed to be copied into the "data" folder and not elsewhere. When TombATI is installed it doesn't create any other directory for game files so I'm assuming the Unfinished Business levels do go there...
Thanks for your help.
Reply 3 of 24, by Glidos
The file lines are in what I posted above, although viewed from linux, so not as you'd usually see them. Just replace the / characters by \ and replace the initial . character by C:\TOMBATI. So where I've posted
./TR1HD/TITLE_2.png
the full files name is C:\TOMBATI\TR1HD\TITLE_2.png
Reply 4 of 24, by Glidos
I'm not aware of the level files havning to be .PHD (and I sort of should be aware if it were true - possibly I may have forgotten). If you look at my list, I have a mix of .PCX and .PHD files. That's from a working installation.
Reply 5 of 24, by Glidos
Sorry, I didn't read your initial post with enough care. You do seem to have followed the correct instructions for the iniital set up. I thought the gog and steam versions came with the UB data files. When I get a chance, I will blow away my whole set up and reinstall, see if I can run into your problems. Probably wont get to that until Wednesday.
Reply 6 of 24, by Glidos
I found time to give it a go this evening. It all just works for me. I deleted the entire C:\TOMBATI folder and reinstalled. One of the items installed by the main installer is C:\TOMBATI\TombRaiderImporter.exe, and that is run as the last step in the installation. That offers to copy files from either theTR CD, from GoG, or from Steam. I tried out both GoG and Steam, deleting everything again inbetween. After doing so, both the main game and UB run fine. I also retested with the HD textures and FMVs installed. All just worked.
If you don't want to start again from scratch, one thing worth doing is just running C:\TOMBATI\TombRaiderImporter.exe again and recopying the files from one of the sources.
Reply 7 of 24, by Avenger
Glidos wrote on 2025-09-01, 18:14:
Where did you install TombATI to?
I have tried installing the GOG version of Tomb Raider at least a dozen times and the importer you reference continues to claim that the game isn't found even when installing in the default "C:" location. I have no idea if the importer is broken or what the problem is. This is why allowing users to define the location manually is of great benefit... So all I'm left with is copying the files into the "data" and "fmv" folders myself which works fine except for the Unfinished Business Expansion.
Also, are you putting the Unfinished Business levels/menu screens (PHD/PCX) files in the same "data" folder as the base game or are they in another directory?
Reply 8 of 24, by Glidos
I installed TombATI to C:\TOMBATI. I guess GOG have changed their installers since I wrote all this and my importer can no longer find what it needs. I think the file my installer uses is GAME.GOG. What I may be able to do is upate the installer to give a forth method where you explicitly find that file... although it's been so long since I've looked at all this that I'm struggling to find the git repo with the code.
PHD/PCX: yes and no. Obviously, in my case, I'm not putting anything anywhere, the importer is doing it for me, but yes - I have PHD/PCX files all in C:\TOMBATI\DATA.
Reply 9 of 24, by Glidos
Do you have this windows register key: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\GOG.com\Games\1207663463?
That's what the importer looks for.
Reply 10 of 24, by Avenger
I finally figured out what the problem was. Apparently Unfinished Business doesn't use the new updated FMV files in .AVI format like the base game does so it still relies on the old "CORE.RPL" file in order to load the old low quality "Core Design" intro video. Why both games wouldn't utilize the higher quality video doesn't really make a lot of sense especially when there are no error codes to instruct the user what the problem is...
I'm not sure about the registry key you're referring to. I will do a fresh install of the game to check when I have a chance and report back the answer. All I know is that the current GOG version is no longer detected by the importer.
Also, both the opening menu screens for the base game and Unfinished Business are different but TombATI can only use one or the other. The problem is they both utilize the exact same file name within the defined "data" folder: "TITLEH.PCX". This is obviously a problem because then the user has to choose between one or the other since you can't have two files with the same name in the same directory. It would be nice to instead have the correct menu displayed for each game. If a second directory for the Unfinished Business Expansion menu screen could be user defined so that both could be utilized that would be great. Either that or editing the name of the file and having TombATI look for that also works, maybe with a note to instruct the user to edit that file name.
I figured since you were going to dig back into this to perhaps fix the GOG importer problem that it would be worth mentioning all 3 issues and have them all corrected at the same time.
I will let you know about that registry key at my first opportunity.
Thanks for taking the time to look into this.
Reply 11 of 24, by Glidos
Yes, thanks, Useful feedback.
I know why UB doesn't use the .AVI files. TombATI, right from it's initial versions, long before I got involved, made TR and UB do things they weren't coded to do. TombATI does this by hacking the binaries on start up: writing over old bits of code with new bits of code. I extended that hacking to get the .AVI files working for TR, but never got around to UB. It's not easy - many days using the IDA program, which I'd never used before, to reverse engineer the binaries.
Reply 12 of 24, by Avenger
Glidos wrote on 2025-09-03, 11:26:
I just downloaded the game from GOG and installed it on the machine I have access to at the moment.
The registry key you're referring to is slightly different:
HKEY_LOCAL_MACHINE\SOFTWARE\GOG.com\Games\1207663463
There is no "WOW6432Node" part.
But as you stated earlier, this could change in the future if/when the installer does.
Might be wise to have the directory user definable or perhaps look for the "data" folder instead since that's how the directory tree is on the origonal Tomb Raider discs so I doubt that would ever be altered.
Just a suggestion.
Reply 14 of 24, by Avenger
Glidos wrote on 2025-09-06, 10:48:
Here's a new version of TombRaiderImporter, hopefully handling both types of GoG Galaxy installs: https://download.glidos.net/TombATI/TombRaide … porter_v1.1.zip
Great. Even if I no longer need it, hopefully it will help someone else.
Any update on Unfinished Business using the Higher Quality AVI FMV or the correct menu screen image?
I know you mentioned the FMV's are time heavy to implement but figured I would ask. I really like what TombATI does and hope to see it in a finished state at some point.
Reply 15 of 24, by Glidos
Does UB have any FMVs other than the initial CORE one? In the FMV directory, there's ESCAPE.RPL that doesn't have a corresponding .AVI. Perhaps that's from UB.
Regarding the menu, that gets overridden if you use any of the texture packs. And the texture pack authors have never created separate menu images for UB.
Reply 16 of 24, by Avenger
Glidos wrote on 2025-09-06, 14:51:
As far as I remember, no.
Maybe I'm misremembering though. I'm sure there are playthroughs on youtube that we can skip through to confirm. I did want to replay the game again after many years so that's why I installed TombATI for a better experience over DOSBox with glide.
Are you sure about the menu screens?
I have the texture pack installed and if I switch out the "TITLEH.PCX" file in the "data" folder with the one from Unfinished Business, TombATI displays the correct menu screen image for Unfinished Business. As mentioned previously though, then that remains the menu image for the base game as well so you have to choose one or the other.
Reply 17 of 24, by Glidos
It may depend on which texture pack you install. I was thinking of John Capon and Quest packs... although - come to think of it - the experience with texture packs in UB might not be great: they were designed for the main game, and there are many UB specific textures that aren't mapped.
Reply 18 of 24, by Avenger
Glidos wrote on 2025-09-09, 11:05:
I didn't even know that there was different versions of the texture pack. I installed whichever the default one you have listed in the "TombATI" section of your website is: https://www.glidos.net/tombati.html?lang=en
Outside of the menu screen, does Unfinished Business really have that many assets not used in the base game?
Either way, as mentioned the menu graphic is wrong unless you change it manually which shouldn't be necessary.
Could you add an option for a user defined path to the correct file or have the user rename it to for example "TITLE.PCX", paste it into the "data" folder directory and have TombATI look for it when Unfinished Business is played?
Reply 19 of 24, by Glidos
The other texture packs are here: https://www.tombraiderxtra.com/ - the main packs really - some retexture the entirety of TR I.
There are a fair number of new textures in UB, but the texture packs are still useable.
The menu problem isn't that easy. It's the original game binary that looks for those files. I haven't yet worked out what the cause of the problem is.
