486 Thermal Heat Sink
First post, by Tory4
I did some searches on here and I don't see vary much debate about it. Running a 486DX2 in my Gateway 2000 tower (its the mid tower in the 2DX era, possibly the biggest during this run in 94 although I'm not 100% sure on that). Plenty of room in the case but I am unsure of temps (haven't put a temp gun to it) and the processor of course having no thermal sensors.
Im looking at adding a fan to the factory heat sink or possibly finding a QUALITY aftermarket heat sink. I am leery of removing the factory heat sink as it does seem to be on there. My case has a fan which blows a decent amount of air close to directly on the processor. You guys get the idea, any ideas here? My setup has the Anigma PCI/ISA motherboard (I will be posting about this board as there doesn't seem to be much documentation on it and from what I have seen there are a few variations). It does have an output for a fan on it. Im thinking about trying to find a P4 or early 2000s Celeron fan to attach to the factory heat sink.
One other thing I have to wonder about is the transfer surface of the cermaic to the heat sink. In modern applications there is of course thermal paste or pads to help transfer the heat to the heat sink. Is there anything to help that with these ceramic heat sinks? I would assume some sort of thermal paste would help with that as the ceramic surface is not smooth at the microscopic level. I'm honestly probably thinking too deep on it.
Any thoughts?
I may do some experimenting with this and in the end I feel a fan is always better than no fan.
Reply 1 of 15, by Pickle
I wouldnt try to remove the heatsink. I also think its ok with just that front fan pulling air over the cpu.
I went through a similar investigation and i remember coming across opinions that thermal paste wasnt useful on ceramic.
Im runnng a amd dx4 at 133 mhz with a simple clip-on heatsink and fan now.
one of the bigger issue i had was the lack of a good way to hold the heat sink on. I attempted some 3d printed brackets that clamped around the cpu. So having the heatsink epoxied might be best in the end.
Reply 2 of 15, by Tory4
Pickle wrote on 2025-09-05, 15:42:
I wouldnt try to remove the heatsink. I also think its ok with just that front fan pulling air over the cpu. I went through a s […]
This was a concern I came up with that I forgot to mention as well... In my google searches I came across several aluminum fin heat sinks (with cheap Chinese fans on them) on eBay and I had seen brackets which looked like they clip on. The current heat sink definitely is not clipped on it looks as if it is glued on and I stopped there. I also forgot to mention I added a (previously blocked off) fan on the backside of the case separate from the PSU exhaust fan so there is a good amount of airflow in the case.
Reply 3 of 15, by jakethompson1
I would leave it alone, or at least buy a second 486DX2-66 to practice on and keep that one as is.
These CPUs are rated for 85 Celsius. Even Intel only put this heatsink on their retail CPUs: https://upload.wikimedia.org/wikipedia/common … _2007_03_27.jpg
Here are the airflow ratings in the datasheet: https://archive.org/details/bitsavers_intelda … e/n219/mode/1up
and a past thread about it: 486DX2 heat sink debate
My avatar shows a fancy ATS heatsink I got from DigiKey with phase-change thermal interface material bonded onto the bottom, hooked to an Am5x86 via a 3d printed bracket. Note that the Am5x86 ADW CPUs are rated for 65C rather than 85C, so cooling is more important on them.
Reply 4 of 15, by dominusprog
Tory4 wrote on 2025-09-05, 15:50:
It's an adhesive thermal paste not glue. You can remove the heatsink by using the freeze spray. But if you don't care about the original heatsink just add a 50x50mm fan on top.
https://www.ebay.co.uk/itm/124615822084?_skw= … ABk9SR_LMx6mjZg
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 5 of 15, by Tory4
jakethompson1 wrote on 2025-09-05, 15:59:
I would leave it alone, or at least buy a second 486DX2-66 to practice on and keep that one as is. […]
I didn't realize they were rated to 85 degrees. If thats the case I will probably leave the heat sink alone and maybe just add a fan to it if I can find one to cover it appropriately.
Appreciate it guys
Reply 6 of 15, by bertrammatrix
That setup is just fine the way it is - I'd call it a "best case scenario". You could even probably get away with slowing that front case fan down some with like 9volts if you want it a little quieter.
Reply 7 of 15, by ODwilly
Touch the Heatsink when you are playing a game. Is it hot? Does it burn your fingers? If it does slap a molex powered fan on it or near it. If it doesn't hurt when ya touch the passive glued on HSF then it's fine as is
Reply 8 of 15, by Tory4
ODwilly wrote on 2025-09-05, 17:44:
Its what i would call HIGHLY uncomfortable but I have a very high pain tolerance (working around race cars and hot exhaust all my life). So yeah that sounds advisable.
Reply 10 of 15, by Tory4
Shponglefan wrote on 2025-09-05, 21:18:
I use 40mm Noctua fans on heat sinks for 486 processors (DX2/66 or faster). Even though the processors are rated for higher temps, keeping them cool as possible doesn't hurt.
On stock Intel heat sinks? That's what I'm thinking I will do.
Reply 11 of 15, by Shponglefan
Tory4 wrote on 2025-09-06, 17:40:
Yup, I've put them on stock heatsinks. For example, here's a 40mm fan I rigged up on a DX4/100 overdrive processor.
It's a bit of a funky setup, but it works.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 12 of 15, by devius
For what it's worth, my first PC had a 486DX2 66MHz and it ran without even a heatsink, let alone a fan, and it ran fine for the 4 years it was my main PC.
Reply 13 of 15, by dominusprog
Shponglefan wrote on 2025-09-06, 19:38:
Is it stable? Doesn't the fan got loose?
Reply 14 of 15, by jakethompson1
If you're using plain DOS, you might look into its POWER.EXE driver to HLT the CPU when idle to help keep it cooler
Without it, the CPU spins in a busy loop when idle
