HDD Issues and Concerns
First post, by DustyShinigami
I'm getting increasingly concerned, not to mention frustrated, that a particular hard drive has been having nothing but problems since changing motherboard/setup. I've lost count now how many times it's been playing up complaining about errors and bad clusters. This is the hard drive I have - https://www.hdsentinel.com/storageinfo_detail … MSUNG%20SP0842N
Someone suggested I connect my HDDs to IDE 3 and 4, but I'm not sure if this one should go back on IDE 1 or 2...? I noticed it says the disk interface is Ultra-ATA/133, whereas the IDE 3 and 4 controllers are Ultra ATA/66. Though surely they're backwards compatible, right...?
Even after doing a fresh reformat, and doing a surface test with Super FDISK and it finding no issues, once I put all of my CD images back on (which takes a helluva long time), problems start arising eventually. Twice now the computer has locked up whilst trying to create a CD image to that drive. And then it'll run through Scan Disk and take ages when it gets to drive E. It always throws this at me:
The attachment IMG_4546.JPG is no longer available
And according to Super FDISK, it is set to LBA. I don't have any options to manually check or adjust it. The BIOS only allows for that with IDE 1 and 2. And even if it does fix the drive, it happens again at some point. I'm hoping it's not because the drive is starting to fail. It was perfectly fine before anyway. Even when I checked the health of it with some software (the name escapes me now). Or is it simply because something isn't configured properly?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 40, by Archer57
You need to read smart and see what's shown there (and post a screenshot?). You can usually tell the state of the drive pretty conclusively just by looking at those data.
But usually if you are able to to see bad blocks with surface scan or write/read errors happen in OS the drive is pretty much dead. Unless of course it is some sort of compatibility issue, but that is impossible to tell with info provided.
To begin with - are you using 80 wire cable?
As for the connectors - IDE1 and IDE2 are connected to chipset integrated controller, up to ATA33. IDE3 and IDE4 are connected to separate controller which supports up to ATA66. 3 and 4 are going to be faster, but you need to be careful which mode the controller is set to (you probably do not want raid) and from compatibility point of view chipset ports are always better, at least in my experience...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 2 of 40, by DustyShinigami
Archer57 wrote on 2025-09-09, 00:37:
You need to read smart and see what's shown there (and post a screenshot?). You can usually tell the state of the drive pretty c […]
Before, when I first started getting these Scan Disk issues, it was detecting bad blocks. The last time, however, there didn't appear to be any. But I wasn't about to let it run for several hours again to find out. The surface scans I've run with Seagate Tools and Super FDISK haven't turned up any issues. Same right after it's reformatted.
I am using an 80 wire cable, yeah. Though I've had to hook up a male to female adapter as IDE 1 and 2 are 39 pin whilst 3 and 4 are 40. For my motherboard, IDE 1 and 2 are controlled by the BIOS whereas 3 and 4 are a separate chip/controller.
Rather than re-upload all the pics again, I'll link to the other thread I made, which was a different hard drive issue. It shows all the options I have in the BIOS.
Re: Struggling at setting up HDDs correctly
Unfortunately I have no way of being able to tell if IDE 3 and 4 have LBA enabled. Super FDISK and the Seagate Tools seem to think so, but there's no option to adjust in the BIOS or the controller's BIOS.
OS: Windows 98 SE
Reply 3 of 40, by DustyShinigami
So far, since connecting it back to IDE 2, it all seems fine. And Alcohol 120% hasn't crashed whilst creating some CD images to the drive.
OS: Windows 98 SE
Reply 4 of 40, by Archer57
Then it would point towards some compatibility issue with controller. It happens. I personally try to avoid such controllers if i can for this reason.
Still worth checking smart though...
Reply 5 of 40, by DustyShinigami
Archer57 wrote on 2025-09-09, 01:45:
It could well be. What/where do you mean by smart though?
OS: Windows 98 SE
Reply 6 of 40, by Archer57
DustyShinigami wrote on 2025-09-09, 01:51:
This:
The attachment smart.JPG is no longer available
Do not pay too much attention to any "health" or whatever any utility used to read it shows, but actual data will indicate most issues that exist.
For example attribute 05 indicates number of bad blocks which were reallocated by the drive, C5 indicates number of blocks which can not be read but were not reallocated yet. If both are non-zero the HDD is very likely bad to a point of not being worth trying to do anything with. C7 would show interface transfer errors, for example because of bad cable. Etc.
Reply 7 of 40, by DustyShinigami
Archer57 wrote on 2025-09-09, 02:14:
This: […]
This:
Ohhh, that. That was the utility I couldn't remember the name of. Crystal Disk. Yeah, the last I saw, everything seemed fine, but I'll give it another check. But thanks for clarifying what to check. 😀
OS: Windows 98 SE
Reply 8 of 40, by DustyShinigami
Just seem to have having some issues finding Crystal Disk Info for Windows 9x/98. I can't remember which one I tried before, but I don't appear to have it saved for some reason.
OS: Windows 98 SE
Reply 9 of 40, by DustyShinigami
Yeeeeaaahhh, I think the HDD is faulty. Just re-booted and it complained of bad sectors again. Tried to go through the Scan Disk. Of course, I can't find out for definite as I can't find Crystal Disk Info for 98 anywhere. 🙁 There's Crystal Disk Mark, but it doesn't have the same info; it looks too simplified. And if it was never released for 9x, then what version at least works? Because I definitely used it before.
OS: Windows 98 SE
Reply 10 of 40, by DustyShinigami
Went back to an old thread of mine, which discussed health checking software, and yeah - there is no version of CrystalDisk Info for Windows 98. Only XP and above. Damn. Looks like it was SpeedFan I used before. Only this time, loading it up, it doesn't even list any of my HDDs. 🙁
OS: Windows 98 SE
Reply 11 of 40, by DustyShinigami
Can't use Hard Disk Sentinel either. Says it needs a S.M.A.R.T. driver. Not sure where to get that from. Nothing much is coming up on Google.
OS: Windows 98 SE
Reply 13 of 40, by DustyShinigami
douglar wrote on 2025-09-09, 16:56:
DustyShinigami wrote on 2025-09-09, 13:45:
Have you tried the DOS version?
https://www.hdsentinel.com/hard_disk_sentinel_dos.php
I haven't, no. Didn't realise there was one. Thanks. 😀
Still trying to figure out what I need to install to get the S.M.A.R.T. drivers on.
OS: Windows 98 SE
Reply 14 of 40, by kotel
Don't think 9x supports SMART data...
Try MHDD 4.6 for DOS, and run a normal scan on it ("F4" key or type "SCAN" when you launch it). Or better yet, plop the HDD inside an XP machine and launch Crystal Disk Info from there.
You say you've got me outnumbered
I say you've evened the odds
You doubt the strength I hold within
Just one bounce back is all I need to win!
Reply 15 of 40, by DustyShinigami
kotel wrote on 2025-09-09, 18:03:
Ahh. Sadly I don't have an XP machine. But thanks for the suggestion, I'll give MHDD a try. 😀 Thing is, I could've sworn I ran something like Crystal Disk Info on my 98 machine. If not, it was definitely Mark because I posted a screenshot from that in another thread. Either way, I thought I ran some sort of test in Windows, even if it doesn't support SMART data. So no idea what that was or how.
OS: Windows 98 SE
Reply 16 of 40, by DustyShinigami
This is the first test from Hard Disk Sentinel DOS
The attachment IMG_4547.JPG is no longer available
According to that it's perfectly fine. 😮 I'm not sure it's giving me the full picture though. Performance is definitely a problem. I have some 80 IDE cables, though they're technically 39 pin, not 40. So I'll have to see if there are any 80 40 pin connectors. At the moment, it's using an 80 pin connector, but coupled with a male to female adapter.
OS: Windows 98 SE
Reply 17 of 40, by DustyShinigami
These are the SMART details from MHDD:
The attachment IMG_4549.JPG is no longer available
OS: Windows 98 SE
Reply 18 of 40, by douglar
DustyShinigami wrote on 2025-09-09, 19:44:
Seems to me like the storage device is saying is that it's fine, but the controller is telling the operating system that there are problems. The root cause is likely one of these:
  1. failing IDE controller in the system
  2. cables not working at the speed negotiate between the controller and the storage device
  3. an incompatibility between the controller device driver & the storage device firmware
  4. edge case system memory that works fine with the CPU but fails intermittently on DMA requests
Reply 19 of 40, by DustyShinigami
douglar wrote on 2025-09-09, 20:33:
Seems to me like the storage device is saying is that it's fine, but the controller is telling the operating system that there a […]
Hmm. Curious. I hope it's not the first possibility. Could using an 80 cable with a male to female adapter be causing an issue with the speed? I can't seem to find any 80 cables that are exactly 40 pins, only 39, so I'm not able to connect it completely from drive to bus.
Not sure if I already have the latest driver installed for the controller. 1.25 was what I installed. I'll have to see if I can find the latest firmware for the HDD. I take it nothing can be done if it's failing intermittently?
OS: Windows 98 SE
