First post, by Feanor_twh
I got a Shuttle HOT-591p to replace my old SS7, which hadn't worked after several years in the closet. It came with a K6-2 300 configured at 66x4.5, which worked fine, until I installed my K6-III 400, and then everything went wrong. It wouldn't even boot, but when I went back to the K6-2, it wouldn't boot either, until I discovered, after much testing, that the problem was with the 100MHz FSB. Neither of them work at all with that FSB, and they do work at 66MHz. I tried 95MHz (86MHz real) and they work but with memory issues. I have yet to try 75MHz, but even if it works, it's a regrettable performance loss.
What am I missing? I thought it might be an outdated BIOS, but that seems unlikely. This motherboard has automatic voltage, but I tried manual adjustment, but nothing. Also tried RAM at AGP speed and FSB speed, and it's the same thing.
It's driving me crazy, but I can't just abandon this project because the other components are so great and fit together perfectly.
Reply 1 of 18, by bracecomputerlab
Maybe, the deterioration of the aluminum electrolytic capacitors due to aging.
Perhaps, the capacitance it still has is barely okay if the current draw is low, but not okay if it the current draw is higher.
The higher current draw is higher if the FSB is higher, so maybe this very simplistic explanation can explain the situation.
Reply 2 of 18, by CharlieFoxtrot
bracecomputerlab wrote on 2025-09-12, 08:00:
Capacitor failing not only affects to the capacitance negatively, but ESR also shoots up way out of spec. For VRM the capacitance can be often less than what is originally installed, but too high ESR means high ripple which definitely causes instability to circuit.
Reply 3 of 18, by dionb
Agree that caps could be causing issues here - but back to basics first: you're getting memory issues. What memory are you using? And how is the memory clock configured (same as FSB or same as AGP?)
Reply 4 of 18, by Inhibit
If the board's otherwise okay I'd suspect memory that's not handling 100mhz for some reason. Settings or just marginal parts.
I did run into boards even when SS7 was current that were flaky at 100mhz. Although that'd usually eventually show up in an errata sheet for them and the Tomato is the only one that sticks out in my memory.
Reply 5 of 18, by Feanor_twh
I tried other memory modules: PC-100, PC-133, 128MB, 64MB, and the problem persists, multiple memory errors.
- It doesn't matter if the memory is running at AGP or FSB speeds, there's no noticeable difference.
- The capacitors are visually fine, not the slightest bulge, not scratches, cracks, or dents on the board.
- The motherboard worked fine with the K6-2 300 (66x4.5), MemTest86+ was correct.
- In all cases, the CMOS battery was absent, so it can't be a bad BIOS configuration either.
The monster must be there, somewhere, but I can't find it.
I'm going to go back to FSB 66 and install WinXP to test the system thoroughly.
In the next few days, a friend will lend me an identical motherboard for testing, so I'll keep you posted.
Reply 6 of 18, by bracecomputerlab
Elegantly said than my explanation.
I learned something from it (i.e., the ESR part).
CharlieFoxtrot wrote on 2025-09-12, 09:33:
Reply 7 of 18, by bracecomputerlab
As a possibility, even if the caps look okay from outside, they may have lost their capacitance due to dry up.
If I understand it, the moisture inside the can gradually escapes from the rubber seal below, and loses the functionality of a capacitor overtime.
Just one possible explanation.
Feanor_twh wrote on 2025-09-12, 14:44:
I tried other memory modules: PC-100, PC-133, 128MB, 64MB, and the problem persists, multiple memory errors. - It doesn't matter […]
Reply 8 of 18, by Feanor_twh
They've already given me the board for testing. It's the same 591P, but this time it's v3.1 while mine is v2.0.
I'm going to run a systematic round of tests on both boards and post the results.
Reply 9 of 18, by Feanor_twh
The attachment WhatsApp Image 2025-09-14 at 5.01.54 PM.jpeg is no longer available
591P 2.0:
- FSB 66: both processors, MemTest86+ RAM OK
- FSB 100: K6-III RAM failures, K6-2 restarts on MemTest86+
591P 3.1:
- FSB 100: both processors, MemTest86+ RAM OK
All tests performed with the same single-sided PC133 64MB RAM module.
I've learned that a PC100 RAM module can work fine at 66MHz and fail at 100MHz.
My motherboard still isn't working properly; perhaps it's what you're saying about the capacitors, as further RAM tests seem unnecessary...
Reply 10 of 18, by Feanor_twh
Ah... with the PC100 RAM module I was initially using, both boards failed in the same way. That made me look for another module, even though it worked without any problems at 66MHz
Reply 11 of 18, by dionb
If one PC100 module fails on both boards, it's probably a dud module - but if PC100 fails at 100MHz on one board but works fine on the other, I'd say your Vdimm voltages are probably out of spec and/or there's a lot of ripple on that line.
Reply 12 of 18, by Feanor_twh
dionb wrote on 2025-09-14, 21:27:
Although I find it a bit hard to recognize, since the board is visually perfect, I'm afraid you're right. Some capacitor must be failing.
Reply 13 of 18, by nickles rust
What happens if you disable the cache on the motherboard?
Reply 14 of 18, by Inhibit
Yea, as a related note on the capacitors I was working on a box of Super Famicoms for fun and noticed the surface mount caps in those were dead in some cases from old age with no visible signs. De-soldering them usually resulted in the smell you'd expect from a dead capacitor but they didn't have any issues in-situ. And those were a decent brand; just pegged it to old age and replaced them all.
Reply 15 of 18, by shevalier
I have a very similar MVP3BS7-954 board with the same chipset.
At FSB100 with minimal timings, not even all PC133 memory modules work with it.
This surprised me greatly, since the MVP3 isn't as RAM aggressive a chipset as, for example, the BX440.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 16 of 18, by bertrammatrix
nickles rust wrote on 2025-09-17, 19:26:
This.
The cache chips on some of these board were borderline adequate for 100mhz even when they were new, 30 years later with some potentially wonky capacitors thrown in the mix the situation is only worse.
Try to disable it, if the problem goes away try to enable it again an slow down some of the timings for it
Reply 17 of 18, by Feanor_twh
It's frustrating to read all this. It's clear to me that this motherboard will never run at 100MHz FSB.
I was planning to use it for another Pentium MMX project, but I won't even be able to up the FSB to 100MHz, which is what I would have liked (and I know those processors support that FSB without any problems).
Reply 18 of 18, by Jasin Natael
I would definitely check the caps.
