First post, by dm-
Hello vogons,
recently i found a couple of Intel Xeon 1000/256/133 Cascades core 5/12V
The attachment xeon01.jpg is no longer available
i did the swap of core from Xeon board to Coppermine interposer. it should work but it did not.
cpu is heating pretty well, reacting to fsb freq. but zero activity on flash and no post codes ( -- -- ).
The attachment xeon02.jpg is no longer available
anyone is aware of any difference between coppermine and cascades ? what did i miss there
Reply 1 of 7, by Ozzuneoj
dm- wrote on 2025-09-15, 03:34:
Hello vogons, […]
Hello vogons,
Wow, honestly, I had no idea that this was a thing that people did.
I will be watching this thread though. I hope you get it working!
Reply 2 of 7, by myne
What makes you think they share common pinouts?
Let's see the ballout sheets you compared
I built:
Reply 3 of 7, by dm-
there is no ballout sheets for Cascades
all you can find is pdf for Intel Mobile Pentium III cpu
Reply 4 of 7, by red-ray
dm- wrote on 2025-09-15, 10:47:
there is no I could not find the ballout sheets for Cascades
See Table 42. Signal Listing in Order by Pin Number
You should also specify which motherboard you have and the BIOS version, ideally include a link to it.
Reply 5 of 7, by myne
I suppose it's possibly just a microcode issue and not hardware.
Probably best to compare the microcode of the current bios with a bios from a board which definitely supports it.
I built:
Reply 6 of 7, by dm-
red-ray wrote on 2025-09-15, 11:14:
this is slot 2 pinout, not a ballout of the chip itself
ballout looks like this (mobile pentium III)
The attachment mobile_p.png is no longer available
Reply 7 of 7, by dm-
myne wrote on 2025-09-16, 02:00:
there is no activity on flash chip
