First post, by superfury
How are the cache bits in the x86 paging layers (PDPTE, PDE, PTE) combined with the CR3 register bits and CR0 register bits?
From what I've gathered so far:
- Page Cache Disable of the CR0 register is pretty much OR'ed with just the current level of lookup (see below on the used second source for the 'current level').
- Page Write-Through uses the flipped Not-Write through bit of the CR0 register AND'ed with the current level of lookup (see below on the used second source for the 'current level')
The second source being:
- PDPTE lookups (when loading CR3 or enabling PAE) use the CD0 register directly (effectively the second source is the CR0 register itself)
- PDE lookups uses either PDPTE bits(PAE) or CR3 bits(non-PAE)
- PTE lookups use the PDE bits.
Is that correct behaviour?
UniPCemu Git repository
