moistyalf wrote on Yesterday, 08:26:
My best interpretation of the drive sounds are: spins up, stepper moves to one side slowly, then back to the other, then the stepper seems to move a tiny bit one back and forth, pauses, does this again a few times, then clunks (presumably head parking), the drive spins down and starts blinking its red LED. No metallic or grindy-crashy head noises. It does this even with no data cables connected
Hm. I wonder if the servo surface got so weak that it no longer provides correct signals, or perhaps there is a problem with the heads. These HDDs can be opened to see if there is any damage to platters - but it's not always obvious with this many platters, especially the bottom sides. Might provide some clues though. Anything seems loose inside if you rotate the HDD in your hands?
Before you open it, try reseating all the connectors and cables, the head FFC especially. I see 2 trim pots on the PCB, rotate those a bit and return to original position - in case it's some sort of bad contact issue. Consider unplugging the entire PCB and cleaning it, at least with a soft brush, from any dust and dirt.
If you want to open the platter case also have a clean soft painting brush prepared for any dust removal. There might be a gasket around the cover that is old and will start to shed, you want that debris removed. After removing the screws (and any stickers that have to go) pry the cover up gently in several places, do not force it open on one side. I've opened quite a few of these HDDs, in most cases having clean and dry hands, as well as not shedding hair into the drive case, is enough to keep it clean and working. There should be a filter inside to catch any dust particles that might get in there anyway.
As for possible replacements... that's tough, I've only seen a few MFM emulators and these were always expensive. Might be difficult to find another HDD that fits in the space there too.
