First post, by Treah
Recently I have been playing fallout 1 and noticed that sometimes getting it working on older hardware is a pain. This is the windows version of the game and it seams to be very picky about which types of systems it likes working on and which video settings it seams to want. Below is what I have experienced and would love to know if anyone else has had similar problems with the game?
Windows 95 - Game will launch but then crash to the desktop, does not seam to matter which video settings I have or drivers... Only tried in emulation tho via Pcem
Windows 98 - Very picky on video settings. Game wants to be launched with video settings set to 800x600 256bit color. Everything else it will complain and fail to launch.
Windows ME- Funny enough works the best.... Game launches without issues regardless of video settings. - Only tested using pcem.
For most of these tests the only video cards I tried were a voodoo3 2000 and a mach64.
Reply 1 of 8, by DosFreak
Pcem isn't old hardware.
If you are only testing on pcem then best to ask on the pcem forum, we don't develop pcem here.
If you are testing on a real system then specify.
Fallout 1 isn't picky at all.
Make your games work offline
Reply 2 of 8, by Treah
DosFreak wrote on 2025-09-18, 17:07:
Pcem isn't old hardware. If you are only testing on pcem then best to ask on the pcem forum, we don't develop pcem here. If you […]
I figured this was a software section of the forum that's why I posted these tests via PCEM. I am aware it does not behave like old hardware.
One of my tests via windows 98 was on real hardware and it still had some issues with fallout1. and I thought it was clear that it did since I dident say I was using PCEM for that.
I wanted to see if others had similar issues with real hardware / emulated stuff with this title I was not looking for support or development help with PCEM...
I also don't really suspect its purely emulation issues since changing nothing but the OS changed the behavior, an example is using windows 98 over ME and ME being able to adjust the resolution and color settings.
Anyway your post kinda comes off as weirdly hostile, is it because emulation was mentioned or something else?
Reply 3 of 8, by feda
Treah wrote on 2025-09-18, 22:49:
Probably cause this subforum is about running software on old hardware, not emulation.
For PCem issues, go to their forum https://pcem-emulator.co.uk/phpBB3/
I don't remember having any problems with F1 on 9x hardware back in the day, it was very stable.
Treah wrote on 2025-09-18, 16:28:
Game wants to be launched with video settings set to 800x600 256 color.
Are you running a modified version, like the one from GoG which is patched for modern OS? The original only supports 640x480.
Reply 4 of 8, by Treah
feda wrote on 2025-09-19, 06:59:
Probably cause this subforum is about running software on old hardware, not emulation. For PCem issues, go to their forum https: […]
Thank you I did notice my error later on when I re-read the forum title better. Probably helps if I don't respond to shit when I am overly stressed at work and tired 🙁. So I do apologize if I kinda sound like an ass. No I am pretty sure my ISO is from an original source that my room-mate used to have but I do think I do have an original copy somewhere. I know that I am running it with the fan patch I think.
I also have a 486 here running windows 95 so I think I am going to test it today and see if I get the same behavior. I also suspect it might be due to me having the wrong directx as windows ME would have a later version.
Reply 5 of 8, by auron
it's going to chug hard on a 486, i've tried the game on a p90 and it runs just about at a tolerable minimum (it's the official requirement for the game as well).
looking back at my notes i've had one issue with a garbled titled screen, but that was when updating dx3 to dx5 and staying on the old driver, updating to the dx5 driver fixed it - so more of a curious note while experimenting rather than a real problem, but it does show that updating directx could have effects like this at times even though it's supposed to be backwards compatible. video card during testing would have been a matrox millennium.
i've never tried the fan patch yet, maybe that's the source of things like 800x600 which can't be true for the original. of course the original is ridiculously buggy and will softlock in places, so it's a case where the fan patch might be recommended.
Reply 6 of 8, by feda
Treah wrote on 2025-09-19, 17:34:
The fan patch is intended for XP and newer systems, I believe. It makes some sort of changes to the graphics code.
Reply 7 of 8, by torpedo
Original game is not picky, you most likely have some dll proxy in the game folder. Delete ddraw.dll and f1_res.dll if they're in the game folder.
Reply 8 of 8, by StriderTR
I can attest, on real hardware, Fallout 1 gives me no issues at all. It's one of my favorite games and goes on all my systems.
DOS Version on 6.22: Cyrix PR166/S3 Virge DX 4MB
Win Version on 95 OSR 2.5: EPIA-800/C3 800MHz/Cyberblade i7 8MB (All onboard)
Win Version on 98SE: Athlon XP 3000/GeForce 4 Ti 4200
I've never tried running it in PCem, but as other suggested, I would try asking over on their forums. While I do use PCem, I'm most definitely not an expert. 😀
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
