First post, by quwy
Hi All!
Have a problem with subject combination and can't to normally use of 2.88 MB FDD mode on SiS496/497-based board.
Since I select FDD type in the BIOS to 2.88 MB, everything breaks.
  • Under DOS and Win9x I can to deal with 1.44 MB images, but not 2.88.
  • WinNT totally does not see floppy drive (and fall to BSOD 0x7b if I try to use 2.88 mode while booting during installation).
  • Can't to boot from 2.88 MB image, but successfully boot from 1.44.
  • On the different 586 boards emulator works fine in 2.88 MB mode.
Can anybody to say, this is problem of exactly my mobo/BIOS, or maybe FDD emulator configuration?
Thanks.
VMT/VMTCE & ChkFlsh author.
Reply 1 of 10, by Jo22
Hi, not sure. But did you try 2M-XBIOS already? For testing purposes? :)
It's a floppy BIOS for XTs and ATs (2M-ABIOS) that can be loaded from DOS.
As far as I can see, it has a 2.88 MB type mentioned.
https://www.minuszerodegrees.net/2M-XBIOS/2M- … 4M%20as%20B.htm
Reply 2 of 10, by quwy
Jo22 wrote on 2025-09-20, 23:42:
Hi, not sure. But did you try 2M-XBIOS already? For testing purposes? 😀
Hi, I tried 2M-ABIOS, but the same result.
Think a problem in the Gotek emulator (one, two), but still not achieve any results.
Reply 3 of 10, by Jo22
quwy wrote on 2025-09-25, 22:04:
Aw, sorry to hear! I had similar issues with a new Gotek bought during pandemic.
It used the new, cost-reduced FPGA that had little RAM. It caused me issues on DOS.
Read here: Gotek woes (32KB) - anyone else?
The FlashFloppy Firmware that was pre-installed by the seller was the best there was, sadly.
I tried upgrading it, because it caused issues, but the newer Firmware (normal branch) I found didn't work..
Anyway. The first model I had was had the old FPGA which worked like a charm.
It's now installed in a PC/XT in 720KB mode (the XT era floppy controller can't go any higher due to bandwidth).
PS: There's one thing that comes to mind..
Some Goteks come with HxC firmware, which focuses more on Amiga platform.
Maybe those Goteks are more likely to handle 2,88 MB mode?
Because HxC is very sophisticated. Maybe those Goteks have better FPGAs.
It's just a wild guess, though. Please double check before buying.
Reply 4 of 10, by quwy
Thank for your reply!
I perform a lot of tests and came to the conclusion what problem in the BM. The only thing that is not clear, it is BIOS or hardware issue.
If somebody have SiS496-based retro MB and Gotek emulator, please check if your system can to deal with 2.88 images. Thanks.
Reply 5 of 10, by sunkindly
quwy wrote on 2025-10-10, 21:34:
Hi, I have a SiS 496/497 board with an AWARD BIOS date from 1996 and it's able to read 2.88MB images in DOS with 2.88 selected as the FDD.
My Gotek is running HxC if that narrows things down at all. The registration is a pain in the butt but I've been happy with it over FlashFloppy.
The attachment IMG_7298.JPG is no longer available
Reply 6 of 10, by Disruptor
sunkindly wrote on 2025-10-10, 21:58:
Hi, I have a SiS 496/497 board with an AWARD BIOS date from 1996 and it's able to read 2.88MB images in DOS with 2.88 selected a […]
Can you post your gotek's configuration and the disk image please?
Reply 7 of 10, by sunkindly
Disruptor wrote on 2025-10-11, 09:11:
The attachment 288test.zip is no longer available
Let me know if this is what you meant, the .cfg and .img is in there. I had created a 2.88MB image and just put a few DOS benchmarks on it. I can try with another image.
Reply 8 of 10, by quwy
Thanks a lot!
Now I switched to another rarity, but a soon plan to try your Gotek config, who knows...
Reply 9 of 10, by mkarcher
Given a sufficiently fast USB stick, I could verify that FlashFloppy 3.39 and 3.44 work well for 2.88MB images connected to an Asus PVI-486SP3. That board has an SiS 496/497 chipset (which is not that relevant) and an UMC8669F Super I/O chip. On the other hand, a Biostar MB-8433UUD with an UMC8663BF does not support 1MBit/s.
I have two Goteks with a SFRKC30AT3 PCB at hand. One is running FlashFloppy 3.39 and has the original AT32F415 processor (32KB internal RAM) on it, while the other one has been upgraded (chip swap) to the AT32F435 (640KB of internal RAM, split between 384KB work RAM and 256KB shadow RAM for the flash), and sports the most current 3.44 firmware. I tested formatting a DOS floppy, running the SYS command, reading in VGACOPY, writing in VGACOPY with and without the "verify" and the "format" option enabled, and every operation worked perfectly. I used a Kingston DataTraveler G4 16GB USB stick for the positive results, and can confidently report that I didn't notice a major difference between the "stock" Gotek and the "upgraded" Gotek.
On the other hand, with a slower USB stick (generic unbranded 1GB stick, which looks like https://www.nordexmedia.com/1gb-black-custom- … wivel-usb-drive), I can report that the bigger RAM (which results in FlashFloppy having more cache available) in the upgrade processor improved things from "any kind of writing is completely unusable" to "in limited circumstances, writing is OK" This list shows the limited usability on the processor with more buffer space. None of the items on that list work with the unupgraded Gotek on using the cheap stick.
  • Formatting in DOS works if you hit PAUSE every 20% of the formatting process (to allow buffers to be flushed).
  • Running "SYS A:" in DOS 6.22 on a blank floppy pops up multiple "Drive not ready" prompts, which you can answer by "retry" and then the system files get correctly copied (but the second FAT copy was bad afterwards, according to scandisk).
  • Writing with VGACOPY works if "format" is on, but one track in the middle of the image and the last 4 tracks required retries by VGACOPY. Maybe this is due to flash-level or FAT-level fragmentation.
  • Writing with VGACOPY works not at all if "format" is off
The final result is though that if you experience issues when writing 2.88 floppies, upgrading the processor is just papering over insufficient speed of the USB stick. On the other hand, if your USB stick is sufficiently fast, you even the cheap 32KB works well. So swapping the processor on a Gotek PCB is not worth the hassle in this use case.
Please note that this experience is about using sector-based images (.IMG files) with flash-floppy. I also tried a .HFE file generated using the HxCFloppyEmulator software , and nothing worked with them, not even reading using the fast USB stick in the upgraded Gotek.
Reply 10 of 10, by Disruptor
Seems like the difference between working 2.88 ED support and fail is just in the speed of the USB stick.
Conclusion:
Don't take the cheapest USB stick for your GoTek.
