3dfx_fan wrote on 2025-10-31, 09:51:Tried with another Asus P3B-F and effect was the same - Pentium III 500 Mhz did not boot/POST.
Pentium II 333 MHz - starts/POST. […]
Pentium II 350 Mhz - starts/POST.
Pentium II 400 Mhz - starts/POST.
I don't own Pentium II 450 Mhz.
Pentium III 450 Mhz - starts/POST.
Pentium III 500 Mhz - does not start/POST (but it starts/POST on another motherboard).
Strange behavior but interesting 🧐
But maybe it's just some oxidized contact of the Slot1, it could be that some pins of the Slot1 do not make contact, and therefore for example does not match the multi, and the result is the failure to start.
Undoubtedly if the CPU works, it is a problem of the Slot1, but I would say that maybe the CPU should also be checked, and a revived to the contacts, would be done, do not use anything abrasive however, if even after cleaning it does not work, it would be to try with a Slot1 370 adapter or a Celeron 333 Slot1, at FSB 100 it would go to 500 MHz, this shows (if it works) that the problem is with that CPU, I on the Soyo for the moment I solved it like this, but it would be better to find someone who has several CPUs P3 500 Slot1, if it does not work with the others, I would try with a 550 or a 600, if they work, the suspicion on the Slot1 pins could be well-founded.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
