First post, by Private_Ops
I have 512 to 2GB of RAM available, dual channel sets. Also, Athlon 64 3400, 3500, 4000 and Opteron 144 & 180.
Rest of the system is an ASUS A8V-XE, Sound Blaster Audigy RX (Audigy 4 with a PCIe translator chip), DVD drive and 80GB Hard drive (both IDE).
Its my understanding the 800XL is somewhere between a 6600GT and 6800GT. I don't see the Opteron 180s dual core-ness being of any use for the period, so I'm leaning towards the 4000+ to get the most out of it.
Reply 1 of 13, by Archer57
One use for dual core, even for old stuff, is that background tasks like monitoring or something stop affecting performance. This actually was the biggest (and very significant) benefit from dual core CPUs initially, software capable of utilizing more than one core arrived way later.
Other than that 4000+ is probably a good choice. Probably with 2GB of RAM, just to be safe, though 1GB is practically more than enough.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 2 of 13, by Repo Man11
FWIW, here is my Asus K8V-XE with an X800 Pro, a 3400+ @ 2,531 MHz and Win98SE. You would have the advantages of dual channel memory and a larger cache.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 3 of 13, by Matth79
With X800XL, that points to XP, so I'd go 2GB RAM and use the dual core Opteron 180 if it has nothing better to do. XP is multithread, though not the "throw more cores at it" that exists with modern games, and even if the software isn't explicitly multithreaded, a second core lets the background stuff slip by without taking away from the foreground.
Also, looks like both the 180 and the 4000+ actually clock at 2.4GHz, so you aren't losing single thread performance
Reply 4 of 13, by douglar
Matth79 wrote on 2025-09-24, 18:48:
That's pretty close to what I ran back in late 2005. It lasted as my main system for a couple years after that upgrade. Still works today.
Reply 5 of 13, by Private_Ops
Win XP, correct.
May very well just run the Opteron. Would love to pair an X850 with it... wish I hadn't sold the one I had.
Reply 6 of 13, by AlexZ
Definitely Opteron 180. Since you have also Athlon 64 4000+ (single core) you could run some benchmarks for us in a dedicated topic. It would be interesting to see the difference between single and dual core 2.4Ghz.
Single core is only good until 2005, dual core perhaps up to 2007 games.
ATI Radeon X800 XL is hopelessly outclassed. It would benefit from GeForce 9800 GT, GTX 260 or more modern alternatives with the same performance. All those GPUs are super cheap.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 7 of 13, by ElectroSoldier
I have an X800XL but its in a Win98 system.
I wouldnt consider that card for use in WinXP. It was ok back in the day but these days the early gen dual core CPUs aint something I would consider to build a system from.
Reply 8 of 13, by Private_Ops
ElectroSoldier wrote on 2025-09-25, 19:18:
Yea.. I like the Opterons, but I feel it would be better served if I was building it as a "stretching its life" system. Which I have considered, throwing in a 5670 or 4830 would work well.
Reply 9 of 13, by ElectroSoldier
I remember the Opteron solutions being popular back then because they were cheaper than the Intel equivalent system but I never had any use experience of them, I went along the Gulftown route.
Powerful systems back in the day, but in my mind I cant see a place for them because XP can run on much later i7 systems like the i7 3770k with a 980Ti. (or a lp 750Ti)...
Win2k I can see them being interesting as it pushes it out longer, which I like because I still love Win2k but for gaming its more meh!
Reply 10 of 13, by AlexZ
If everyone was building i7 3770k with 980Ti for Windows XP then this would be a very sad place. I hope people will be interested in other platforms as well.
Reply 11 of 13, by douglar
I liked the X800XL because it was relatively quiet compared to the alternatives. Do you have an AGP version? Running win98 without AGP always seemed a little anachronistic to me.
Reply 12 of 13, by ElectroSoldier
douglar wrote on 2025-09-26, 12:33:
Yeah mine is AGP, Its on an ASRock 775i65G.
Its a great card on Win98, there isnt a single game it cant play. Which is what you would expect.
Reply 13 of 13, by shevalier
The X800 is compatible with Windows 98 and devices from that era.
Not long ago, I had G41+E8400 in my signature. And its Windows 2000.
Yep. It doesn't work with A3D Vortex2 drivers at all – it's multithreading.
The X800 is absolutely necessary with a single-core solution.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
