First post, by charleski
I'm running the old Titanium Everquest client connecting to Project1999 servers. After having several graphics freezes I downloaded dgVoodoo and copied the x86 dlls into the application diorectory as instructed.
I managed to get it running in a borderless window (I use SmartContextWindow) by turning ON "DisableAltEnterToToggleScreenMode". Maybe that should be put in the tooltip.
The problem is that text, in particular, is now noticeably blurry. If I disable the dgvoodo dlls and pass through to native DX then everything is sharp again. I've set the resolution in the .conf to the resolution I run the game at (same as specified in eqclient.ini), and I've disabled anitalising and dithering, but the text is still blurred. Is there anything else I should try? If this fixes the random freezes then I'll have to keep using it, but would really like to get sharp text back.
Reply 1 of 2, by charleski
Ok, found a workaround. I downloaded nvidiaProfileInspector and turned antialiasing off in the Everquest profile. Text is now clear again.
It looks like the antialiasing setting in dgVoodoo dooesn't actually have any effect.
Reply 2 of 2, by Squall Leonhart
if you set aa globally, application msaa will be ignored.
