First post, by matt102498
After a long hiatus, I think I'll be back here asking the gurus for information again for a while.
Back in 2001 I bought a Cyberpower PC with an ATI rage 128 pro all-in-wonder. This machine played DVDs like butter. Since then, I have been trying to build an "ultimate" socket 7 build, and it mostly works. My system now is as below:
Motherboard: EPoX MVP3G5
Ram: 768 mb
Processor: AMD K6-III+ 550 (not modded)
Primary graphics: AMD Radeon 7500
Secondary graphics: SLI Diamond Monster 3D2 12 mb
Audio: Diamond Monster Sound Aureal 8830
Also added a 4 port VIA USB 2.0 PCI card
Lastly a Hauppauge WinTV-GoPlus with an IR blaster to use an OTA antenna and a digital converter box (because my previous rage 128 pro AIW was analog only)
OS: CF to IDE swappable Win ME and Windows XP (both are very responsive and initiate glide on an SLI setup fine)
And the most common question to be answered is yes, I've installed the via Hyperion 4.35 chipset driver to both OS.
The problem is now with DVDs, they play like stop motion films. I did just purchase an ATI rage theater 128 pro 32 mb to see if it's just a hardware generation phenomenon. Appreciate any suggestions to get DVDs to play smoothly.
P.S. My socket 478 Intel 3.4 Ghz extreme edition with Radeon 4570 is still kicking. Sometimes fails to post, so I bought another Abit IC7-Max3 motherboard to see if that is the issue. Bad capacitor era.
Thanks for any input.
Matt
Main Rig: ABIT IC7-MAXIII P4 EE 3.4GHz 4GB OCZ Platinum HIS Radeon 4670HD AGP 120Gb OCZ SSD
Retro: EPoX MVP3G5 K6-III 450 768 CL2 ASUS Geforce 5950 Ultra Aureal Vortex
Looking for: IBM PS/1 supporting 64mb ram
Reply 1 of 9, by b_riera
I guess I would try ruling out the drive by ripping a DVD to the CF drive and playing the directly. If DMA isn't on for the DVD drive then that's going to kill the CPU trying to deal with that data stream while simultaneously decoding it.
I remember commercial software like PowerDVD had much better software decoders than anything freely available at the time.
I've seen a PII 300 with an Ati Rage 128 play DVD video decently and definitely not a slide show like you're describing (different CPU though I know and this was a very long time ago). I'm almost certain it had a very specific DVD player program though.
ATI and nVidia at the time usually had some sort of hardware assist. You'd still use software decoding but it would help lower CPU utilisation.
I guess try the first test before buying anything else!
Reply 2 of 9, by Unknown_K
Are the HD and DVD drive on separate IDE cables?
Reply 3 of 9, by b_riera
I went and did my own test just now.
I have a Pentium II 333 with a GeForce 2 MX400 with no hardware MPEG 2 decoding but some assist if the DVD player supports it apparently. Also, it doesn't have a DVD drive so I copied a VOB file off a disc and transferred it over.
Running Media Player Classic on Windows 98 and it was a total slideshow.
So I installed Cyberlink PowerDVD XP 4.0 and it played back very smoothly. The CPU usage was at 100% though but it was still smooth.
So, software definitely matters on something this old. Also, what he said ^^^
Reply 4 of 9, by Repo Man11
The lowest spec system I've recently played a DVD on is a PCChips M520 with a K6-3+ 450 (6x75 MHz), a PCI FX5500, Win98 SE and 96 megs of EDO. With PowerDVD XP installed it played DVDs with no issues.
Reply 5 of 9, by matt102498
b_riera wrote on 2025-10-11, 22:43:
I guess I would try ruling out the drive by ripping a DVD to the CF drive and playing the directly. If DMA isn't on for the DVD […]
I didn't think to check if DMA was working on the drive. Would be a simple solution. I'll have to figure out where the DMA enabled check was again.
Thanks
Reply 6 of 9, by matt102498
Unknown_K wrote on 2025-10-11, 23:04:
Yes, IDE 1 is the CF, IDE 2 is a DVD and CD drive
Reply 7 of 9, by matt102498
b_riera wrote on 2025-10-11, 23:39:
I went and did my own test just now. […]
I used PowerDVD 4.0 XP at the suggestion of the online community that it played so well with ATI graphics. It's probably about 5 frames per second, they play, but not well.
Reply 8 of 9, by Matth79
Did you try ATI Multimedia Center, that probably has the best ATI GPU acceleration
Reply 9 of 9, by marxveix
Use ATiDVD Control Panel to change acceleration type, i have no problem even with Rage Pro cards, Rage128&Rage128Pro cards are even better!
I have used Rage128 Pro even with AMD K6 266MHZ and no, its not even K6-II. AMD K6-III or PII-300 should have no problems at ATiDVD.
With Radeon 7500 with correct driver and DVD software there should be no problems, havent used lately Radeon 7500 for DVD.
You can use my software bundle , its for RagePro, DVD part should aslo work with Rage128, Radeon may need newer ATiDVD
Re: ATi RagePro drivers and software
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … %20Panel.7z?w=1
ATiDVD Player and ATiMMC6.3
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … 20ATiMMC.7z?w=1
ATi DVD Player 3.1 with ATi Video Player
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … ATiCombo.7z?w=1
ATi MMC 6.3 with ATi DVD 3.2 / its made for Rage Pro/Rage128/Rage128 Pro
https://hingetee.ee/library/Software/ATi/Win9 … MC630/MMC63.ZIP
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
