First post, by Killermac
Hey everyone,
I made a small mistake and ended up buying a GTX 750 instead of the GTX 750 Ti, and now I’m wondering if there will be any real difference for my goals with this build. I’d really appreciate your help figuring that out.
Main goal:
I want the machine to run all the games listed below at maximum settings, in 1920x1200 (or 1600x1200 when 16:10 isn’t supported), and maintain at least 75 FPS to take full advantage of my ASUS PA248QV running at 75Hz.
I won’t be doing any overclocking — the focus is on stability, longevity, and reliability, not squeezing out performance. This build is meant to be a nostalgic time capsule that’ll last for many years.
Game list (with developers and publishers):
Age of Empires III (Ensemble Studios®, October 2005)
Counter-Strike (Valve Corporation®, November 2000)
Diablo II (Blizzard North®, June 2000)
Doom 3 (id Software®, August 2003)
Fable: The Lost Chapters (Lionhead Studios®, September 2005)
Grand Theft Auto: San Andreas (Rockstar North®, June 2005)
Gold and Glory: The Road to El Dorado (Revolution Software®, November 2000)
GunZ: The Duel (Maiet Entertainment®, June 2003)
Mu Online (Webzen®, October 2003)
SimCity 4 & Rush Hour (Maxis®, January 2003)
Star Wars: Republic Commando (Aspyr Media®, February 2005)
The Sims (Maxis®, February 2000)
UFO: Extraterrestrials (Chaos Concept®, May 2007)
Vampire: The Masquerade – Redemption (Nihilistic Software®, June 2000)
Warcraft III: Reign of Chaos & The Frozen Throne (Blizzard Entertainment®, 2002–2003)
With Your Destiny (JoyImpact®, May 2003)
System specs:
Intel® Core i7-3770K
EVGA® GeForce GTX 750
ASUS® SABERTOOTH™ Z77
Creative® Sound Blaster X-Fi Titanium 7.1
Noctua® NH-U12S chromax.black
Western Digital® WD_BLACK 1TB
Corsair® Dominator DDR3 1600MHz 4GB
ASUS® DRW-24F1MT
Corsair® RM650x PSU
Corsair® Carbide Series 100R case
Thanks a lot for your time and advice — I really want to make sure this build stays solid for years to come!
ASUS® SABERTOOTH Z77
Intel® Core™ i7-3770K
EVGA® GeForce GTX 980 Ti
Western Digital® WD_BLACK 1 TB
Crucial® MX500 1TB
Corsair® Dominator 4x4GB 1600MHz
Reply 1 of 18, by RandomStranger
The compatibility between vanilla and Ti are the same. There is a performance difference, but your games are so old a GT740 would be enough for most if not all of them.
Reply 2 of 18, by Killermac
RandomStranger wrote on 2025-10-12, 05:09:
Thank you very much for your help! In your opinion, I shouldn't be concerned about setting antialiasing to the maximum, considering my graphics card only has 1 GB of VRAM?
Crucial® MX500 1TB
Reply 3 of 18, by RandomStranger
When most of these games came out no graphics card had more than 256MB. The industry only moved to sell graphics cards with 512MB with the high-end models of Radeon R500 (X1000) and G70 (Radeon 7000) series in late 2005. 1GB as an option, and not a standard came a good 2 years later.
Reply 4 of 18, by Bruno128
GTX 750 with ivy bridge i7 will make short work of all those games performance-wise but compatibility (driver is too new) may be an issue for less known titles released around year 2000.
SBEMU compatibility reports list | Navigation thread
Reply 5 of 18, by Matth79
For XP, may be worth disabling HT in BIOS, so it runs only 1 thread per core, as XP does not have core vs HT thread aware scheduling
Reply 6 of 18, by chinny22
Matth79 wrote on 2025-10-14, 20:37:
Given how overpowered the CPU is for the games in question, I doubt it'll make much difference.
but given it's such a low risk/low effort change OP can see if it makes any difference easy enough if they wish
Reply 7 of 18, by SScorpio
The era for the games listed would have them generally max out at using a two cores. The XBox 360 was released in 2005 and had three cores, while the 2006 PlayStation 3 had one big core and seven smaller almost GPU shader like computer units. It really wasn't until 2008/9 when development started utilizing the full PS3 that games started be more multithreaded. There's pretty much zero reason to go with an i7 over an i5. Though and i3 with disabled hyperthreading so it was just a dual core is also more than enough for almost any XP game.
Reply 8 of 18, by Killermac
Thank you so much for all the responses!
I know the choice of components might seem a bit odd when compared to the final goal of the build, so here’s some context:
Originally, I wanted to create a kind of “Windows XP Ultimate” system, built specifically to play a handful of childhood games — but with all graphics settings maxed out.
The original GPU was an EVGA GTX 980 Ti, which unfortunately started having issues, especially with crashing in solid colors while playing Fable: The Lost Chapters. Sometimes the crashes would freeze the whole system until a restart, and other times I'd get a Windows pop-up saying the NVIDIA driver had stopped working. I ran a stress test and it showed tens of thousands of VRAM errors. I believe this was due to the high temperatures where I live and a poor cooling setup.
That was a tough hit — not only because I had paid a lot for that GPU, but also because parts are hard to find where I live, my tech knowledge is limited, and my budget isn't the biggest.
So, a bit shaken by the experience, I decided to prioritize reliability over raw performance. I just wanted something that could run those few games on max settings, at a stable 75fps to match my 75Hz monitor, without giving me headaches.
After dealing with a lot of compatibility issues and trial-and-error with different parts, I’ve reached a point where I just want the system to work — and to last — so I can simply enjoy playing.
In your opinion, did it make sense for me to go with the GTX 750? I got it pretty cheap (even though it was a bit of an accidental purchase), but I’m open to upgrading(read downgrading to something that makes more sense) in the future if there’s a better option worth considering.
Crucial® MX500 1TB
Reply 9 of 18, by SScorpio
Killermac wrote on 2025-10-19, 20:27:
Does it lets you play all of the games you want at maxed out settings for your display? If so, what benefit would you get from a more powerful GPU? You are running hardware that is up to a decade newer than the games so it's more powerful that the fastest hardware when those games were released, but sips power.
The top end GPUs of a series are normally red lined. They are sucking down power and pumping out a bunch of heat to hit their performance levels. This can cause extra wear on the parts causing them to die more quickly. A card that's using 1/3rd of the power could potentially last longer.
So, in the end. If the card is playing everything you want at the settings and performance you want. What more are you looking to achieve?
The top end of the series be it CPU, GPU, or something else will often be much more expensive because people are conditioned to what the best of the best. But a step down could be 10-15% less performance but cost orders of magnitude less. When doing a build, also come up with a target on what you want the build to achieve. Then figure out what parts will match your goals without breaking the bank, while having the best chance to not be limping along on its last legs being a ticking time bomb waiting to die on you.
Reply 10 of 18, by Killermac
SScorpio wrote on 2025-10-19, 21:35:
Does it lets you play all of the games you want at maxed out settings for your display? If so, what benefit would you get from a […]
Thanks for helping me out!
I think what I was trying to express wasn’t about wanting more GPU power, but actually the opposite — I’m looking to scale down.
At first, the goal was to build the most powerful XP-era machine I could, as if money weren’t an issue back then. But after losing the GPU (which I honestly think was my fault — it was working perfectly and could run anything at first), my priorities changed. Now, I just want a system that can run all those games smoothly, without giving me headaches.
My question was more like:
"Can I go even lower in performance, still keep all the games running at max quality with a solid 75fps minimum, and reduce power consumption even more — all without running into bottlenecks or other issues?"
Crucial® MX500 1TB
Reply 11 of 18, by SScorpio
Killermac wrote on 2025-10-19, 21:49:
Gotcha, IMO no. You are at somewhat of a crazy sweet spot. The GTX 750 is rated at 55W, go a generation back and you are at 65W for a GTX 650. The GTX 550ti is 116W and GTS 450 is 106W. While a few percentage points (6-7%) more powerful card like the GTX 470 is 4x the power at 215W.
You normally have to go newer to get more performance for less power, but the GTX 950 is a 90W card.
If you didn't already, go into your BIOS and disable hyperthreading. You might also want to think about disabling two of the cores so you'll have only two cores running since as discussed above most XP games don't really scale beyond a dual core and your ivybridge is way more CPU power than XP era games will need. And since you have an unlocked K processor, maybe thing about limiting the multiplier to underclock it a little so it will use less power when boosting.
Reply 12 of 18, by Bruno128
I think the low hanging fruit here is CPU.
Games listed don’t benefit from quad core and they won’t be bottlenecked by much cooler model (like i3-3220T)
Reply 13 of 18, by Bruno128
I’d speculate you may even be well with a Celeron. And sell 3770K for profit to an overclocker if money is the issue.
It’s only in late 00s games after Bioshock you may start seeing CPU bottleneck.
Reply 14 of 18, by agent_x007
1) Use VGA connector for simplicity sake (1200p75 may need custom resolution on DVI/HDMI, but VGA should fix this issue).
2) As mentioned earlier, a Maxwell card will have limited range of drivers for troubleshooting purposes.
Personally I'd go with GTX 680 for better compatibility while retaining somewhat reasonable Perf/Power ratio.
3) Since you already have i7 there is no point in downgrading.
If some idiot thinks four threads is too much, you can simply tell him that disabling cores for free and still having full fat 8MB of L3 for it to play around it is not worth downgrade.
4) If some programs crash/hang/give you other weird issues - try updating .NET and Visual C++ (not needed for 2005-2006 stuff).
Reply 15 of 18, by gregorem
I would take all tips from those tread with huge doubt. You definitely not need such powerful hardware for playing any XP games, especial those you mentioned. GeForce 750 is a pretty nice GPU for Windows 7 setup, on which many games from Windows 7 period will be working smoothly at Full HD. And you listed some games from pre-XP age (Counter Strike, Sims, Vampire).
Here is some showcase of Doom 3 (I guess most demanding game from your list, next to AoE III): https://www.youtube.com/watch?v=CZ5PVhL3p94
Guy gets over 200 FPS with i7 920 and 4870x2. You targeted 400 FPS? And with newer hardware you could find some incompatibilities. Theoretically, GT 750 still supports DX9, but producers was removed outdated features all the time. I have seen Doom 3 playing fine on GT 430 in FHD on max settings, so some low-end Radeon 6000 (or similar GeForce) is the maximum of what you need. In case of CPU, something like i5 750?
Reply 17 of 18, by gregorem
Bruno128 wrote on 2025-11-01, 10:37:
gregorem wrote on 2025-10-28, 16:43:
Doom3 maxed doesn't run well on Radeon HD5450
Not surprising - Radeon 5450 is 40% slower than 4650 and almost twice than GT 430.
