First post, by Alahndro
The last a year I installed Linux debian on all my old Laptops, besides Windows, and for backups and preparations this meant to transfer huge amount of partition backups out and in from external storage via the USB port.
But still this is rather slow -why are there no USB 3.0 cards for older laptops using the cardbus socket?
Though there are adapters for cardexpress I could not find a verified one to really translate from the pci-e lanes.
Why not? Let's tinker something:
The attachment 1743785930799.jpg is no longer available
I removed the chip from an older wifi card and soldered the ribbon cable directly onto the pins of the socket:
It needed 3 reworks and a lot of patience until all 68 pins were connected.
This sunday evening I had my first success:
The attachment IMG_20251012_194024.jpg is no longer available
The card gets detected but cannot be started (code 10). I tried several cards and it got obvious I miss something here..
I post this for the hope that the vogon community can help me getting this fully working.
Further details in upcoming posts.
Now your thoughts/questions/critics:
Reply 1 of 17, by Alahndro
Sorry, but somehow the pics are in the wrong order and I can't find the edit function.
Reply 3 of 17, by Alahndro
There's a working solution available on indiamart:
https://www.indiamart.com/proddetail/communic … 8831215473.html
I tried to contact them but got no answer. They say that it is possible to use any card with their adapter.
But instead of an attached box I gonna make mine like this:
https://www.alibaba.com/product-detail/Pcmcia … .5ab85f93gDiMSc
Just that mine will have a shorter cable and will connect to a pci-adapter-pcb.
Beside the next idea is to make another variant for the external adapter: for AGP.
My goal is to have a convinient way to test or use pci/agp/pcie cards sitting besides any old notebook. Especially as it is pnp: no need to power down a clumsy desktop-pc to install another card. Just attach or remove any card for tests, tinkering or pure fun. Using my old gericom webgine from 2001 with a Geforce TI4200 or let's say a vodoo as external gpu 😉
Reply 4 of 17, by Alahndro
I got some minor improvments by:
- pulling up the IDSELECT line of the PCI socket. This signal has no counterpart on the cardbus side. photos of disassembled carbdus cards show this signal also being pulled up by a resistor.
- blocking the backfeed of power into the 3.3v volt rail with a shotky diode. My OZ6912 cardbus controller refuses to start the interface if it senses power being already applied on the card.
This improved the detection rate of the cards I tested. And even my USB3.0 Card could be seen behind a pci-e bridge on linux.
But still both windows and linux refuse or cannot start the cards. I fear I have some bad data corruption. gonna scope the signal the next days. Ideas:
- improve the ground connections between the socket and the card. Currently only 5 lines of the ribbon cable carry ground - could be to few.
- insert some resistors into the data lines to dampen reflections. That are at least 32 data lines, gonna be another soldering nightmare.
Reply 5 of 17, by Alahndro
OK. all what was needed was a proper back shielding of the ribbon cable to improve signal integrity.
The results still aren't perfect but at least my usb 3.0 controller appears fully working:
The attachment IMG_20251024_170911.jpg is no longer available
The attachment IMG_20251024_170225.jpg is no longer available
The attachment IMG_20251024_170411.jpg is no longer available
Reply 6 of 17, by Alahndro
Running Matrox Millennium PCI Gfxcard via cardbus as dual screen in Win7:
The attachment IMG_20251024_224345.jpg is no longer available
Reply 7 of 17, by lolo799
This looks nice and very useful, good job!
At the sacrifice of a rt2560 cardbus card though, those can be still used to load demo files on DS.
The company Magma made external enclosures with one or more pci ports and a cardbus interface, they're not easy to find.
There are cardbus to expresscard34 adapters, and expresscard usb3 cards I believe.
Reply 8 of 17, by Alahndro
There a numerous adapters for expresscard and either they do not provide details or mention explicit that they are not suited for pcie based expresscards as they only translate to usb 2.0.
That's the reason I started this experiment.
Currently my success rate is at about 50%. Some cards still fail to init and though my usb3.0 cards gets recogniced it speed is still usb2.0 in linux and in windows the communication gets stuck.
I'm confident to improve this - all that is needs is even better shielding and grounding.
But my via based sata/ide card achieved a transfer speed of 55MB/s
Reply 9 of 17, by bk2
Logged in just to comment, awesome project! I'd looked in the past for MiniPCI or Cardbus adapters to PCI to extend the life of some older laptops as servers, but only saw those more expensive external enclosures.
Would be cool once you have it more stable if a couple PCBs could be designed.
Reply 10 of 17, by Alahndro
PCB-design is what I planned next. I just build this first as the cheapest test to see if it can work at all.
Though I've got some bad news:
I tested my pci-e bridge card and WinXP fails to init with Code 12 - Not enough resources,
but Win7 does start it OK.
Still I'm not sure if it's is due to a limit in XP's pci.sys or still to bad signal integrity.
So the next step is to design more proper PCBs. I already sourced the connectors on allconnectors.de, even the cardbus socket and housing:
http://www.allconnectors.de/pages/board-to-bo … ---cards/pc.php
Reply 11 of 17, by Alahndro
I wanted to let all you know that my project is advancing!
Thanks to the holidays I had enough free time to get used to LibrePCB. Over the last days I was building the components for the cardbus socket and the pci socket and initial board placement has begun:
The attachment cb2pci_Board.png is no longer available
Now I have to decide on the following remaining questions:
- how many layers I should use? The PCBs of cardbus cards are rather thin and I suspect that cheap ones only use 2 layers.
- shall I insert level shifters between the connectors or trust the fact that the cardbus-controllers are fully 5V tolerant? Maybe at least insert some resistors to dampen reflections?
- what kind of buck converter to use. I already researched the TPS54- series, but still would prefer something in so-8 that has legs.
- understand the logic of the Carddetect-pins. I liked to have a physical bush-button switch on the adapter that disables the card without the need to actually remove it from the socket to prevent wearing out the pins.
- etc. etc.
I kindly accept any hints you can give me on this.
Happy new Year to all!
Reply 12 of 17, by BassDicer
Hi! I know this is a little while after the last one, but did you end up getting around to finalising a design for the PCB? If the interest is gone, I'd be interested in working on it.
Reply 13 of 17, by Alahndro
Sorry, if I have not yet posted further updates. The reason is that I could not find enough free time due to work and it also needs some further considerations and preparations.
Like reviving my own blog as main project site and anchor point. You can follow it there:
http://ts-finecircuits.de/?p=209
Reply 14 of 17, by Alahndro
Progress on my Card is coming along nicely.
I think I'll be ready to order the first prototype PCBs soon... (at least later THIS year, I hope)
The attachment Progress.PNG is no longer available
Reply 15 of 17, by simontomi
Alahndro wrote on 2026-09-19, 19:42:
Great work, I'm so glad you found the time to continue working on this project! The thought of being able to use external GPUs with old laptops, even AGP ones with a PCI to AGP adapter is exciting 😀
Reply 16 of 17, by Alahndro
The card is finished. Currently I'm trying to source the sockets and connectors, the 68-pin socket and the PCI connector is available on ebay, but I haven't found a easy source for the cover - that is important for a proper card insertion.
I want to recheck the whole design for errors before I gonna send it to PCBway. First patch order will be 10 pieces. If all goes well I can order more 😀
Aaaand I'm already contemplating for the next variants:
- AGP (with level shifters to 1.5V)
- IDE card based on VT6421
Reply 17 of 17, by simontomi
Alahndro wrote on 2026-09-24, 10:58:
The card is finished. Currently I'm trying to source the sockets and connectors, the 68-pin socket and the PCI connector is avai […]
That's awesome!! I cannot wait to build one for myself 😀
The AGP version is very exciting too!
