First post, by ubertrout
I got a lot of cards as untested, and by far the most interesting was a Radeon 9600 XT. Put it in a system and I can't figure out if it's broken or it's just troublesome.
The good - regular 2d performance on the VGA port in Windows 98 is just fine. No artifacting, nothing weird. Windows sees it and drivers install fine. HWinfo32 sees 128 MB of SDRAM on the card and that the card is running at 499.5 Mhz and Memory is running at 297 Mhz.
The bad - I pretty much can't get it to do anything 3D. Quake 2 and Unreal Tournament both pretty much refuse to work. Even the DirectX 3D test fails. Weirdly GLQuake seems to work great. Not sure what's going on there.
Any thoughts as to what's going on? Nice AGP cards are getting harder to find and I'd rather not give up on this card quickly.
Reply 1 of 29, by Ozzuneoj
I would say the card is defective if not for GL Quake seemingly working fine.
Make sure DirectX 9 is installed since the drivers are likely expecting that, even if games aren't (no idea if this is required, but it seems like a good idea).
Next, try running a driver cleaner to get rid of any video drivers on the system, then install an old-ish driver (something from before the X800 series was released, to keep it contemporary to the 9x00 series).
Download and install a high res texture pack for GLQuake, and run the game at the highest resolution possible. This may reveal whether it's a video memory related issue.
Only other thing I can think of is that AGP aperture size and AGP Fastwrites were problematic on some systems back in the day, so those settings may need tweaked in the BIOS or drivers.
Reply 3 of 29, by ubertrout
Ozzuneoj wrote on 2025-10-21, 03:59:
I would say the card is defective if not for GL Quake seemingly working fine. […]
What should aperture and fastwrites be set at to avoid issues? Good call about DDU etc.
Reply 4 of 29, by ubertrout
tehsiggi wrote on 2025-10-21, 04:12:
If you have DOS running anyways, give it a shot to run R3MEMID and see if there are any memory faults.
I wasn't familiar with this tool; will try.
Reply 5 of 29, by Ozzuneoj
ubertrout wrote on 2025-10-21, 04:17:
Usually Fastwrites set to Off is the safer bet (while On can potentially improve performance). As far as AGP aperture goes, this isn't usually an issue, I just figured I'd throw it out there. Changing it from whatever it is (higher or lower) will either help or, more likely, do nothing at all, but at least you'll be able to rule out one of the few graphics related settings that exists outside of the OS and drivers.
Reply 6 of 29, by ubertrout
Few other things - board is a MSI MS-6330. There's 256 MB of RAM and a Athlon 1700+ CPU. The whole thing except for the CPU was a recycling center find so it's possible it was dropped off for reasons other than being old, but there were no signs of retroish use.
One thing I did notice is that the CF card I'm using in the system in had a ATI MiniGL Driver for GLQuake already installed. If that's why GLQuake is working it implies it really could just be drivers potentially. Or undue optimism - I'll try the above stuff tonight.
Reply 7 of 29, by momaka
9000 series Radeons with DDR2/gDDR2 are apparently known to develop bad vRAM, at least according to what I've been reading around here (Vogons.)
Of course Windows 98 / 9x being iffy could be it too (I never trust that OS when I see system issues.)
But before jumping to any conclusions, I would suggest to just put another HDD in the system and test everything with Windows XP SP3 and some era-appropriate ATI drivers. If that doesn't work, then start thinking about further troubleshooting the card.
Reply 8 of 29, by ubertrout
So, the plot thickens. I removed all other display drivers and reinstalled and Direct3D really isn't happy. It won't work pretty much ever. I upgraded to 9.0c and it didn't help.
But here's the thing...OpenGL seems to work fine. I replaced the OpenGL file from the driver with the OpenGL driver in Quake 2 and Half-Life 1 and they both started without complaint and seemed to be running fine at 1024x768. Does this make sense to anyone?
Edit: if it helps running timedemo demo1 in GLQuake at 1024x768 got 222.3 fps.
Reply 9 of 29, by ubertrout
Update: You'll be happy to know that I'm a idiot and hadn't properly installed the AGP drivers. Seems to be working now although Windows seems kind of unstable for what I hope is other reasons. Need to try some games.
Edit: So it all works now...but the video card seems to have problems. I don't know if it's bad cooling or memory what but it's crashing out fast of most things. This time though a 3D signal is working, including in Direct3D.
I'd test it in DOS but I can't get a PS/2 keyboard to work with this PC and the USB keyboard doesn't seem to work in DOS. I think I'm going to go back to the Radeon 9000 I had in there before. Less fun, but fine for Win98.
Reply 10 of 29, by tehsiggi
momaka wrote on 2025-10-21, 20:57:
It's not DDR2, it's most of the time plain DDR1 (sometimes called GDDR1) memory. Usually from Hynix or Samsung, up to 350MHz clock speeds. There were a few DDR2 (not GDDR2) variants of the 9550, 9600 and 9800 but they are pretty rare compared to the DDR1 variants.
Did you run R3MEMID to see if the memory is faulty?
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 11 of 29, by ux-3
Can you try it in some other PC?
Retro PC warning: The things you own end up owning you.
Reply 12 of 29, by ubertrout
tehsiggi wrote on 2025-10-22, 10:45:
Getting R3MEMID to run was a struggle because the PC doesn't seem to recognize PS/2 keyboards and DOS doesn't want to work with my USB one (yes, I checked BIOS settings). I finally realized that I could put R3MEMID into dosstart.bat and to put dos4gw into the root directory. After a second this is what the screen showed. Pretty sure it's the memory.
Reply 13 of 29, by tehsiggi
What happens if you apply pressure to the memory ICs (front and back, use your thumb and indexfinger like a vice) during that? does the pattern change?
You can run r3memid "blind" and get the result logged.
Re: ATI 9700 Pro Broken
Reply 14 of 29, by ubertrout
ux-3 wrote on 2025-10-22, 13:29:
I don't have another AGP 4/8x system. But it's pretty clearly memory.
Reply 15 of 29, by ubertrout
tehsiggi wrote on 2025-10-22, 14:19:
Um, that's more hands on than I'm used to getting in testing. I'll double check getting a log file first 😀
Reply 16 of 29, by ubertrout
How long does r3memid take to run? The screen output is totally corrupted and when I rebooted after ten minutes or so the log file was blank.
Reply 17 of 29, by tehsiggi
Did you take the command from that thread? That shouldn't take more than 3-5 minutes at best if it's only running the first test. Furthermore, the pattern should change quite a lot, as the tests are executing.
Reply 18 of 29, by ubertrout
tehsiggi wrote on 2025-10-22, 18:06:
Yes, and I gave it more time than that. The pattern at first was the attached, then the monitor went into standby, and when I came back it was garbled like in my previous post.
