First post, by Mu0n
I made a new MSDOS utility, the MIDI Sniffer:
* takes in MIDI in
* reroutes to: MIDI out, PC Speaker, or OPL2
* supports polyphony
* can take in regular keyboard playing (qwerty...] = white notes, etc)
* generate a random OPL2 instrument for you to dig and test out its values (I use that to find new interesting sounds for other projects)
it's a little rough around the edges, since it works well on my weecee but I need bug reports on other machines. it freezes in dosbox, dosbox-x and will beep with filled keyboard buffer very quickly on my 486 when you use the typing keyboard
github page including source code and .exe binary: https://github.com/Mu0n/MIDI_in_Sniffer
demonstration video is here: https://youtu.be/9_MNY7hs1qg
1Bit Fever Dreams: https://www.youtube.com/channel/UC9YYXWX1SxBhh1YB-feIPPw
AnyBit Fever Dreams: https://www.youtube.com/channel/UCIUn0Dp6PM8DBTF-5g0nvcw
Reply 1 of 1, by gerry
That sounds like a cool project, hope people make use if it. I like that you used Borland C too ( it could even become a windows 3 application building on same source if anyone wants to "enjoy" win 16 code 😀 )
