First post, by Calolo
Hello
I have a retro PC with the following specifications:
- Gigabyte GA-6BXC v2.0 440BX - BIOS "powerleap3.bin"
- Intel Pentium III 800MHz (8x100)
- Soltek SL-02A++
- 256MB SDRAM PC133 C2
- 3dfx Voodoo 3 1000 16MB AGP (O/C @145MHz)
- 64GB Lexar Professional CF 800x
- Windows 98 SE
All games work fine but the memory bandwidth benchmarks are quite low.
Using Sandra 2002 or 2004, the "INT" bandwidth is normal (same as other benchmarks) but the FLOAT is underperforming (-40%).
I tried with a clean install of Win98SE but the results are the same.
What could be causing this loss of performance in the FLOAT bench?
I see the same low results in the AIDA32 memory benchmark.
I tried to flash the BIOS to the "beta F4c" version but no change.
No more luck by swapping with other memory sticks...
Thanks for your help.
DOS/98SE : PIII-S 1400/C3 1200, GA-6BXC 2.0, 256MB PC133 C2, GeForce 2 Ultra, Voodoo2 12MB, Audigy1 Platinum Ex, ESS1688, SSD 128GB
XP/7 : i5 3750k, 8GB DDR3 1600, GTX 280 1GB, Radeon X1950 XTX, SSD 512GB
Reply 2 of 14, by maxtherabbit
Check if the BIOS has an option for "in order queue depth" and set it to its highest value
Reply 3 of 14, by Calolo
Of course I have forced the memory CAS2 in the BIOS setup.
Unfortunately no option "in-order queue depth" for this motherboard. Some software reports the value of 4 is used (should be 8?).
Reply 4 of 14, by maxtherabbit
I believe 4 is the correct value for a BX
Reply 5 of 14, by Calolo
Here is the analyse of my problem from ChatGPT, I don't know if it's true but could be an explanation :
🧩 Summary: Low “Float iSSE” Memory Bandwidth on Pentium III Coppermine + Intel 440BX
I was testing an old PC with a Pentium III 800 MHz (Coppermine), GA-6BXC motherboard (Intel 440BX chipset), and 256 MB SDRAM CAS2.
In SiSoft Sandra 2002 and 2004, the memory benchmark shows normal “Integer” bandwidth, but the “Float iSSE” score is about 40 % lower than expected.
Older Sandra 2001 (which doesn’t use SSE in its memory test) reports normal and balanced Integer/Float results.
After checking everything — BIOS cache settings, RAM timings, chipset drivers — the cause turned out to be the 440BX chipset itself, not the CPU or RAM.
🔍 What’s Really Happening
Starting with Sandra 2002, the memory benchmark uses SSE (iSSE) routines that move data in 128-bit blocks (MOVAPS/MOVNTPS).
The 440BX memory controller, designed before SSE existed, only optimizes 64-bit burst transfers and doesn’t handle 128-bit SSE memory access patterns efficiently.
As a result, SSE memory throughput (the “Float iSSE” test) is about 30–40 % slower than expected.
The Integer test is fine, because it still uses regular 64-bit memory operations which the 440BX handles perfectly.
🧠 Why Real-World Performance Isn’t Affected
Games and real applications don’t stream large blocks of floats directly from main memory like Sandra’s synthetic test.
Most data fits in the L1/L2 cache, and game engines use SSE arithmetic on cached data, not on big raw memory transfers.
So this bandwidth drop is only visible in synthetic benchmarks, not in actual 3D or physics performance.
⚙️ Katmai vs. Coppermine
With a Pentium III Katmai, Sandra doesn’t use full 128-bit SSE memory moves (the Katmai only supports a limited SSE subset).
→ Memory results are normal.
With a Coppermine, full SSE 128-bit instructions are used.
→ The 440BX can’t burst them efficiently, so the “Float iSSE” score drops.
Conclusion
It’s not a defect — just a chipset limitation.
The 440BX predates full SSE support and can’t optimize 128-bit memory transfers.
Everything works as it should; it only affects Sandra’s “Float iSSE” synthetic score.
Newer chipsets like the i815E or VIA Apollo Pro 133A don’t show this issue.
Reply 6 of 14, by AlexZ
This is probably a problem of a process using the CPU while the benchmark is running. Sisoft sandra memory test can be inconsistent in Windows 98. It helps to re-run the same test multiple times, even reboot the PC. You should be able to get good results at least once.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 ML-37@2.2Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 7 of 14, by Calolo
I have noticed that the performance can be lower when another thread is running in the background, same if you run the benchmark multiple times.
With Sandra 2002 or 2004, the Float memory benchmark using SSE is limited to about 425Mb/s, no matter what I do.
With Sandra 2001 the benchmark is not using SSE, so the results are normal when comparing with other systems.
Maybe someone with a Coppermine CPU on a 440BX motherboard could confirm this behavior?
Reply 8 of 14, by AlexZ
I have Coppermine on 440BX and do not see that behavior. Try reinstalling OS and install as few drivers as possible. You can also try running it in safe mode.
Reply 9 of 14, by Calolo
Even in safe mode the benchmark results are the same.
Maybe this is a bug of the GA-6BXC motherboard ?
Reply 10 of 14, by AlexZ
It could be BIOS or microcode issue. Maybe you can try updating BIOS. It's a 3 ISA slot board, those tend to be older. You could also try looking at wpcredit with 440bx chipset file. Perhaps there is a setting that can be abled to fix it.
Before updating BIOS try Everest 5.5 or 5.3. 5.5 is from 2010 but still works on Windows 98. It is better than Sisoft Sandra which became bloatware.
It is very difficult to get consistent results from Sisoft Sandra memory benchmark. Everest 5.5 memory test gives me 786MB/s (read), 787MB/s (write), 114ns latency. It would take like 30 attempts in Sisoft Sandra to get results that make sense.
Reply 11 of 14, by Calolo
The BIOS was released in 2002 and is ready for Tualatin and C3 CPUs, so there shouldn't be a microcode issue with Coppermine.
Reply 12 of 14, by AlexZ
Try Everest 5.5, see my results above.
Reply 13 of 14, by Calolo
My Everest results are close to yours, we are close to the maximum bandwidth of FSB @100MHz (800MB/s)
Reply 14 of 14, by AlexZ
So the problem is in Sisoft Sandra, not your board.
