First post, by Dusko
- Member
Hello all!
I’m trying to understand how I can switch between the OPL3 and the CQM on this SB16 CT1740.
From what I’ve read, the jumpers (IFSD and APSD) that activate the CQM should be open, which they are. In fact, the pins weren’t even installed from the factory.
Now, I’m almost certain that the FM sound I’m hearing is coming from the OPL3. I’m tempted to install jumper pins and close them just to see what happens, but I wanted to ask here first.
What also confuses me is this: if the jumper pins weren’t installed from the factory, forcing the use of the CQM, then why bother including an OPL3 chip in the first place?
Could it be that it's actually using the CQM? In that case, it doesn't sound bad after all, somewhat dull, but that may be due to the old caps.
Any thoughts?
Thanks!
Retro PC games channel: http://www.youtube.com/@myRetroPC
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
Reddit: https://www.reddit.com/r/MyRetroPC
FaceBook: https://www.facebook.com/myretropc
