First post, by SueFoster
Wonder if you would be able to help. I have a very old database program which needed Windows XP 32 bit. Unfortunately it does not work on the 64 bit refurbished computer I have just purchased as a replacement for one that is faDosbox installed.
I can successfully mount y C Drive and the sub directory where my program resides but am having difficulty knowing how to insert those dosbox on exit e exe file so that my program initiates and also how to iinput the lines to ensure that dosbox exits when I close the rprgram rather that having to use the exit command. Any suggestion would be gratefully received.After running Dosbox, the dosbox emulator runs but the commnd line has returned to Z:\
I am entering the following command into the auto exec field on the dosbox options batch file. The folder is on my C Drive
MOUNT C C:\Recorder\Arev
This loads the C drive but does not run the software.  I am not sure where to put the run command
