First post, by AM_PM
This Vogons thread: Virtual floppy drive under MS-DOS?, helped me discover Turbo Image (TI101A) which is a great program resident in extended memory allowing the mounting of floppy images as virtual drives in DOS. Sadly, the mounting is only effective in DOS itself and does not carry on when launching Windows. I've searched a lot but have been unable to locate a similar virtual mounting software that works in Windows 3.1 or 3.0. Does anyone know any?
Reply 1 of 6, by Jo22
Oof! Hard to say! Back then Windows 3.x was using MS-DOS for such things, I guess!
True floppy emulation might involve DMA emulation and VXDs, maybe.
It's more in Windows 95/98 era, I think. When virtual CD-ROM drives got common and VXDs would emulated Sound Blaster cards for DOS compatibility and so on.
That being said, it's not impossible that there's something for Windows 3.1 and 95.
Maybe an early virtual floppy for Windows 95 will work on Windows 3.1, too?
The *.386 files are VXDs.
Reply 2 of 6, by Ringding
Turn off 32 bit file access (386 enhanced settings)?
Reply 3 of 6, by AM_PM
Jo22 wrote on 2025-10-31, 16:26:
Oof! Hard to say! Back then Windows 3.x was using MS-DOS for such things, I guess! True floppy emulation might involve DMA emula […]
Yeah sadly not luck yet, an early one for Windows 95 probably wouldn't work being 32-bit (unless 32s works!).
Ringding wrote on 2025-10-31, 20:29:
Don't have that option in my 3.1.
Reply 4 of 6, by Cyberdyne
Try to run Windows in standard mode. Win /s.
Reply 5 of 6, by AM_PM
Cyberdyne wrote on 2025-11-05, 23:27:
I'm guessing you mean after mounting it in DOS. Just tried and no, not any different.
Reply 6 of 6, by AM_PM
I'm using the workaround of using the software WinImage to open and extract every IMG to the hard disk and launch from there. (If there are multiple floppies, every IMG itself should be extracted to a folder called DISK01, DISK02...).
