First post, by ux-3
I am looking for a IDE-CDrom drive that uses USB instead of CDs. Basically a Gotek Floppy Drive gone to CD.
I would kile to transport files to older AT machines that have no USB and I don't want to do it in chunks of 1.44 MB. Burning a CD seems to cumbersome.
Currently, I power down the AT, take the CFcard to PC and copy the files, then move it back and turn it on. I don't like to power down and up all the time with the old PSUs.
That is why I ask.
Retro PC warning: The things you own end up owning you.
Reply 1 of 9, by marxveix
What is the problem with CD or DVD? I use them when needed.
Something like this?
https://shop.tattiebogle.net/product/prod_EkTnv3Tk2Trxhf
https://www.zuluide.com/
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 3 of 9, by squelch41
I think Ian Scott is working on an IDE cdrom emulator and it is due soon...
https://picoide.com/
V4P895P3 VLB Motherboard AMD 486 133MHz.64mb RAM, CF 4Gb HDD,
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
386sx 20MHz ICL NB386s laptop, 4mb RAM, modified bios with XT-IDE, CF 512mb, 387 FPU
Reply 4 of 9, by jakethompson1
marxveix wrote on 2025-10-30, 11:31:
I use them too. However, it does seem like the 52x era CD-ROM drives have a finite lifespan before they start getting picky with which discs to read and not, whether to eject, etc. So even if I don't use these projects, I'm glad the exist, because someday I probably will.
Reply 5 of 9, by jh80
Not USB, but the ZuluIDE supports hot-swapping SD cards.
You can attach a micro SD card extension cable to it and run the cable outside your PC to make accessing it easier.
They just released a slightly cheaper V2: https://www.zuluide.com/
Reply 6 of 9, by Guld
You could also go the network card route using mtcp, that's how I transfer files.
Reply 7 of 9, by ux-3
Lots of input, many thanks.
I am looking for a hot swap option. I am not sure how my old 486 will respond when running DOS, if I simply take out the secondary CF card (non-system), write stuff on it and stick it back in.
Has anyone tried this? Because if that would work and be non destructive to components, it would suffice. It would not change the drive geometry. But would DOS notice in the idle time and would it act up?
Maybe I have a wrong idea, but what is the max file size I can store on a Gotek? 1.44MB? Or can I make them bigger? What transfer speed will a Gotek deliver? How long does it take for 1.44MB?
The problem is that it takes too long for my taste to burn a CD-RW for just a few files. I would like to have a USB port for hot swap, quick transfer. But with DOS, I don't think that is an option.
zuldan wrote on 2025-10-30, 11:47:
PicoGUS is exactly what you want.
It sounds great, given the versatility and the fact that I have a free 8 bit slot.
BUT ... can I hot swap the stick? Because if not, I can cold swap the CF-card anyway (rear slot).
And while this may be great to move stuff to the 486, how would I move it back off? It can't write to CD in DOS.
While the PicoGUS may not solve my problem, it is a nice gadget to not worry about CDs any more.
jh80 wrote on 2025-11-01, 05:50:
While I like the fact that it hooks up to IDE, I was surprised by the 3-digit price tag. The PicoGUS is actually cheaper and brings a soundcard too.
Guld wrote on 2025-11-01, 11:19:
My last attempt to transfer files through my home network to a win98 machine was cancelled by win11 paranoia. There is a thread here somewhere about it. Would have been nice.
Given the few moments a hot swap is desired, it seems that a gotek might be a wise investment, if it is hot swappable.
And what about simply ripping out the CF card? It might be a subject for another thread.
Reply 8 of 9, by NeoG_
ux-3 wrote on 2025-11-01, 19:12:
It sounds great, given the versatility and the fact that I have a free 8 bit slot. BUT ... can I hot swap the stick? Because if […]
Yes you can hot swap the USB on the PicoGUS, I do it all the time. It doesn't cause any issues because the USB drive is opened in read only mode. Writing data to emulated drives in DOS, I think only the GOTEK can do it. I don't think the upcoming PicoIDE would be able to hot swap writable drives either, only ROM images.
For network based file transfer, FTP is the best option as it works across most generations of computers and carries very little security risk.
As for removing the CF card, the issues will be
a) freezing computer if anything attempts to access a failed fixed disk (removed CF card is 'failed') and
b) corruption of filesystem from partial writes
In pure DOS while in idle it may be possible, but not running anything the does background tasks (e.g. windows).
Reply 9 of 9, by ux-3
NeoG_ wrote on 2025-11-01, 23:21:
As for removing the CF card, the issues will be a) freezing computer if anything attempts to access a failed fixed disk (removed […]
I am not sure if the controller talks to the card all the time and will be upset, if the card seems dead suddenly.
I would not use the 486 while adding files, so Dos would not do reads.
I can see problems with buffers and smartdisk.
